Hello, I’m currently working on a YOLOv3 model with ResNet-18 backbone. The model is pruned and then retrained with Quantization-Aware-Training, now I’m trying to export the model and generate the cache file using tlt-export command, below is the exact command I used:
NOTE: UFF has been tested with TensorFlow 1.14.0.
WARNING: The version of TensorFlow installed on this system is not guaranteed to work with UFF.
Warning: No conversion function registered for layer: BatchedNMS_TRT yet.
Converting BatchedNMS as custom op: BatchedNMS_TRT
Warning: No conversion function registered for layer: ResizeNearest_TRT yet.
Converting upsample1/ResizeNearestNeighbor as custom op: ResizeNearest_TRT
Converting upsample0/ResizeNearestNeighbor as custom op: ResizeNearest_TRT
Warning: No conversion function registered for layer: BatchTilePlugin_TRT yet.
Converting FirstDimTile_2 as custom op: BatchTilePlugin_TRT
Converting FirstDimTile_1 as custom op: BatchTilePlugin_TRT
Converting FirstDimTile_0 as custom op: BatchTilePlugin_TRT
DEBUG [/usr/local/lib/python3.6/dist-packages/uff/converters/tensorflow/converter.py:96] Marking [‘BatchedNMS’] as outputs
2020-11-18 09:50:50,183 [INFO] iva.common.export.base_exporter: Generating a tensorfile with random tensor images. This may work well as a profiling tool, however, it may result in inaccurate results at inference. Please generate a tensorfile using the tlt-int8-tensorfile, or provide a custom directory of images for best performance.
File “/usr/local/bin/tlt-export”, line 8, in
sys.exit(main())
File “/home/vpraveen/.cache/dazel/_dazel_vpraveen/715c8bafe7816f3bb6f309cd506049bb/execroot/ai_infra/bazel-out/k8-py3-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/common/export/app.py”, line 185, in main
File “/home/vpraveen/.cache/dazel/_dazel_vpraveen/715c8bafe7816f3bb6f309cd506049bb/execroot/ai_infra/bazel-out/k8-py3-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/common/export/app.py”, line 263, in run_export
File “/home/vpraveen/.cache/dazel/_dazel_vpraveen/715c8bafe7816f3bb6f309cd506049bb/execroot/ai_infra/bazel-out/k8-py3-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/common/export/base_exporter.py”, line 478, in export
File “/home/vpraveen/.cache/dazel/_dazel_vpraveen/715c8bafe7816f3bb6f309cd506049bb/execroot/ai_infra/bazel-out/k8-py3-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/common/export/base_exporter.py”, line 206, in get_calibrator
File “/home/vpraveen/.cache/dazel/_dazel_vpraveen/715c8bafe7816f3bb6f309cd506049bb/execroot/ai_infra/bazel-out/k8-py3-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/common/export/base_exporter.py”, line 295, in generate_tensor_file
File “/home/vpraveen/.cache/dazel/_dazel_vpraveen/715c8bafe7816f3bb6f309cd506049bb/execroot/ai_infra/bazel-out/k8-py3-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/common/export/base_exporter.py”, line 337, in generate_random_tensorfile
File “/home/vpraveen/.cache/dazel/_dazel_vpraveen/715c8bafe7816f3bb6f309cd506049bb/execroot/ai_infra/bazel-out/k8-py3-fastbuild/bin/magnet/packages/core/build_wheel.runfiles/ai_infra/moduluspy/modulus/export/data.py”, line 54, in init
File “/usr/local/lib/python3.6/dist-packages/h5py/_hl/files.py”, line 312, in init
fid = make_fid(name, mode, userblock_size, fapl, swmr=swmr)
File “/usr/local/lib/python3.6/dist-packages/h5py/_hl/files.py”, line 148, in make_fid
fid = h5f.create(name, h5f.ACC_TRUNC, fapl=fapl, fcpl=fcpl)
File “h5py/_objects.pyx”, line 54, in h5py._objects.with_phil.wrapper
File “h5py/_objects.pyx”, line 55, in h5py._objects.with_phil.wrapper
File “h5py/h5f.pyx”, line 98, in h5py.h5f.create
ValueError: Invalid file name (invalid file name)
Please refer to the commands inside the jupyter notebook or tlt-user guide.
For example, below is needed.
--cal_data_file : tensorfile generated from tlt-int8-tensorfile for calibrating the engine. This can also be an output file if used with --cal_image_dir .
--cal_image_dir : Directory of images to use for calibration.
I see those two arguments, however, my question is are they still needed while my input model is trained with QAT? For what I understood, the dynamic ranges for int8 are already computed during the quantization aware training, and thus there is no need to calibrate one more time when exporting the model.
Here is a note quoted from tlt-export section in the official documentation:
When exporting a model trained with QAT enabled, the tensor scale factors to calibrate the activations are peeled out of the model and serialized to a TensorRT readable cache file defined by the cal_cache_file argument. @Morganh
I see those two arguments, however, my question is are they still needed while my input model is trained with QAT? For what I understood, the dynamic ranges for int8 are already computed during the quantization aware training, and thus there is no need to calibrate one more time when exporting the model. @Morganh
I’m confused here too, facing the same problem. The documentation clearly state that the cal_image_dir is not needed and that the calibration scaling factors are extracted from the .tlt file because it was trained with QAT enabled.
Issue cannot be reproduced.Actually your model is not a QAT model.
I verify with TLT 2.0_py3 docker.
Please set enable_qat: true in the first training spec, then trigger training. Run tlt-export without "–cal_data_file " and “–cal_image_dir”,there is no issue.
# tlt-export yolo -k key -m result/weights/yolo_resnet18_epoch_005.tlt -e yolo_train_resnet18_kitti.txt --data_type int8 --batch_size 16 --cal_cache_file output/cal.bin -o output/yolo_resnet18_epoch_005.etlt
Using TensorFlow backend.
2021-01-28 14:40:47.562814: I tensorflow/stream_executor/platform/default/dso_loader.cc:44] Successfully opened dynamic library libcudart.so.10.0
2021-01-28 14:40:50.330969: I tensorflow/stream_executor/platform/default/dso_loader.cc:44] Successfully opened dynamic library libcuda.so.1
2021-01-28 14:40:50.331584: I tensorflow/core/common_runtime/gpu/gpu_device.cc:1618] Found device 0 with properties:
name: GeForce GTX 1080 Ti major: 6 minor: 1 memoryClockRate(GHz): 1.582
pciBusID: 0000:65:00.0
2021-01-28 14:40:50.331618: I tensorflow/stream_executor/platform/default/dso_loader.cc:44] Successfully opened dynamic library libcudart.so.10.0
2021-01-28 14:40:50.331666: I tensorflow/stream_executor/platform/default/dso_loader.cc:44] Successfully opened dynamic library libcublas.so.10.0
2021-01-28 14:40:50.332728: I tensorflow/stream_executor/platform/default/dso_loader.cc:44] Successfully opened dynamic library libcufft.so.10.0
2021-01-28 14:40:50.332807: I tensorflow/stream_executor/platform/default/dso_loader.cc:44] Successfully opened dynamic library libcurand.so.10.0
2021-01-28 14:40:50.334227: I tensorflow/stream_executor/platform/default/dso_loader.cc:44] Successfully opened dynamic library libcusolver.so.10.0
2021-01-28 14:40:50.335289: I tensorflow/stream_executor/platform/default/dso_loader.cc:44] Successfully opened dynamic library libcusparse.so.10.0
2021-01-28 14:40:50.335354: I tensorflow/stream_executor/platform/default/dso_loader.cc:44] Successfully opened dynamic library libcudnn.so.7
2021-01-28 14:40:50.336164: I tensorflow/core/common_runtime/gpu/gpu_device.cc:1746] Adding visible gpu devices: 0
2021-01-28 14:40:50.336195: I tensorflow/stream_executor/platform/default/dso_loader.cc:44] Successfully opened dynamic library libcudart.so.10.0
2021-01-28 14:40:50.850069: I tensorflow/core/common_runtime/gpu/gpu_device.cc:1159] Device interconnect StreamExecutor with strength 1 edge matrix:
2021-01-28 14:40:50.850116: I tensorflow/core/common_runtime/gpu/gpu_device.cc:1165] 0
2021-01-28 14:40:50.850123: I tensorflow/core/common_runtime/gpu/gpu_device.cc:1178] 0: N
2021-01-28 14:40:50.851424: I tensorflow/core/common_runtime/gpu/gpu_device.cc:1304] Created TensorFlow device (/job:localhost/replica:0/task:0/device:GPU:0 with 9699 MB memory) -> physical GPU (device: 0, name: GeForce GTX 1080 Ti, pci bus id: 0000:65:00.0, compute capability: 6.1)
2021-01-28 14:40:55,128 [INFO] /usr/local/lib/python3.6/dist-packages/iva/yolo/utils/spec_loader.pyc: Merging specification from yolo_train_resnet18_kitti.txt
2021-01-28 14:40:58.358860: I tensorflow/core/common_runtime/gpu/gpu_device.cc:1618] Found device 0 with properties:
2021-01-28 14:40:58.358919: I tensorflow/stream_executor/platform/default/dso_loader.cc:44] Successfully opened dynamic library libcudart.so.10.0
2021-01-28 14:40:58.358954: I tensorflow/stream_executor/platform/default/dso_loader.cc:44] Successfully opened dynamic library libcublas.so.10.0
2021-01-28 14:40:58.358976: I tensorflow/stream_executor/platform/default/dso_loader.cc:44] Successfully opened dynamic library libcufft.so.10.0
2021-01-28 14:40:58.358996: I tensorflow/stream_executor/platform/default/dso_loader.cc:44] Successfully opened dynamic library libcurand.so.10.0
2021-01-28 14:40:58.359010: I tensorflow/stream_executor/platform/default/dso_loader.cc:44] Successfully opened dynamic library libcusolver.so.10.0
2021-01-28 14:40:58.359024: I tensorflow/stream_executor/platform/default/dso_loader.cc:44] Successfully opened dynamic library libcusparse.so.10.0
2021-01-28 14:40:58.359036: I tensorflow/stream_executor/platform/default/dso_loader.cc:44] Successfully opened dynamic library libcudnn.so.7
2021-01-28 14:40:58.359746: I tensorflow/core/common_runtime/gpu/gpu_device.cc:1746] Adding visible gpu devices: 0
2021-01-28 14:40:58.359777: I tensorflow/core/common_runtime/gpu/gpu_device.cc:1159] Device interconnect StreamExecutor with strength 1 edge matrix:
2021-01-28 14:40:58.359786: I tensorflow/core/common_runtime/gpu/gpu_device.cc:1165] 0
2021-01-28 14:40:58.359794: I tensorflow/core/common_runtime/gpu/gpu_device.cc:1178] 0: N
2021-01-28 14:40:58.360488: I tensorflow/core/common_runtime/gpu/gpu_device.cc:1304] Created TensorFlow device (/job:localhost/replica:0/task:0/device:GPU:0 with 9699 MB memory) -> physical GPU (device: 0, name: GeForce GTX 1080 Ti, pci bus id: 0000:65:00.0, compute capability: 6.1)
2021-01-28 14:42:17.901148: I tensorflow/core/common_runtime/gpu/gpu_device.cc:1618] Found device 0 with properties:
2021-01-28 14:42:17.901210: I tensorflow/stream_executor/platform/default/dso_loader.cc:44] Successfully opened dynamic library libcudart.so.10.0
2021-01-28 14:42:17.901254: I tensorflow/stream_executor/platform/default/dso_loader.cc:44] Successfully opened dynamic library libcublas.so.10.0
2021-01-28 14:42:17.901279: I tensorflow/stream_executor/platform/default/dso_loader.cc:44] Successfully opened dynamic library libcufft.so.10.0
2021-01-28 14:42:17.901293: I tensorflow/stream_executor/platform/default/dso_loader.cc:44] Successfully opened dynamic library libcurand.so.10.0
2021-01-28 14:42:17.901308: I tensorflow/stream_executor/platform/default/dso_loader.cc:44] Successfully opened dynamic library libcusolver.so.10.0
2021-01-28 14:42:17.901323: I tensorflow/stream_executor/platform/default/dso_loader.cc:44] Successfully opened dynamic library libcusparse.so.10.0
2021-01-28 14:42:17.901338: I tensorflow/stream_executor/platform/default/dso_loader.cc:44] Successfully opened dynamic library libcudnn.so.7
2021-01-28 14:42:17.902009: I tensorflow/core/common_runtime/gpu/gpu_device.cc:1746] Adding visible gpu devices: 0
2021-01-28 14:42:17.902038: I tensorflow/core/common_runtime/gpu/gpu_device.cc:1159] Device interconnect StreamExecutor with strength 1 edge matrix:
2021-01-28 14:42:17.902046: I tensorflow/core/common_runtime/gpu/gpu_device.cc:1165] 0
2021-01-28 14:42:17.902054: I tensorflow/core/common_runtime/gpu/gpu_device.cc:1178] 0: N
2021-01-28 14:42:17.902732: I tensorflow/core/common_runtime/gpu/gpu_device.cc:1304] Created TensorFlow device (/job:localhost/replica:0/task:0/device:GPU:0 with 9699 MB memory) -> physical GPU (device: 0, name: GeForce GTX 1080 Ti, pci bus id: 0000:65:00.0, compute capability: 6.1)
2021-01-28 14:42:22.379106: I tensorflow/core/common_runtime/gpu/gpu_device.cc:1618] Found device 0 with properties:
2021-01-28 14:42:22.379165: I tensorflow/stream_executor/platform/default/dso_loader.cc:44] Successfully opened dynamic library libcudart.so.10.0
2021-01-28 14:42:22.379202: I tensorflow/stream_executor/platform/default/dso_loader.cc:44] Successfully opened dynamic library libcublas.so.10.0
2021-01-28 14:42:22.379223: I tensorflow/stream_executor/platform/default/dso_loader.cc:44] Successfully opened dynamic library libcufft.so.10.0
2021-01-28 14:42:22.379235: I tensorflow/stream_executor/platform/default/dso_loader.cc:44] Successfully opened dynamic library libcurand.so.10.0
2021-01-28 14:42:22.379248: I tensorflow/stream_executor/platform/default/dso_loader.cc:44] Successfully opened dynamic library libcusolver.so.10.0
2021-01-28 14:42:22.379260: I tensorflow/stream_executor/platform/default/dso_loader.cc:44] Successfully opened dynamic library libcusparse.so.10.0
2021-01-28 14:42:22.379272: I tensorflow/stream_executor/platform/default/dso_loader.cc:44] Successfully opened dynamic library libcudnn.so.7
2021-01-28 14:42:22.379972: I tensorflow/core/common_runtime/gpu/gpu_device.cc:1746] Adding visible gpu devices: 0
2021-01-28 14:42:22.380634: I tensorflow/core/common_runtime/gpu/gpu_device.cc:1618] Found device 0 with properties:
2021-01-28 14:42:22.380666: I tensorflow/stream_executor/platform/default/dso_loader.cc:44] Successfully opened dynamic library libcudart.so.10.0
2021-01-28 14:42:22.380691: I tensorflow/stream_executor/platform/default/dso_loader.cc:44] Successfully opened dynamic library libcublas.so.10.0
2021-01-28 14:42:22.380708: I tensorflow/stream_executor/platform/default/dso_loader.cc:44] Successfully opened dynamic library libcufft.so.10.0
2021-01-28 14:42:22.380720: I tensorflow/stream_executor/platform/default/dso_loader.cc:44] Successfully opened dynamic library libcurand.so.10.0
2021-01-28 14:42:22.380735: I tensorflow/stream_executor/platform/default/dso_loader.cc:44] Successfully opened dynamic library libcusolver.so.10.0
2021-01-28 14:42:22.380753: I tensorflow/stream_executor/platform/default/dso_loader.cc:44] Successfully opened dynamic library libcusparse.so.10.0
2021-01-28 14:42:22.380770: I tensorflow/stream_executor/platform/default/dso_loader.cc:44] Successfully opened dynamic library libcudnn.so.7
2021-01-28 14:42:22.381458: I tensorflow/core/common_runtime/gpu/gpu_device.cc:1746] Adding visible gpu devices: 0
2021-01-28 14:42:22.381489: I tensorflow/core/common_runtime/gpu/gpu_device.cc:1159] Device interconnect StreamExecutor with strength 1 edge matrix:
2021-01-28 14:42:22.381497: I tensorflow/core/common_runtime/gpu/gpu_device.cc:1165] 0
2021-01-28 14:42:22.381505: I tensorflow/core/common_runtime/gpu/gpu_device.cc:1178] 0: N
2021-01-28 14:42:22.382182: I tensorflow/core/common_runtime/gpu/gpu_device.cc:1304] Created TensorFlow device (/job:localhost/replica:0/task:0/device:GPU:0 with 9699 MB memory) -> physical GPU (device: 0, name: GeForce GTX 1080 Ti, pci bus id: 0000:65:00.0, compute capability: 6.1)
DEBUG [/usr/local/lib/python3.6/dist-packages/uff/converters/tensorflow/converter.py:96] Marking ['BatchedNMS'] as outputs
