After i power on my jetson it shows bootloading and after that it sho
ws black screen
Attaching a video file to understand more clearly
Use the serial console to check the status of the board.
but the board is working fine
Yeah, it is fine, so share me the log. Any question to this?
We need a readable log but not a video here.
Which port are you connected on your Jetson?
This only indicates your cable setup might be wrong.
We connected our jetson to the Linux hot pc via miro usb port
Are you sure that micro usb cable has data line but not just a charging cable?
Could you check what is the log on your host PC dmesg when you plug this cable into it?
Also, just to clarify.
Are you using NV devkit or a custom board? Or you don’t know what I am asking here?
If you are uncertain of my question, please tell.
Hey , I am using Nvidia Jetson Orion AGX with Avermedia Carrier D315
Please check Avermedia datasheet if this D315 board’s micro usb port is really for UART console…
All the guidance we provided here is only for NVIDIA developer kit. If you are using custom boards, the the method we provided may not work on them.
Alright thanks
