Programmatically limiting GPU access
Is it possible to limit access to the GPU programmatically, either making it unavailable or only available at a specified limit?
Jetson doesn’t have a mechanism to control GPU resource limit.
But you can make it unavailable with the below global variable.
$ ./deviceQuery
./deviceQuery Starting...
 CUDA Device Query (Runtime API) version (CUDART static linking)
Detected 1 CUDA Capable device(s)
Device 0: "Orin"
  CUDA Driver Version / Runtime Version          12.5 / 12.5
  CUDA Capability Major/Minor version number:    8.7
  Total amount of global memory:                 62841 MBytes (65893945344 bytes)
  (016) Multiprocessors, (128) CUDA Cores/MP:    2048 CUDA Cores
  GPU Max Clock rate:                            1300 MHz (1.30 GHz)
  Memory Clock rate:                             1300 Mhz
  Memory Bus Width:                              256-bit
  L2 Cache Size:                                 4194304 bytes
  Maximum Texture Dimension Size (x,y,z)         1D=(131072), 2D=(131072, 65536), 3D=(16384, 16384, 16384)
  Maximum Layered 1D Texture Size, (num) layers  1D=(32768), 2048 layers
  Maximum Layered 2D Texture Size, (num) layers  2D=(32768, 32768), 2048 layers
  Total amount of constant memory:               65536 bytes
  Total amount of shared memory per block:       49152 bytes
  Total shared memory per multiprocessor:        167936 bytes
  Total number of registers available per block: 65536
  Warp size:                                     32
  Maximum number of threads per multiprocessor:  1536
  Maximum number of threads per block:           1024
  Max dimension size of a thread block (x,y,z): (1024, 1024, 64)
  Max dimension size of a grid size    (x,y,z): (2147483647, 65535, 65535)
  Maximum memory pitch:                          2147483647 bytes
  Texture alignment:                             512 bytes
  Concurrent copy and kernel execution:          Yes with 2 copy engine(s)
  Run time limit on kernels:                     No
  Integrated GPU sharing Host Memory:            Yes
  Support host page-locked memory mapping:       Yes
  Alignment requirement for Surfaces:            Yes
  Device has ECC support:                        Disabled
  Device supports Unified Addressing (UVA):      Yes
  Device supports Managed Memory:                Yes
  Device supports Compute Preemption:            Yes
  Supports Cooperative Kernel Launch:            Yes
  Supports MultiDevice Co-op Kernel Launch:      Yes
  Device PCI Domain ID / Bus ID / location ID:   0 / 0 / 0
  Compute Mode:
     < Default (multiple host threads can use ::cudaSetDevice() with device simultaneously) >
deviceQuery, CUDA Driver = CUDART, CUDA Driver Version = 12.5, CUDA Runtime Version = 12.5, NumDevs = 1
Result = PASS
$ export CUDA_VISIBLE_DEVICES=1
$ ./deviceQuery
cudaGetDeviceCount returned 100
-> no CUDA-capable device is detected
Result = FAIL
CUDA_VISIBLE_DEVICES is the variable that controls the visible GPU index.
Since Jetson only has one GPU (index=0), setting the variable with other values should meet your requirement.
Thank you. This implies that processes that had been launched prior to the environment variable having been set wouldn’t be aware of the setting?
Suppose the variable will take effect if the CUDA initialization is executed periodically.
