queueInputBatch(): cudaMemcpyAsync for output buffers failed (cudaErrorLaunchFailure)
HI mchi,
  1. can you try this on powerful platform, e.g. Xavier or dGPU+x86 system?
It will take some time, i’ll try and post the results.
  1. can set all three model to bacth==1 and check if this issue is still reproducibled
Batch size set to 1 for all the models and i receive the same error.
  1. run cuda-mmecheck to check the CUDA memory access
output:
========= CUDA-MEMCHECK
Using winsys: x11
========= Internal Memcheck Error: Initialization failed
=========     Saved host backtrace up to driver entry point at error
=========     Host Frame:/usr/lib/aarch64-linux-gnu/tegra/libcuda.so.1 (cuDevicePrimaryCtxRetain + 0x154) [0x1fda6c]
=========     Host Frame:/usr/lib/aarch64-linux-gnu/gstreamer-1.0/deepstream/libnvdsgst_multistream.so [0x42724]
Creating LL OSD context new
0:00:03.549280537 32736   0x5584b09490 INFO                 nvinfer gstnvinfer.cpp:519:gst_nvinfer_logger:<secondary_gie_1> NvDsInferContext[UID 3]:initialize(): Trying to create engine from model files
0:00:42.518084575 32736   0x5584b09490 INFO                 nvinfer gstnvinfer.cpp:519:gst_nvinfer_logger:<secondary_gie_1> NvDsInferContext[UID 3]:generateTRTModel(): Storing the serialized cuda engine to file at /opt/nvidia/deepstream/deepstream-4.0/sources/apps/sample_apps/anpr-test1/char_rec_model.uff_b1_fp32.engine
0:00:43.514035446 32736   0x5584b09490 INFO                 nvinfer gstnvinfer.cpp:519:gst_nvinfer_logger:<secondary_gie_0> NvDsInferContext[UID 2]:initialize(): Trying to create engine from model files
Loading pre-trained weights...
Loading complete!
Total Number of weights read : 291836
Output blob names :
yolo_13
Total number of layers: 31
Total number of layers on DLA: 0
Building the TensorRT Engine...
Building complete!
0:00:55.120270441 32736   0x5584b09490 INFO                 nvinfer gstnvinfer.cpp:519:gst_nvinfer_logger:<secondary_gie_0> NvDsInferContext[UID 2]:generateTRTModel(): Storing the serialized cuda engine to file at /opt/nvidia/deepstream/deepstream-4.0/sources/apps/sample_apps/deepstream-app/model_b1_fp32.engine
Deserialize yoloLayerV3 plugin: yolo_13
gstnvtracker: Loading low-level lib at /opt/nvidia/deepstream/deepstream-4.0/lib/libnvds_mot_klt.so
gstnvtracker: Optional NvMOT_RemoveStreams not implemented
gstnvtracker: Batch processing is OFF
Deserialize yoloLayerV3 plugin: yolo_15
Deserialize yoloLayerV3 plugin: yolo_22
Runtime commands:
	h: Print this help
	q: Quit
	p: Pause
	r: Resume
NOTE: To expand a source in the 2D tiled display and view object details, left-click on the source.
      To go back to the tiled display, right-click anywhere on the window.
**PERF: FPS 0 (Avg)
**PERF: 0.00 (0.00)
** INFO: <bus_callback:189>: Pipeline ready
Opening in BLOCKING MODE
NvMMLiteOpen : Block : BlockType = 261
NVMEDIA: Reading vendor.tegra.display-size : status: 6
NvMMLiteBlockCreate : Block : BlockType = 261
** INFO: <bus_callback:175>: Pipeline running
0:00:57.739293883 32736   0x558470ac00 ERROR                nvinfer gstnvinfer.cpp:511:gst_nvinfer_logger:<primary_gie_classifier> NvDsInferContext[UID 1]:queueInputBatch(): cudaMemcpyAsync for output buffers failed (cudaErrorLaunchFailure)
0:00:57.739381687 32736   0x558470ac00 WARN                 nvinfer gstnvinfer.cpp:1098:gst_nvinfer_input_queue_loop:<primary_gie_classifier> error: Failed to queue input batch for inferencing
0:00:57.739578739 32736   0x558470ac00 ERROR                nvinfer gstnvinfer.cpp:511:gst_nvinfer_logger:<primary_gie_classifier> NvDsInferContext[UID 1]:queueInputBatch(): Failed to make stream wait on event(cudaErrorLaunchFailure)
0:00:57.740077886 32736   0x558470ac00 WARN                 nvinfer gstnvinfer.cpp:1098:gst_nvinfer_input_queue_loop:<primary_gie_classifier> error: Failed to queue input batch for inferencing
0:00:57.740187342 32736   0x558470ac00 ERROR                nvinfer gstnvinfer.cpp:511:gst_nvinfer_logger:<primary_gie_classifier> NvDsInferContext[UID 1]:queueInputBatch(): Failed to make stream wait on event(cudaErrorLaunchFailure)
0:00:57.740240668 32736   0x558470ac00 WARN                 nvinfer gstnvinfer.cpp:1098:gst_nvinfer_input_queue_loop:<primary_gie_classifier> error: Failed to queue input batch for inferencing
ERROR from primary_gie_classifier: Failed to queue input batch for inferencing
Debug info: /dvs/git/dirty/git-master_linux/deepstream/sdk/src/gst-plugins/gst-nvinfer/gstnvinfer.cpp(1098): gst_nvinfer_input_queue_loop (): /GstPipeline:pipeline/GstBin:primary_gie_bin/GstNvInfer:primary_gie_classifier
KLT Tracker Init
========= Error: process didn't terminate successfully
=========        The application may have hit an error when dereferencing Unified Memory from the host. Please rerun the application under cuda-gdb or Nsight Eclipse Edition to catch host side errors.
========= No CUDA-MEMCHECK results found
back-to-back-detectors.gz (217.0 KB)
Could you take a try this sample?
$ cd /opt/nvidia/deepstream/deepstream-5.0/sources/apps/sample_apps
$ tar xpf back-to-back-detectors.tgz
$ cd back-to-back-detectors
$ ./prebuild.sh
$ make
$ ./back-to-back-detectors file:///opt/nvidia/deepstream/deepstream-5.0/samples/streams/sample_720p.h264
if you run on DeepStream 4,0, make below change to the Makefile.
NVDS_VERSION:=5.0
to
NVDS_VERSION:=4.0
And, in your configure file, please try changing
network-mode=0
to
network-mode=2
to use FP16 instead of FP32
Hi mchi,
I was trying trying to post but was unable because it said can’t post in read mode, however i tried the sample
Error:
0:00:19.772169864 11797   0x5585c5f050 WARN                 nvinfer gstnvinfer.cpp:1830:gst_nvinfer_output_loop:<char-recognition> error: Internal data stream error.
0:00:19.772249140 11797   0x5585c5f050 WARN                 nvinfer gstnvinfer.cpp:1830:gst_nvinfer_output_loop:<char-recognition> error: streaming stopped, reason error (-5)
ERROR from element char-recognition: Internal data stream error.
Error details: /dvs/git/dirty/git-master_linux/deepstream/sdk/src/gst-plugins/gst-nvinfer/gstnvinfer.cpp(1830): gst_nvinfer_output_loop (): /GstPipeline:anprtest1-pipeline/GstNvInfer:char-recognition:
Returned, stopping playback
Deleting pipeline
what sample? how did you try? could you share more details?
The back-to-back-detectors sample that you provided, i tried it on jetson nano. Set the batch size to 1.
Hi @pawany16,
Really sorry for long delay!
Below change can enable back-to-back sample on NANO.
Did you try your program on powerful GPU, e.g. Xavier or dGPU?
diff -ruNa deepstream_reference_apps/back-to-back-detectors/Makefile back-to-back-detectors/Makefile
--- deepstream_reference_apps/back-to-back-detectors/Makefile   2020-07-20 23:56:42.161382402 +0800
+++ back-to-back-detectors/Makefile     2020-07-20 23:15:14.693073845 +0800
@@ -24,7 +24,7 @@
 TARGET_DEVICE = $(shell gcc -dumpmachine | cut -f1 -d -)
-NVDS_VERSION:=4.0
+NVDS_VERSION:=5.0
 LIB_INSTALL_DIR?=/opt/nvidia/deepstream/deepstream-$(NVDS_VERSION)/lib/
diff -ruNa deepstream_reference_apps/back-to-back-detectors/back_to_back_detectors.c back-to-back-detectors/back_to_back_detectors.c
--- deepstream_reference_apps/back-to-back-detectors/back_to_back_detectors.c   2020-07-20 23:56:42.165382507 +0800
+++ back-to-back-detectors/back_to_back_detectors.c     2020-07-20 23:58:13.759777901 +0800
@@ -237,7 +237,8 @@
 #ifdef PLATFORM_TEGRA
   transform = gst_element_factory_make ("nvegltransform", "nvegl-transform");
 #endif
-  sink = gst_element_factory_make ("nveglglessink", "nvvideo-renderer");
+  //sink = gst_element_factory_make ("nveglglessink", "nvvideo-renderer");
+  sink = gst_element_factory_make ("fakesink", "nvvideo-renderer");
   if (!source || !h264parser || !decoder || !primary_detector || !secondary_detector
       || !nvvidconv || !nvosd || !sink) {
@@ -321,7 +322,7 @@
   if (!gst_element_link_many (streammux, primary_detector, secondary_detector,
-      nvvidconv, nvosd, transform, sink, NULL)) {
+      nvvidconv, nvosd, /*transform,*/ sink, NULL)) {
     g_printerr ("Elements could not be linked: 2. Exiting.\n");
     return -1;
