I am using a quadro RTX 6000, and I have a problem with GENERATIVE AI.
I met at least 2 instances where my card could not handle things that other cards with less VRAM would do.
My card has 24GB vram, yet I am not able to handle bf16 and not able to run some scripts.
I am specifically using ComfyUI program.
Many models used are BF16 or need BF16, for example the “PULID FLUX” model, and the latest AI video gen model “MOCHI”.
I talked with the creator of ComfyUI and he suggested to modify the comfyUI code to allow for float16, so we commented a line of code and allowed the program to allow float 16:
#supported_inference_dtypes = [torch.bfloat16, torch.float32]
supported_inference_dtypes = [torch.float16, torch.bfloat16, torch.float32]
The result was that comfyUI was able to run some bf16 models but … in float16 mode? the result was a corrupted video output (from the generation process), it was a noise video.
__
Maybe the card failing to handle bf16 so it is turning to f32 → which makes the generation ultra slow and not efficient → ultimately the card would fail at the generation whereas lower vram card that can handle bf16 would not fail.
Which is a shame isnt it?
__
I need an upgrade or driver or workaround that can make my card work with BF16? Can you do that NVIDIA please?
I mean this is not bad card. And it is still used. It has 24GB vram after all. It deserves to get an update to handle this problem.
__
I also got other errors such as:
RuntimeError: expected scalar type Half but found BFloat16
Please help.
Btw, I don’t know if this is the right place or not.
Can NVIDIA help me find a quick solution please. I need this. I need to handle BF16 models.
