Purchased AGX Orin off ebay, how to test its genuine and fully functioning?
Hi all
I purchased my AGX Orin off ebay, it was sealed and unused and i got it for a very good price (£920). The seller had sold a couple and said it was from an failed robot project.
Anyway, so far the device seems completely legit but i want to be 100% certain.
  1. Is there a way to verify the serial number is legit
  2. Any tests you would recommend running to check all the internals of the device and make sure everything works as it should?
Any help would really be appreciated
Kind regards,
You may flash the system to Jetpack 6.0GA and try the stress test:
Jetson/L4T/TRT Customized Example - eLinux.org
And can run $ sudo tegrastats to check the system status.
