Verify JETSON AGX ORIN hardware
• Hardware Platform (Jetson)
• DeepStream Version 6.2
• JetPack Version (5.1)
• Issue Type( question)
• Requirement details( Identify and verify hardware)
Where can one get/read/identify the Hardware platform I am on? My case, specifically
for the JETSON AGX ORIN. Is there a file with the “JETSON AGX ORIN” or a command line command
I can run, or a built in NVIDIA environment variable, something else?
Moving to Jetson AGX Orin forum.
You can refer to Identifying the chip at runtime - Jetson & Embedded Systems / Jetson AGX Orin - NVIDIA Developer Forums
@kaycc Thanks. In your reply…
steven@development-orin:~$ cat /sys/firmware/devicetree/base/model
Jetson AGX Orin
