rlgpu ❯ python train.py --task Cartpole
Importing module 'gym_37' (/home/lqk/downloads/IsaacGym_Preview_2_Package/isaacgym/python/isaacgym/_bindings/linux-x86_64/gym_37.so)
Setting GYM_USD_PLUG_INFO_PATH to /home/lqk/downloads/IsaacGym_Preview_2_Package/isaacgym/python/isaacgym/_bindings/linux-x86_64/usd/plugInfo.json
PyTorch version 1.8.1
Device count 1
/home/lqk/downloads/IsaacGym_Preview_2_Package/isaacgym/python/isaacgym/_bindings/src/gymtorch
Using /home/lqk/.cache/torch_extensions as PyTorch extensions root...
Emitting ninja build file /home/lqk/.cache/torch_extensions/gymtorch/build.ninja...
Building extension module gymtorch...
Using envvar MAX_JOBS (10) as the number of workers...
ninja: no work to do.
Loading extension module gymtorch...
Importing module 'rlgpu_37' (/home/lqk/downloads/IsaacGym_Preview_2_Package/isaacgym/python/isaacgym/_bindings/linux-x86_64/rlgpu_37.so)
Setting seed: 8963
Python
Not connected to PVD
+++ Using GPU PhysX
PxgCudaDeviceMemoryAllocator fail to allocate memory 67108864 bytes!! Result = 2
PxgCudaDeviceMemoryAllocator fail to allocate memory 134217728 bytes!! Result = 2
PxgCudaDeviceMemoryAllocator fail to allocate memory 402653184 bytes!! Result = 2
PxgCudaDeviceMemoryAllocator fail to allocate memory 100663296 bytes!! Result = 2
Physics Engine: PhysX
Physics Device: cuda:0
GPU Pipeline: enabled
^C^\[1] 19158 quit (core dumped) python train.py --task Cartpole
I have checked vulkaninfo and used export VK_ICD_FILENAMES=/usr/share/vulkan/icd.d/nvidia_icd.json.
The joint_monkey example works fine with CPU. The graphics card driver is 470.63.01.
But I am using a pretty old graphics card: GTX750, not sure if this caused the problem.
Thanks to kind people!
