Metropolis Microservices for Jetson
I have started with Metropolis Microservices for Jetson and wanted to install the application bundle on Jetson AGX Orin, I am following the following Part 2: Hardware and Software Installation of AI-NVR | NVIDIA On-Demand and the following are the my hardware and software stacks.
Hardware: Jetson AGX Orin.
Software:
Jetpack: Version: 6.0-b52
deepstream-app version 6.4.0
DeepStreamSDK 6.4.0
While following the above video, I did not understand why we had to use the below command
sudo apt-key adv --fetch-keys http://l4t-repo.nvidia.com/jetosn-ota-internal.key
and further adding below two lines in the nvidia@ubuntu:/etc/apt/sources.list.d$ sudo nano nvidia-l4t-apt-source.list
deb http://l4t-repo.nvidia.com/common r36.2 main
deb http://l4t-repo.nvidia.com/t234 r36.2 main
when I did sudo apt update, I got the following errors
nvidia@ubuntu:/etc/apt/sources.list.d$ sudo apt update
Hit:1 https://download.docker.com/linux/ubuntu jammy InRelease
Hit:2 https://repo.download.nvidia.com/jetson/common r36.2 InRelease
Hit:3 https://repo.download.nvidia.com/jetson/t234 r36.2 InRelease
Hit:4 http://ports.ubuntu.com/ubuntu-ports jammy InRelease
Get:5 http://ports.ubuntu.com/ubuntu-ports jammy-updates InRelease [119 kB]
Get:6 http://l4t-repo.nvidia.com/common r36.2 InRelease [2,561 B]
Hit:7 http://ports.ubuntu.com/ubuntu-ports jammy-backports InRelease
Get:8 http://l4t-repo.nvidia.com/t234 r36.2 InRelease [2,558 B]
Err:6 http://l4t-repo.nvidia.com/common r36.2 InRelease
The following signatures couldn't be verified because the public key is not available:
NO_PUBKEY 6E3279734C41A135
Get:9 http://ports.ubuntu.com/ubuntu-ports jammy-security InRelease [110 kB]
Err:8 http://l4t-repo.nvidia.com/t234 r36.2 InRelease
Reading package lists... Done
W: GPG error: http://l4t-repo.nvidia.com/common r36.2 InRelease: The following
signatures couldn't be verified because the public key is not available: NO_PUBKEY 6E3279734C41A135
E: The repository 'http://l4t-repo.nvidia.com/common r36.2 InRelease' is not signed.
N: Updating from such a repository can't be done securely, and is therefore disabled by default.
N: See apt-secure(8) manpage for repository creation and user configuration details.
W: GPG error: http://l4t-repo.nvidia.com/t234 r36.2 InRelease: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 6E3279734C41A135
E: The repository 'http://l4t-repo.nvidia.com/t234 r36.2 InRelease' is not signed.
can anyone help me to understand the procedure and resolve the issues? Thanks.
I have resolved the errors by copying the URL : http://l4t-repo.nvidia.com/jetson-ota-internal.key from here : http://l4t-repo.nvidia.com/
and then simply use the following command again
sudo apt-key adv --fetch-keys http://l4t-repo.nvidia.com/jetson-ota-internal.key
then
sudo apt update
does not show any errors.
but still did not understand why we had to do this.
@DaneLLL , Can you help to answer the question?
Do you flash AGX Orin developer kit through SDKManager? You should be able to execute sudo apt update without the additional steps, if the system image is installed through SDKManager.
Yes, I flashed the AGX Orin developer kit through SDKMangaer. Do you mean to say If flash the device through SDKManger, I do not need to follow the below steps?
step 1:
step 2:
Add the following two lines to /etc/apt/sources.list.
Simply, do sudo apt update?
Yes, we expect the file is present:
/etc/apt/sources.list.d/nvidia-l4t-apt-source.list
And you can run sudo apt update directly.
The file
do exist but it has this
# SPDX-FileCopyrightText: Copyright (c) 2019-2021 NVIDIA CORPORATION &
AFFILIATES. All rights reserved.
# SPDX-License-Identifier: LicenseRef-NvidiaProprietary
# NVIDIA CORPORATION, its affiliates and licensors retain all intellectual
# property and proprietary rights in and to this material, related
# documentation and any modifications thereto. Any use, reproduction,
# disclosure or distribution of this material and related documentation
# without an express license agreement from NVIDIA CORPORATION or
# its affiliates is strictly prohibited.
deb https://repo.download.nvidia.com/jetson/common r36.2 main
deb https://repo.download.nvidia.com/jetson/t234 r36.2 main
but the following lines are missing in the file
Please share where you see http://l4t-repo.nvidia.com. The correct website should be https://repo.download.nvidia.com. Would like to know where you see the link.
@DaneLLL Thanks for your patience. I think so you got confused. In my last reply, I said the file /etc/apt/sources.list.d/nvidia-l4t-apt-source.list exists and the following lines also exist
but as per the video(refer to my first thread ), do I need to add the following lines?
I only see this snapshot in the video. Where you see the link: http://l4t-repo.nvidia.com?
@kesong, I think so they removed that part from the video. I am pretty sure those steps were there. Anyways Thanks for your response.
