May I know what is the voltage level of HIGH from the GPIO pins in those 40-pins header in Jetson AGX Orin?
I am not sure about the output voltage, but maybe this can help, based on the Jetson AGX Orin Series Pinmux (Jetson_AGX_Orin_Series_Pinmux_Config_Template_1.9.xlsm), Most of the outputs indicate 1.8 IO Block Voltage,
Check the document to see an specific GPIO
Embedded SW Engineer at RidgeRun
Contact us: support@ridgerun.com
Developers wiki: https://developer.ridgerun.com
Website: www.ridgerun.com
Does this document for Jetson nano also apply to the Orin NX 40-pin expansion header?
Yes, the 40-pin header is same.
