Proper Cleanup of OptixDeviceContext
Hello everyone!
I am using OptiX 8.0 for a project, and while optimizing memory usage I noticed something that looks like a GPU memory leak, but which is likely to also be a misunderstanding on my part, hence, my question below.
I set up a simple for-loop in C++ which calls optixDeviceContextCreate and optixDeviceContextDestroy repeatedly. I notice that as this runs, my GPU memory usage grows slow and steady.
  • The VRAM usage keeps growing with more iterations. E.g., if I set it to 2.5k, the program will go from ~230 MiB VRAM to >1.1 GiB VRAM.
  • This isn’t a critical issue—I understand it’s uncommon to actually create/destroy thousands of contexts in a single application; I just want to confirm my understanding of how the API works.
  • Is this expected? If not, what is the correct way to fully clean up the OptiX device context?
Thank you in advance!
Please find additional information like a repro program below
My system:
Ubuntu 20.04.6 LTS
GPU: NVIDIA RTX 4500 Ada Generation
Driver: 570.133.20
CUDA Driver Version: 12.8
CUDA Runtime Version: 12.6
OptiX Header Version: 8.0.0
Snippet to reproduce this leak (requires only CUDA RT API and the OptiX headers). Disclaimer: After I identified the strange memory behavior, I created the repro snippet with help from an AI code assistant.
// Standalone OptiX context memory leak reproducer.
// Tests whether optixDeviceContextCreate/Destroy leaks memory.
#include <cuda_runtime_api.h>
#include <optix.h>
#include <optix_function_table_definition.h>
#include <optix_stubs.h>
#include <chrono>
#include <iomanip>
#include <iostream>
#include <thread>
#define CUDA_CHECK(call)        \
    do {        \
        cudaError_t rc = call;        \
        if (rc != cudaSuccess) {        \
            std::cerr << "CUDA error " << cudaGetErrorName(rc) << " at " << __FILE__ << ":" << __LINE__ << ": " \
                      << cudaGetErrorString(rc) << std::endl;                                                   \
            exit(1);        \
    } while (0)
#define OPTIX_CHECK(call)        \
    do {        \
        OptixResult res = call;        \
        if (res != OPTIX_SUCCESS) {        \
            std::cerr << "OptiX error " << res << " at " << __FILE__ << ":" << __LINE__ << std::endl; \
            exit(1);        \
    } while (0)
static void context_log_cb(unsigned int level, const char *tag, const char *message, void *) {
    // Silence logs
double get_gpu_memory_used_mb() {
    size_t free_bytes, total_bytes;
    CUDA_CHECK(cudaMemGetInfo(&free_bytes, &total_bytes));
    return static_cast<double>(total_bytes - free_bytes) / (1024.0 * 1024.0);
int main(int argc, char **argv) {
    int num_iterations = 150;
    int warmup_iterations = 10;
    if (argc > 1) {
        num_iterations = std::atoi(argv[1]);
    std::cout << "OptiX Context Memory Leak Reproducer" << std::endl;
    std::cout << "=====================================" << std::endl;
    // Initialize CUDA
    CUDA_CHECK(cudaSetDevice(0));
    cudaDeviceProp props;
    CUDA_CHECK(cudaGetDeviceProperties(&props, 0));
    std::cout << "GPU: " << props.name << std::endl;
    CUDA_CHECK(cudaFree(0));  // Force context creation
    // Initialize OptiX (once)
    OPTIX_CHECK(optixInit());
    std::cout << "OptiX initialized" << std::endl;
    // Warmup
    std::cout << "\nWarmup (" << warmup_iterations << " iterations)..." << std::endl;
    for (int i = 0; i < warmup_iterations; i++) {
        OptixDeviceContext context = nullptr;
        OPTIX_CHECK(optixDeviceContextCreate(nullptr, 0, &context));
        OPTIX_CHECK(optixDeviceContextSetLogCallback(context, context_log_cb, nullptr, 3));
        OPTIX_CHECK(optixDeviceContextSetCacheEnabled(context, 0));  // Disable cache
        OPTIX_CHECK(optixDeviceContextDestroy(context));
    CUDA_CHECK(cudaDeviceSynchronize());
    std::this_thread::sleep_for(std::chrono::milliseconds(200));
    // Measure starting memory
    double start_gpu_mb = get_gpu_memory_used_mb();
    std::cout << "\nStarting GPU memory: " << std::fixed << std::setprecision(2) << start_gpu_mb << " MB" << std::endl;
    // Main test loop
    std::cout << "Running " << num_iterations << " create/destroy cycles..." << std::endl;
    auto start_time = std::chrono::steady_clock::now();
    for (int i = 0; i < num_iterations; i++) {
        if ((i + 1) % 100 == 0) {
            double current_mb = get_gpu_memory_used_mb();
            std::cout << "  Iteration " << (i + 1) << ": GPU = " << current_mb << " MB" << std::endl;
    auto end_time = std::chrono::steady_clock::now();
    // Measure ending memory
    double end_gpu_mb = get_gpu_memory_used_mb();
    auto duration = std::chrono::duration_cast<std::chrono::milliseconds>(end_time - start_time);
    std::cout << "\n=====================================" << std::endl;
    std::cout << "Results:" << std::endl;
    std::cout << "  Iterations:        " << num_iterations << std::endl;
    std::cout << "  Duration:          " << duration.count() << " ms" << std::endl;
    std::cout << "  Start GPU memory:  " << start_gpu_mb << " MB" << std::endl;
    std::cout << "  End GPU memory:    " << end_gpu_mb << " MB" << std::endl;
    std::cout << "  Memory change:     " << (end_gpu_mb - start_gpu_mb) << " MB" << std::endl;
    double leak_per_instance_kib = (end_gpu_mb - start_gpu_mb) * 1024.0 / num_iterations;
    std::cout << "  Leak per context:  " << leak_per_instance_kib << " KiB" << std::endl;
    if (leak_per_instance_kib > 1.0) {
        std::cout << "\n⚠️  LEAK CONFIRMED: ~" << leak_per_instance_kib
                  << " KiB per optixDeviceContextCreate/Destroy cycle" << std::endl;
    } else {
        std::cout << "\nâś… No significant leak detected" << std::endl;
    return 0;
Sample output on my machine:
OptiX initialized
Warmup (10 iterations)...
Starting GPU memory: 232.69 MB
Running 2500 create/destroy cycles...
  Iteration 100: GPU = 270.69 MB
  <snip>
  Iteration 2500: GPU = 1182.69 MB
Results:
  Iterations:        2500
  Duration:          166714 ms
  Start GPU memory:  232.69 MB
  End GPU memory:    1182.69 MB
  Memory change:     950.00 MB
  Leak per context:  389.12 KiB
⚠️  LEAK CONFIRMED: ~389.12 KiB per optixDeviceContextCreate/Destroy cycle
Hi @andrei.ioan.barsan, welcome!
Your code snippet has a copyright notice. Do we have permission to copy it, and use it and modify it?
There might be a memory leak, but FWIW it might not be possible to demonstrate this using cudaMemGetInfo; as CUDA is doing cached allocations, and because the very test you’re running, along with anything else on your GPU (for example your OS & browser) running at the same time as your test might be causing VRAM fragmentation that leads to accumulated memory usage over time, and because cudaMemGetInfo may not be as accurate as you expect for a variety of reasons. If you search a bit, you will find many long conversations about this.
Do you have a use case where this potential memory usage would affect you? As far as I know for OptiX users, it’s relatively rare to use more that 1 OptiX context per process, and extremely rare to use more than a handful. We will, of course, investigate and fix any leaks, I’m just asking if this is a serious or high priority issue for you.
David.
Thank you for the quick response, David.
The snippet is fine to share, thanks for flagging! It is vanilla C++ I prepared to illustrate my problem and contains nothing proprietary; the copyright notice was just auto-added by my IDE. I have removed it now since it did not apply to the code to begin with.
I confirmed that nothing major was using the GPU on my end; this is a headless workstation without an active desktop environment. Just an idle X server taking up ~7 MiB.
I increased the number of iterations and managed to run the create/destroy loop until it crashed the process:
Iteration 62000: GPU = 23884.69 MB
OptiX error 7807 at waabi/sim/sensor_simulation/lidar_simulation/optix/optix_context_leak_repro.cpp:91
As you can imagine, this is not a critical issue on my end. As you said, it’s unusual to have multiple contexts, and I doubt there will ever be a true application requiring 1k contexts to be created and cleaned up. I just wanted someone to confirm my reasoning and to make sure I wasn’t missing something super obvious.
Got it, thank you for reporting this! We are investigating.
David.
