Hi, I want use object tracking and detection in my python app, and have a problem with computing resources. When used detection only fps was near 100 on MobileNet inference, but i added dlib or mosse(pyhton) tracking fps became equal 1. What am I doing wrong on my Jetson Xavier?
This may be related to the dlib implementation.
You can get some profiling data for your program first.
nvprof python3 [app.py]
nvprof python3 my-detection.py
jetson.inference.__init__.py
jetson.inference -- initializing Python 3.6 bindings...
jetson.inference -- registering module types...
jetson.inference -- done registering module types
jetson.inference -- done Python 3.6 binding initialization
jetson.utils.__init__.py
jetson.utils -- initializing Python 3.6 bindings...
jetson.utils -- registering module functions...
jetson.utils -- done registering module functions
jetson.utils -- registering module types...
jetson.utils -- done registering module types
jetson.utils -- done Python 3.6 binding initialization
jetson.inference -- PyTensorNet_New()
jetson.inference -- PyDetectNet_Init()
jetson.inference -- detectNet loading build-in network 'ssd-inception-v2'
detectNet -- loading detection network model from:
-- model networks/SSD-Inception-v2/ssd_inception_v2_coco.uff
-- input_blob 'Input'
-- output_blob 'NMS'
-- output_count 'NMS_1'
-- class_labels networks/SSD-Inception-v2/ssd_coco_labels.txt
-- threshold 0.400000
-- batch_size 1
[TRT] TensorRT version 6.0.1
[TRT] loading NVIDIA plugins...
[TRT] Plugin Creator registration succeeded - GridAnchor_TRT
[TRT] Plugin Creator registration succeeded - GridAnchorRect_TRT
[TRT] Plugin Creator registration succeeded - NMS_TRT
[TRT] Plugin Creator registration succeeded - Reorg_TRT
[TRT] Plugin Creator registration succeeded - Region_TRT
[TRT] Plugin Creator registration succeeded - Clip_TRT
[TRT] Plugin Creator registration succeeded - LReLU_TRT
[TRT] Plugin Creator registration succeeded - PriorBox_TRT
[TRT] Plugin Creator registration succeeded - Normalize_TRT
[TRT] Plugin Creator registration succeeded - RPROI_TRT
[TRT] Plugin Creator registration succeeded - BatchedNMS_TRT
[TRT] Could not register plugin creator: FlattenConcat_TRT in namespace:
[TRT] completed loading NVIDIA plugins.
[TRT] detected model format - UFF (extension '.uff')
[TRT] desired precision specified for GPU: FASTEST
[TRT] requested fasted precision for device GPU without providing valid calibrator, disabling INT8
==9741== NVPROF is profiling process 9741, command: python3 my-detection.py
==9741== Warning: Insufficient privileges to start the profiling session. Use root privileges
==9741== Profiling application: python3 my-detection.py
==9741== Profiling result:
No kernels were profiled.
No API activities were profiled.
Try exec sudo and from root, result:
nvprof: command not found
Please update to this command:
/usr/local/cuda-10.0/bin/nvprof python3 [app.py] -o data.nvvp
And share the data.nvvp with us.
