What is the Quadro FX 1800 computing capability?
I cannot find any info because it is a new card.
@NVIDIA: Could you put Computing Capability on the Specification page of your GPUs, please?
I am pretty sure it is G94 based (like the 9600GT), so 1.1 capability
Amen. We shouldn’t have to wait until the next CUDA programming guide comes out to get a definitive reference.
yeah, agreed. let me poke people
I just installed the card in place the old Quadro FX 3400 on
ell Precision 670, Intel Xeon 3.00Ghz, RAM 2GB, 64-bit, Windows 7
Here is what deviceQuery.exe generated:
CUDA Device Query (Runtime API) version (CUDART static linking)
There is 1 device supporting CUDA
Device 0: “Quadro FX 1800”
CUDA Capability Major revision number: 1
CUDA Capability Minor revision number: 1
Total amount of global memory: 805306368 bytes
Number of multiprocessors: 8
Number of cores: 64
Total amount of constant memory: 65536 bytes
Total amount of shared memory per block: 16384 bytes
Total number of registers available per block: 8192
Warp size: 32
Maximum number of threads per block: 512
Maximum sizes of each dimension of a block: 512 x 512 x 64
Maximum sizes of each dimension of a grid: 65535 x 65535 x 1
Maximum memory pitch: 262144 bytes
Texture alignment: 256 bytes
Clock rate: 1.38 GHz
Concurrent copy and execution: Yes
Run time limit on kernels: No
Integrated: No
Support host page-locked memory mapping: No
Compute mode: Default (multiple host threads can use this device simultaneously)
Here is what bandwidthtest generated:
Running on…
device 0:Quadro FX 1800
Quick Mode
Host to Device Bandwidth for Pageable memory
Transfer Size (Bytes) Bandwidth(MB/s)
33554432 1031.3
Quick Mode
Device to Host Bandwidth for Pageable memory
33554432 779.6
Quick Mode
Device to Device Bandwidth
33554432 31702.4
can you also run bandwidthTest --memory=pinned? That will come closer to theoretical PCI-Express maximum.
here is what I got. What do you think for these results up to now?
Running on…
Quick Mode
Host to Device Bandwidth for Pinned memory
33554432 2427.4
Quick Mode
Device to Host Bandwidth for Pinned memory
33554432 2691.6
Quick Mode
33554432 31720.7
This is definitely below average for a PCI-Express 1.0 connection, but motherboards with different chipsets show a surprising range of bandwidths in this test.
What is your theoretical maximum for PCIe 1.0?
I’ve lost access to my PCI-Express 1.0 motherboard (finally died last week). My 8800 GTX in a Phenom II system (a PCI-e 1.0 card in a high-end PCI-e 2.0 motherboard) gets 2.6 GB/sec Host-to-Device and 3.1 GB/sec Device-to-Host. Other systems I’ve seen reported in the forums get > 3 GB/sec in both directions. (4 is the theoretical max, but I don’t think I’ve ever seen anyone get higher than 3.5 in practice.)
For comparison, a PCI-e 2.0 card in an Phenom system (PCI-e 2.0 motherboard) gets 5.3 H->D and 5.0 D->H, and in a Core i7 system (also PCI-e 2.0 motherboard) gets 5.8 and 5.6 GB/sec.
Here are some results for a pretty poor performing PCI-e 1.0 system (my development machine which is a Shuttle Flex-ATX G31 chipset board with a Core 2 Quad Q6600, 2Gb of DDR2-667 ram and a GF9500GT) which gives some idea of what below average looks like…
A multiple clock frequencies that can be quoted for any card: core clock, shader clock, and memory clock.
Which one the deviceProp.clockRate is returning?
should be shader clock.
