May I know what is the voltage level of HIGH from the GPIO pins in those 40-pins header in Jetson AGX Orin?
Hi @jin.li9.civ
You can check this document the 40-Pin Expansion Header section, it states the following:
Regards,
Andres
Embedded SW Engineer at RidgeRun
Contact us: support@ridgerun.com
Developers wiki: https://developer.ridgerun.com/
Website: www.ridgerun.com
Do you know if the GPIO pins can be programmed or configured as “High Z (impedance)” instead of only “HIGH” and “LOW” output?
To be updated at GPIO configuration optoins - Jetson & Embedded Systems / Jetson AGX Orin - NVIDIA Developer Forums
