HP laptop with Ubuntu 22.04 Quadro T1000 does not recognize HDMI monitor
Hi. I would really appreciate if you could help me.
ubuntu 22.04 does not recognize my monitor with HDMI.
The HDMI cable and the monitor both work fine with another laptop.
the laptop is HP with nvidia Quadro T1000 graphic.
I am using nvidia driver metapackage from nvidia-driver-535.
When I bought the laptop it had a windows and HDMI worked correctly but with ubuntu it does not.
I am a fresh ubuntu user, if any new information is needed, please tell me what to type in terminal. thanks.
nvidia-bug-report.log.gz (366.9 KB)
xrandr --verbose
Screen 0: minimum 8 x 8, current 1920 x 1080, maximum 32767 x 32767
DP-0 disconnected (normal left inverted right x axis y axis)
Identifier: 0x21c
Timestamp: 79027318
Subpixel: unknown
Clones:
CRTCs: 0 1 2 3
Transform: 1.000000 0.000000 0.000000
0.000000 1.000000 0.000000
0.000000 0.000000 1.000000
filter:
CTM: 0 1 0 0 0 0 0 0 0 1 0 0 0 0 0 0
0 1
CscMatrix: 65536 0 0 0 0 65536 0 0 0 0 65536 0
BorderDimensions: 4
supported: 4
Border: 0 0 0 0
range: (0, 65535)
SignalFormat: DisplayPort
supported: DisplayPort
ConnectorType: DisplayPort
ConnectorNumber: 0
_ConnectorLocation: 0
non-desktop: 0
supported: 0, 1
HDMI-0 disconnected (normal left inverted right x axis y axis)
Identifier: 0x21d
Timestamp: 79027318
Subpixel: unknown
Clones:
CRTCs: 0 1 2 3
filter:
0 1
BorderDimensions: 4
supported: 4
Border: 0 0 0 0
range: (0, 65535)
SignalFormat: TMDS
supported: TMDS
ConnectorType: HDMI
ConnectorNumber: 2
_ConnectorLocation: 2
non-desktop: 0
supported: 0, 1
DP-1 connected primary 1920x1080+0+0 (0x21f) normal (normal left inverted right x axis y axis) 344mm x 193mm
Identifier: 0x21e
Timestamp: 79027318
Subpixel: unknown
Gamma: 1.0:1.0:1.0
Brightness: 1.0
Clones:
CRTC: 0
CRTCs: 0 1 2 3
filter:
_MUTTER_PRESENTATION_OUTPUT: 0
CTM: -26997632 0 1461765 0 9823659 -2147483648 1354350 -2147483648 4555181 1 6089007 0 661164 -2147483648 3539183 -2147483648
17386285 1
CscMatrix: 65124 22 -149 0 -20 65605 92 0 -10 -54 65801 0
Backlight: 99
range: (0, 100)
EDID:
00ffffffffffff000daef61500000000
111b01049522137802ee95a3544c9926
0f505400000001010101010101010101
010101010101b43b804a713834403020
680058c11000001ab43b804a71386a42
3020680058c11000001a000000000000
00000000000000000000000000000002
000c26ff143cc8120f34c80000000041
BorderDimensions: 4
supported: 4
Border: 0 0 0 0
range: (0, 65535)
ConnectorType: Panel
ConnectorNumber: 3
_ConnectorLocation: 3
non-desktop: 0
supported: 0, 1
1920x1080 (0x21f) 152.840MHz +HSync -VSync *current +preferred
h: width 1920 start 1968 end 2000 total 2250 skew 0 clock 67.93KHz
v: height 1080 start 1086 end 1094 total 1132 clock 60.01Hz
1920x1080 (0x220) 152.840MHz +HSync -VSync
v: height 1080 start 1086 end 1094 total 1698 clock 40.01Hz
DP-2 disconnected (normal left inverted right x axis y axis)
Identifier: 0x221
Timestamp: 79027318
Subpixel: unknown
Clones:
CRTCs: 0 1 2 3
filter:
0 1
BorderDimensions: 4
supported: 4
Border: 0 0 0 0
range: (0, 65535)
ConnectorNumber: 4
_ConnectorLocation: 4
non-desktop: 0
supported: 0, 1
nvidia-smi
Thu Sep 21 19:06:25 2023
| NVIDIA-SMI 535.86.05 Driver Version: 535.86.05 CUDA Version: 12.2 |
| GPU Name Persistence-M | Bus-Id Disp.A | Volatile Uncorr. ECC |
| | | MIG M. |
| 0 Quadro T1000 Off | 00000000:01:00.0 On | N/A |
| N/A 47C P8 3W / 50W | 586MiB / 4096MiB | 14% Default |
| | | N/A |
| Processes: |
| ID ID Usage |
| 0 N/A N/A 1755 G /usr/lib/xorg/Xorg 292MiB |
| 0 N/A N/A 1977 G /usr/bin/gnome-shell 65MiB |
| 0 N/A N/A 6416 G …3500163,17141993852923215813,262144 92MiB |
| 0 N/A N/A 38195 G …sion,SpareRendererForSitePerProcess 31MiB |
| 0 N/A N/A 51593 G …irefox/3131/usr/lib/firefox/firefox 48MiB |
| 0 N/A N/A 70382 G telegram-desktop 1MiB |
| 0 N/A N/A 72537 G …allation/ubuntu12_64/steamwebhelper 25MiB |
Could you please share how you solved the issue
Same issue here, did you succeed ?
HDMI not working is likely a driver issue. Try sudo prime-select nvidia and reboot. Also, turn off Secure Boot in BIOS.
