@WayneWWW, thanks. Is there any way to test if that’s the case? Unfortunately the carrier board’s manufacturer is not very responsive and doesn’t provide any details.
@WayneWWW from what I understand from the attached .dts file, the regulator used for the USB ports I need to reset is vdd-usb-3v3. I tried to use Dane’s method above, but it seems that I can’t disable that regulator, i.e., even if I put disabled inside the state file, nothing happens and the state file always says enabled. Am I missing something? output.dts (355.4 KB)
