Hi.
I’ve been looking through the forum, and only found the carriers and adapters from ConnectTech for the AGX Xavier.
I’d like to know if there is some sort of casing like the Geekworms’ for the Jetson-Nano, but for the Xavier.
Thank you.
Hi.
Thank you.
Hi rsapiain, aside from IP-rated ruggedized enclosure for the Xavier module from ConnectTech, someone created a 3D-printed cover for the Xavier devkit’s base here: [url]https://www.youmagine.com/designs/jetson-xavier-base-cover[/url]
Thank you.
Seems like I’ll have to later start tinkering with a 3D printer to make some props for my use case.
