When following the JPS quickstart guide:
https://docs.nvidia.com/jetson/jps/setup/quick-start.html#installation
I run
sudo apt update
sudo apt install nvidia-jetson-services
But when I go to /opt/nvidia/jetson/services
there is no /vst/ folder
Just as well when I run:
sudo systemctl start jetson-vst
It returns: Failed to start jetson-vst.service: Unit jetson-vst.service not found.
Note that I have Jetpack 6.0 installed with DeepStream.
I am trying to run the AI NVR sample app.
Hi @nickjalali , can you confirm the following:
You are using JP 6.0 GA release, which is BSP 36.3 version.
$ cat /etc/nv_tegra_release
# R36 (release), REVISION: 3.0, GCID: 36191598, BOARD: generic, EABI: aarch64, DATE: Mon May 6 17:34:21 UTC 2024
# KERNEL_VARIANT: oot
TARGET_USERSPACE_LIB_DIR=nvidia
TARGET_USERSPACE_LIB_DIR_PATH=usr/lib/aarch64-linux-gnu/nvidia
The package installation was successful with no errors
$ dpkg -l | grep nvidia-jetson-services
ii nvidia-jetson-services 1.1.0 arm64 NVIDIA Jetson Package
The contents of /opt/nvidia/jetson/services, which should include vst.
$ ls /opt/nvidia/jetson/services
firewall gpumonitoring ingress iotgateway monitoring networking redis storage sysmonitoring vst
You will not be able to start jetson-vst service unless vst is installed successfully (as above).
@nickjalali
If you use SDkmanger to download and install platform services then you will find them as
t-tech@ubuntu:/opt/nvidia/jetson/services$ ls
From your information, what I see the platform services have not been downloaded and installed yet.
Which Jetson device do you have?
Is it possible to show the what comes on the terminal when you run
Thanks for the response.
Results from following your suggestions:
1.
# R36 (release), REVISION: 2.0, GCID: 34956989, BOARD: generic, EABI: aarch64, DATE: Thu Nov 30 19:03:58 UTC 2023
ii nvidia-jetson-services 1.0 arm64 NVIDIA Jetson Package
firewall ingress monitoring redis sysmonitoring
gpumonitoring iotgateway networking storage
It seems that I am using BSP 36.2 , does this explain why vst is not installing, or is not installed? Do I have to wipe and reflash my Jetson using SDKM? I am using Jetson Orin NX 16.
Hi @nickjalali - yes, thatās the reason, as VST was not part of debian in the earlier DP (36.2) release. You need to upgrade your Jetson to 36.3 BSP (via SDKM or manual flashing).
Thanks. I updated my SDK manager to 2.1.0.11682 on my host Linux device, but the most recent version seems to be Jetpack6.0 (Rev. 2) Linux for Jetson Orin NX Modules.
This is 36.2 correct? Is 36.3 not available on SDKM? The quickstart guide says you can install 36.3 using SDKM.
Jetpack6.0 (Rev. 2) is GA version. It will install 36.3 BSP (Jetson Linux). Just follow the install guide and choose Jetson Platform Services, so you get everything you need.
Ok, I will proceed with installing via SDKM. Thank you very much for all the help!
system
Closed
July 19, 2024, 5:51pm
9
