Questions about Tensor Metadata in the nvinfer plugin
• Hardware Platform (Jetson / GPU) : jetson
• DeepStream Version : 5.0 ga
• JetPack Version (valid for Jetson only):4.4
• TensorRT Version:7.1
Hi guys,
nvinfer has options to set True/False for capturiung the raw-tensor data in the metadata for both primary mode and seconder mode.
For secondary model, It attached output tensor of each object for last output layer before softmax layer?
For primary mode, It attached the frame tensor?
I think so, You can refer deepstream_infer_tensor_meta_test.cpp for more details
