Excuse me, I encountered with a problem when I tried to run DenseFusion-Pytorch1.0.
And failed with:
THCudaCheck FAIL file=/opt/conda/conda-bld/pytorch_1544174967633/work/aten/src/THC/THCGeneral.cpp line=405 error=11 : invalid argument
/home/lr/anaconda3/envs/df2/lib/python3.6/site-packages/torch/nn/functional.py:2351: UserWarning: nn.functional.upsample is deprecated. Use nn.functional.interpolate instead.
warnings.warn("nn.functional.upsample is deprecated. Use nn.functional.interpolate instead.")
/home/lr/anaconda3/envs/df2/lib/python3.6/site-packages/torch/nn/functional.py:2423: UserWarning: Default upsampling behavior when mode=bilinear is changed to align_corners=False since 0.4.0. Please specify align_corners=True if the old behavior is desired. See the documentation of nn.Upsample for details.
"See the documentation of nn.Upsample for details.".format(mode))
/home/lr/anaconda3/envs/df2/lib/python3.6/site-packages/torch/nn/modules/upsampling.py:129: UserWarning: nn.Upsample is deprecated. Use nn.functional.interpolate instead.
warnings.warn("nn.{} is deprecated. Use nn.functional.interpolate instead.".format(self.name))
/home/lr/anaconda3/envs/df2/lib/python3.6/site-packages/torch/nn/modules/container.py:92: UserWarning: Implicit dimension choice for log_softmax has been deprecated. Change the call to include dim=X as an argument.
input = module(input)
File "./tools/train.py", line 237, in <module>
main()
File "./tools/train.py", line 140, in main
loss, dis, new_points, new_target = criterion(pred_r, pred_t, pred_c, target, model_points, idx, points, opt.w, opt.refine_start)
File "/home/lr/anaconda3/envs/df2/lib/python3.6/site-packages/torch/nn/modules/module.py", line 489, in __call__
result = self.forward(*input, **kwargs)
File "/media/lr/OLDFACE BRO/DenseFusion-Pytorch-1.0/lib/loss.py", line 83, in forward
return loss_calculation(pred_r, pred_t, pred_c, target, model_points, idx, points, w, refine, self.num_pt_mesh, self.sym_list)
File "/media/lr/OLDFACE BRO/DenseFusion-Pytorch-1.0/lib/loss.py", line 38, in loss_calculation
pred = torch.add(torch.bmm(model_points, base), points + pred_t)
RuntimeError: cublas runtime error : the GPU program failed to execute at /opt/conda/conda-bld/pytorch_1544174967633/work/aten/src/THC/THCBlas.cu:441
nvcc -V
Copyright (c) 2005-2017 NVIDIA Corporation
Built on Fri_Sep__1_21:08:03_CDT_2017
Cuda compilation tools, release 9.0, V9.0.176
cat /usr/local/cuda/include/cudnn.h | grep CUDNN_MAJOR -A 2
#define CUDNN_MAJOR 7
#define CUDNN_MINOR 4
#define CUDNN_PATCHLEVEL 1
#define CUDNN_VERSION (CUDNN_MAJOR * 1000 + CUDNN_MINOR * 100 + CUDNN_PATCHLEVEL)
#include "driver_types.h"
nvidia-smi
Sat Oct 8 15:05:50 2022
| NVIDIA-SMI 515.65.01 Driver Version: 515.65.01 CUDA Version: 11.7 |
| | | MIG M. |
| 0 NVIDIA GeForce ... Off | 00000000:01:00.0 Off | N/A |
| 36% 32C P8 11W / 125W | 5MiB / 6144MiB | 0% Default |
| | | N/A |
| Processes: |
| ID ID Usage |
| 0 N/A N/A 1299 G /usr/lib/xorg/Xorg 4MiB |
How can I solve ‘RuntimeError: cublas runtime error : the GPU program failed to execute at /opt/conda/conda-bld/pytorch_1544174967633/work/aten/src/THC/THCBlas.cu:441’?
Please help me out…
Thank you guys…
