Quadro P1000 graphics card DOES NOT recognize Ultrawide monitor?
Well I have a PC with Linux Pop OS! installed with Nvidia Quadro P1000 graphics card and bought an Ultrawide monitor, I would like to know if the Quadro P1000 recognizes Ultrawide monitors when I check that the system does not recognize this monitor pattern
Would you know how to help me with this problem?
Are you saying that it does not recognise the monitor at all, or that you can’t select an ultrawide resolution in your display settings?
Are you using a high-quality display cable, e.g. if you’re using DisplayPort then is the cable VESA certified?
Please run nvidia-bug-report.sh as root and attach the resulting nvidia-bug-report.log.gz file to your post.
