I just need some confirmation that I understand the doc correctly.
For FP32/FP16/INT8 deployment, I have 2 options: using
.etltor.enginefile..engineis hardware specific so it need to be generated on the deployment hardware (i.e., a Jetson), this.enginecan either be generated usingtlt-converter(for Jetson) or Deepstream will generate a.enginefile on the fly using the provided.etltfile. My question is: is there any difference in the model’s performance (speed & accuracy( between usingtlt-convertervs. letting Deepstream generate a.enginefile on the fly? -
For INT8 deployment, regarding the calibration cache file. What is its purpose? What is the general advice on creating this file (e.g., the number of images to use, using train or val set or both)?
I’m aware that the number of images to be used for calibration need the be at least
batch_size * batches, what happens if the number of images exceed that value? How should I setbatch_sizeandbatchesto get optimal performance from the model? -
Regarding
max_batch_sizewhen create the.enginefile usingtlt-converter, in any Deepstream model config file, there is abatch-size(=number of source elements in the pipeline) parameter, what is the relationship between these two parameters? My understanding isbatch-size<=max_batch_size, is that correct? -
When using
tlt-converter, theinput_dimensionsneed to match the inferredinput_dimensionsused duringtlt-export. When deploy with Deepstream, in the model config file, there is a parameter calleduff-input-dims, this value need to match theinput_dimensions, is that correct?
