putting the extern keyword in front of __constant__ memory doesn't throw an error
In attempting to have on global constant parameters structure for a project, I declared an extern constant structure. As I later learned, this is forbidden according to the CUDA C Programming Guide, but it doesn’t throw a compiler error, and instead will compiling, letting you read a structure now filled with zeros, which is probably some bad pointer access. It seems like this should probably throw an error.
I’m running nvcc release 4.2, V0.2.1221 on ubuntu 11.04.
