Jetson AGX Orin head pins
How many GPIO pins and PWM pins does Jetson AGX Orin have within its 40 header pins?
You can see this information in Jetson AGX Orin Developer Kit Carrier Board Specification (Jetson_AGX_Orin_DevKit_Carrier_Board_Specification_SP-10900-001_v1.1.pdf) pag 32
Manuel Leiva
Embedded SW Engineer at RidgeRun
Contact us: support@ridgerun.com
Developers wiki: https://developer.ridgerun.com
Website: www.ridgerun.com
May I know what is the HIGH output voltage from the GPIO pins?
Please see: GPIO Output HIGH voltage
Manuel Leiva
Do you know if the GPIO pins can be programmed or configured as “High Z (impedance)” instead of only “HIGH” and “LOW” output?
To be updated at GPIO configuration optoins - Jetson & Embedded Systems / Jetson AGX Orin - NVIDIA Developer Forums
