GPIO Connector
I want a 40 pin female to female connector which I can connect to my Jetson AGX Orin developer kit.
All 40 pin connectors available online have a notch at the end which will not fit in the Jetson AGX Orin developer kit.
Can you suggest a 40 pin connector? Thanks!
Hi, we don’t have recommendation on this. The 40-pin header is a general pin header which part number is Wieson G2100CE04C-009-H. You can check with vendor for the mated one.
