Hello. Thank you for your work. I would like to see an example (if any) where you can run tracking without neural networks. That is, where you can select the desired object and check the quality of tracking (like classic OpenCV trainers or solutions based on Siamese networks). I couldn’t find a similar example.
**• Hardware Platform Jetson **
• DeepStream Version 6.0
• JetPack Version 4.6
• Issue Type questions
