I am Having issues with my Quadro p4000 power state
My system is running 20.04 ubuntu server headless with 440.64 driver and cuda 10.2 with Nvidia docker
With nothing running on the gpu the p state always sits a p0 and will not clock down so always at about 30w
Please make sure nvidia-persistenced is started on boot an is continuously running.
Check that and it’s running and from start up
Please run nvidia-bug-report.sh as root and attach the resulting nvidia-bug-report.log.gz file to your post. You will have to rename the file ending to something else since the forum software doesn’t accept .gz files (nifty!).
nvidia-bug-report.log.c (284.3 KB) renamed the end .c
Nothing really obvious. Does the system have any other pcie slots you can mount the card? it’s currently sitting behind a pcie switch together with an SAS raid controller, don’t know if this has any influence on the card’s power management. Another thing worth a shot would be to enable the (depreciated) persistence mode using nvidia-smi.
ok thanks that’s the only 16x sized sort I have i will give persistence a goo might just be motherboard lay out
interestingly if I try and do gpu rest I get this
nvidia-smi --gpu-reset
GPU 00000000:05:00.0 is currently in use by another process.
1 device is currently being used by one or more other processes (e.g., Fabric Manager, CUDA application, graphics application such as an X server, or a monitoring application such as another instance of nvidia-smi). Please first kill all processes using this device and all compute applications running in the system.
root@hills-server:~# nvidia-smi
Tue Jun 23 09:58:00 2020
| NVIDIA-SMI 440.64 Driver Version: 440.64 CUDA Version: 10.2 |
| 0 Quadro P4000 On | 00000000:05:00.0 Off | N/A |
| 55% 60C P0 30W / 105W | 12MiB / 8119MiB | 0% Default |
| Processes: GPU Memory |
| GPU PID Type Process name Usage |
| No running processes found |
Most likely nvidia-persistenced, it gets filtered from the process list.
Ok how could I stop fix or test that ?
sudo systemctl stop nvidia-persistenced
I have move to a different motherboard with bios set to default a clean ssd with clean ubuntu server 20.04 install then did
sudo apt update
sudo apt upgrade
sudo add-apt-repository ppa:graphics-drivers/ppa
sudo apt install nvidia-headless-440 nvidia-utils-440
if I then do Nvidia-smi is still get p0
but now got it working by doing
Nvidia-smi -pm -1
sudo systemctl restart nvidia-persistenced
so went back to my old install and did the same but on this new motherboard and it works spot on so must be a motherboard issue thanks
for your help
