Question About Access to VST Web Client Source
I have been exploring the VST web client that NVIDIA provides, and I noticed that the package only contains the compiled build outputs (for example, static/js/main.[hash].js). It doesn’t seem to include the original src/ source files.
I was wondering:
  • Is the source code (src) normally provided somewhere, or is the distribution intentionally limited to build artifacts?
  • I’d like to make some small modifications to the client, but working with only the minified build files is quite difficult.
  • If the source is not available, is there perhaps a recommended way to customize or extend the client (for example through configuration, APIs, or another supported method)?
I may be missing something obvious, but I just wanted to confirm whether access to the source is possible, or if there’s an alternative approach I should take.
Thank you in advance for any guidance.
Best regards,
YoungSeok
What application are you running? Are you working on Jetson or dGPU?
jetson, but if possible dGPU
The VST web client source code isn’t public yet. It is only for demo, maybe you need to develop your own UI.
There is no update from you for a period, assuming this is not an issue anymore. Hence we are closing this topic. If need further support, please open a new one. Thanks.
