I have 2 HP Gen8 servers each identical with the same 2 port IB cards, I’ve got opensm running on each (two instances on each server, both specifying a particular GUID) Both ports on both servers are connected to an unmanaged switch (the same error occurs when they are connected directly to each other). One port works fine, the other (port 2) gives the following error on both servers. Does anyone know what this means? Firmware has been updated on the cards to the same level, openSM is at the most recent level and I’ve tried switching cables. Thanks for the input.
Entering DISCOVERING state
osm_vendor_bind: Binding to port 0x26be05fffe94faa2
osm_opensm_bind: Setting IS_SM on port 0x26be05fffe94faa2
vl15_send_mad: ERR 3E03: MAD send failed (IB_INVALID_AV_HANDLE)
