Continuing the discussion from Orin PWM output is not precise to the desired PWM in code:
hello:
I have encountered a similar problem. my kernel version is :
Linux tegra-ubuntu 5.10.120-rt70-tegra #1 SMP PREEMPT RT Fri Apr 18 16:29:22 CST 2025 aarch64 aarch64 aarch64 GNU/Linux
jetson linux version is L4T 35.4.1.
pwm clock is :
root@tegra-ubuntu:/sys/kernel/debug/clk/pwm1# cat /sys/kernel/debug/clk/pwm1/clk_parent
pllp_out0
root@tegra-ubuntu:/sys/kernel/debug/clk/pwm1# cat /sys/kernel/debug/clk/pwm1/clk_possible_parents
pllp_out0 clk_32k clk_m
I set param is:
but the tested PWM waveform is as follows:
Single cycle error is 317ns, Single high-level time error is 35ns.
Is there any other way to optimize it?
