PWM support in AGX Orin
We are using Jetson AGX Orin SOM for custom carrier board and we are using the GPIO27 pin for PWM generation on the AGX Orin. What is the maximum PWM frequency that can be set for this pin? Is it possible to set different individual frequencies for all 4 PWM pins separately?
Hi saran.sridhar,
The available PWM frequncy is 1.5 Hz till 1.59 MHz while pllp_out0 as source clock.
Yes, you can configure different PWM frequency/duty cycle for specific PWM channel.
