I took a reboot of the machine.
After that I have seen, neither monitor is working not ssh connectivity is working?
I also tried connecting with the USB but not able to connect.
Need assistance?
Thanks for visiting the NVIDIA Developer forums! Your topic will be best served in the Jetson category.
I will move this post over for visibility.
Cheers,
Tom
- If you want to check current status of the board, you could use below method to dump serial console log from the micro usb port (if this is NV devkit).
- Even after checking (1), it has chance that the only way to fix current situation is flashing the board with another x86 host PC+ sdkmanager. Thus, if you don’t want dump the log, you could also reflash the board directly.
