I installed CUDA 10.1, my visual studio is 2015 version.
graphic card is GT650.
after I opened CUDA 10.1 and checked value of cudaStatus,
an error has occured as cudaErrorNoKernelImageForDevice(209).
this problem is as below.
// Check for any errors launching the kernel
cudaStatus = cudaGetLastError();
if (cudaStatus != cudaSuccess) {
fprintf(stderr, "addKernel launch failed: %s\n", cudaGetErrorString(cudaStatus));
goto Error;
I don’t know why it is. pls check it.
thanks in advance.
Hi, that error means that you haven’t compiled eith support for sm_53 (Nano GPU arch). Please add these flags to your nvcc compile options:
-gencode arch=compute_53,code=sm_53 \
-gencode arch=compute_53,code=compute_53
thanks for your kindly reply,
however, I still don’t know where should I add “nvcc compile options”.
Visual Studio 2015\Projects\CudaSumArrayDLL
as I know, the path route is project path.
.cu type file is only “kernel.cu” in this path, do you means that should I change it?
May I know more detail about your environment first?
Do you want to cross-compile an application for Jetson Nano?
I don’t think visual studio supports Jetson environment.
