The program does not running
• Hardware Platform (Jetson / GPU) Jetson AGX
• DeepStream Version 7.0
**• JetPack Version (valid for Jetson only) 6.0 GA
**• TensorRT Version 8.6
**• NVIDIA GPU Driver Version (valid for GPU only) 540.3.0
**• Issue Type( questions, new requirements, bugs) questions
I want to run this deepstream-3d-action-recognition ,but show error message
The piture is below
The previous three picture are using jtop command, the last is the output of program
It seem that the resource is not enough . How to fix this problem
Now playing: file:///opt/nvidia/deepstream/deepstream/samples/streams/sample_walk.mov, file:///opt/nvidia/deepstream/deepstream/samples/streams/sample_ride_bike.mov, file:///opt/nvidia/deepstream/deepstream/samples/streams/sample_run.mov, file:///opt/nvidia/deepstream/deepstream/samples/streams/sample_push.mov, file:///home/debug/output.mov,
Setting min object dimensions as 16x16 instead of 1x1 to support VIC compute mode.
WARNING: [TRT]: Using an engine plan file across different models of devices is not recommended and is likely to affect performance or even cause errors.
0:00:04.815120890 185926 0xaaaaea935360 INFO nvinfer gstnvinfer.cpp:682:gst_nvinfer_logger: NvDsInferContext[UID 1]: Info from NvDsInferContextImpl::deserializeEngineAndBackend() <nvdsinfer_context_impl.cpp:2095> [UID = 1]: deserialized trt engine from :/home/debug/deployable_v1.0/resnet18_2d_rgb_hmdb5_32.etlt_b4_gpu0_fp16.engine
INFO: [FullDims Engine Info]: layers num: 2
0 INPUT kFLOAT input_rgb 96x224x224 min: 1x96x224x224 opt: 4x96x224x224 Max: 4x96x224x224
1 OUTPUT kFLOAT fc_pred 5 min: 0 opt: 0 Max: 0
0:00:05.134882703 185926 0xaaaaea935360 INFO nvinfer gstnvinfer.cpp:682:gst_nvinfer_logger: NvDsInferContext[UID 1]: Info from NvDsInferContextImpl::generateBackendContext() <nvdsinfer_context_impl.cpp:2198> [UID = 1]: Use deserialized engine model: /home/debug/deployable_v1.0/resnet18_2d_rgb_hmdb5_32.etlt_b4_gpu0_fp16.engine
0:00:05.146379153 185926 0xaaaaea935360 INFO nvinfer gstnvinfer_impl.cpp:343:notifyLoadModelStatus: [UID 1]: Load new model:config_infer_primary_2d_action.txt sucessfully
/dvs/git/dirty/git-master_linux/deepstream/sdk/apps/deepstream/sample_apps/deepstream-3d-action-recognition/custom_sequence_preprocess/sequence_image_process.cpp:489, [INFO: CUSTOM_LIB] 2D custom sequence network shape NSHW[4, 96, 224, 224], reshaped as [N: 4, C: 3, S:32, H: 224, W:224]
/dvs/git/dirty/git-master_linux/deepstream/sdk/apps/deepstream/sample_apps/deepstream-3d-action-recognition/custom_sequence_preprocess/sequence_image_process.cpp:512, [INFO: CUSTOM_LIB] Sequence preprocess buffer manager initialized with stride: 1, subsample: 0
/dvs/git/dirty/git-master_linux/deepstream/sdk/apps/deepstream/sample_apps/deepstream-3d-action-recognition/custom_sequence_preprocess/sequence_image_process.cpp:516, [INFO: CUSTOM_LIB] SequenceImagePreprocess initialized successfully
0:00:05.173610107 185926 0xaaaaea935360 WARN basesrc gstbasesrc.c:3688:gst_base_src_start_complete: pad not activated yet
Decodebin child added: source
Decodebin child added: decodebin0
0:00:05.174169075 185926 0xaaaaea935360 WARN basesrc gstbasesrc.c:3688:gst_base_src_start_complete: pad not activated yet
0:00:05.174595341 185926 0xaaaaea935360 WARN basesrc gstbasesrc.c:3688:gst_base_src_start_complete: pad not activated yet
Decodebin child added: decodebin1
0:00:05.174860138 185926 0xaaaaea935360 WARN basesrc gstbasesrc.c:3688:gst_base_src_start_complete: pad not activated yet
0:00:05.175437986 185926 0xaaaaea935360 WARN basesrc gstbasesrc.c:3688:gst_base_src_start_complete: pad not activated yet
Decodebin child added: decodebin2
0:00:05.175712254 185926 0xaaaaea935360 WARN basesrc gstbasesrc.c:3688:gst_base_src_start_complete: pad not activated yet
0:00:05.177868288 185926 0xaaaaea935360 WARN basesrc gstbasesrc.c:3688:gst_base_src_start_complete: pad not activated yet
Decodebin child added: decodebin3
0:00:05.178405209 185926 0xaaaaea935360 WARN basesrc gstbasesrc.c:3688:gst_base_src_start_complete: pad not activated yet
0:00:05.179019440 185926 0xaaaaea935360 WARN basesrc gstbasesrc.c:3688:gst_base_src_start_complete: pad not activated yet
Decodebin child added: decodebin4
0:00:05.179676871 185926 0xaaaaea935360 WARN basesrc gstbasesrc.c:3688:gst_base_src_start_complete: pad not activated yet
Running…
Decodebin child added: qtdemux1
Decodebin child added: qtdemux4
Decodebin child added: qtdemux0
Decodebin child added: qtdemux3
Decodebin child added: qtdemux2
0:00:05.200190253 185926 0xaaab0ec85640 WARN qtdemux qtdemux_types.c:249:qtdemux_type_get: unknown QuickTime node type tmcd
0:00:05.200242285 185926 0xaaab0ec85640 WARN qtdemux qtdemux_types.c:249:qtdemux_type_get: unknown QuickTime node type sgpd
0:00:05.200252940 185926 0xaaab0ec85640 WARN qtdemux qtdemux_types.c:249:qtdemux_type_get: unknown QuickTime node type sbgp
0:00:05.200261260 185926 0xaaab0ec85640 WARN qtdemux qtdemux_types.c:249:qtdemux_type_get: unknown QuickTime node type text
0:00:05.200268204 185926 0xaaab0ec85640 WARN qtdemux qtdemux_types.c:249:qtdemux_type_get: unknown QuickTime node type tmcd
0:00:05.200291372 185926 0xaaab0ec85640 WARN qtdemux qtdemux_types.c:249:qtdemux_type_get: unknown QuickTime node type tmcd
0:00:05.200304652 185926 0xaaab0ec85640 WARN qtdemux qtdemux.c:7942:qtdemux_parse_container: length too long (2184644 > 37)
0:00:05.200295820 185926 0xffff0c022300 WARN qtdemux qtdemux_types.c:249:qtdemux_type_get: unknown QuickTime node type tmcd
0:00:05.200319244 185926 0xaaab0ec85640 WARN qtdemux qtdemux_types.c:249:qtdemux_type_get: unknown QuickTime node type keys
0:00:05.200355659 185926 0xffff0c022300 WARN qtdemux qtdemux_types.c:249:qtdemux_type_get: unknown QuickTime node type sgpd
0:00:05.200371115 185926 0xffff0c022300 WARN qtdemux qtdemux_types.c:249:qtdemux_type_get: unknown QuickTime node type sbgp
0:00:05.200380875 185926 0xffff0c022300 WARN qtdemux qtdemux_types.c:249:qtdemux_type_get: unknown QuickTime node type text
0:00:05.200388427 185926 0xffff0c022300 WARN qtdemux qtdemux_types.c:249:qtdemux_type_get: unknown QuickTime node type tmcd
0:00:05.200426954 185926 0xffff0c022300 WARN qtdemux qtdemux_types.c:249:qtdemux_type_get: unknown QuickTime node type tmcd
0:00:05.200431466 185926 0xffff000238c0 WARN qtdemux qtdemux_types.c:249:qtdemux_type_get: unknown QuickTime node type tmcd
0:00:05.200440426 185926 0xffff0c022300 WARN qtdemux qtdemux.c:7942:qtdemux_parse_container: length too long (2184644 > 37)
0:00:05.200464202 185926 0xffff0c022300 WARN qtdemux qtdemux_types.c:249:qtdemux_type_get: unknown QuickTime node type keys
0:00:05.200464074 185926 0xffff000238c0 WARN qtdemux qtdemux_types.c:249:qtdemux_type_get: unknown QuickTime node type sgpd
0:00:05.200489481 185926 0xffff000238c0 WARN qtdemux qtdemux_types.c:249:qtdemux_type_get: unknown QuickTime node type sbgp
0:00:05.200470058 185926 0xffff040495e0 WARN qtdemux qtdemux_types.c:249:qtdemux_type_get: unknown QuickTime node type tmcd
0:00:05.200503561 185926 0xffff000238c0 WARN qtdemux qtdemux_types.c:249:qtdemux_type_get: unknown QuickTime node type text
0:00:05.200527177 185926 0xffff000238c0 WARN qtdemux qtdemux_types.c:249:qtdemux_type_get: unknown QuickTime node type tmcd
0:00:05.200532105 185926 0xffff040495e0 WARN qtdemux qtdemux_types.c:249:qtdemux_type_get: unknown QuickTime node type sgpd
0:00:05.200540489 185926 0xffff000238c0 WARN qtdemux qtdemux_types.c:249:qtdemux_type_get: unknown QuickTime node type tmcd
0:00:05.200544808 185926 0xffff040495e0 WARN qtdemux qtdemux_types.c:249:qtdemux_type_get: unknown QuickTime node type sbgp
0:00:05.200555016 185926 0xffff000238c0 WARN qtdemux qtdemux.c:7942:qtdemux_parse_container: length too long (2184644 > 37)
0:00:05.200564936 185926 0xffff040495e0 WARN qtdemux qtdemux_types.c:249:qtdemux_type_get: unknown QuickTime node type text
0:00:05.200576328 185926 0xffff000238c0 WARN qtdemux qtdemux_types.c:249:qtdemux_type_get: unknown QuickTime node type keys
0:00:05.200586920 185926 0xffff040495e0 WARN qtdemux qtdemux_types.c:249:qtdemux_type_get: unknown QuickTime node type tmcd
0:00:05.200612936 185926 0xffff040495e0 WARN qtdemux qtdemux_types.c:249:qtdemux_type_get: unknown QuickTime node type tmcd
0:00:05.200623527 185926 0xffff040495e0 WARN qtdemux qtdemux.c:7942:qtdemux_parse_container: length too long (2184644 > 37)
0:00:05.200634023 185926 0xffff040495e0 WARN qtdemux qtdemux_types.c:249:qtdemux_type_get: unknown QuickTime node type keys
0:00:05.200690118 185926 0xaaab0ec85640 WARN qtdemux qtdemux.c:3121:qtdemux_parse_trex: failed to find fragment defaults for stream 1
0:00:05.200706726 185926 0xffff0c022300 WARN qtdemux qtdemux.c:3121:qtdemux_parse_trex: failed to find fragment defaults for stream 1
0:00:05.200716262 185926 0xffff000238c0 WARN qtdemux qtdemux.c:3121:qtdemux_parse_trex: failed to find fragment defaults for stream 1
0:00:05.200710726 185926 0xffff040495e0 WARN qtdemux qtdemux.c:3121:qtdemux_parse_trex: failed to find fragment defaults for stream 1
0:00:05.200782213 185926 0xaaab0ec85640 WARN qtdemux qtdemux.c:3121:qtdemux_parse_trex: failed to find fragment defaults for stream 2
0:00:05.200790117 185926 0xffff000238c0 WARN qtdemux qtdemux.c:3121:qtdemux_parse_trex: failed to find fragment defaults for stream 2
0:00:05.200831877 185926 0xffff040495e0 WARN qtdemux qtdemux.c:3121:qtdemux_parse_trex: failed to find fragment defaults for stream 2
0:00:05.200849668 185926 0xffff0c022300 WARN qtdemux qtdemux.c:3121:qtdemux_parse_trex: failed to find fragment defaults for stream 2
0:00:05.200853540 185926 0xffff000238c0 WARN qtdemux qtdemux.c:10165:qtdemux_parse_segments: Segment 0 extends to 0:00:09.609633333 past the end of the declared movie duration 0:00:09.609600000 movie segment will be extended
0:00:05.200874916 185926 0xaaab0ec85640 WARN qtdemux qtdemux.c:3121:qtdemux_parse_trex: failed to find fragment defaults for stream 3
0:00:05.200907971 185926 0xffff0c022300 WARN qtdemux qtdemux.c:3121:qtdemux_parse_trex: failed to find fragment defaults for stream 3
0:00:05.200920675 185926 0xffff000238c0 WARN qtdemux qtdemux.c:3121:qtdemux_parse_trex: failed to find fragment defaults for stream 3
0:00:05.200891588 185926 0xffff040495e0 WARN qtdemux qtdemux.c:3121:qtdemux_parse_trex: failed to find fragment defaults for stream 3
0:00:05.201259487 185926 0xfffef400ae40 WARN qtdemux qtdemux.c:7942:qtdemux_parse_container: length too long (873924 > 17)
0:00:05.201293438 185926 0xfffef400ae40 WARN qtdemux qtdemux.c:3121:qtdemux_parse_trex: failed to find fragment defaults for stream 1
Decodebin child added: multiqueue1
Decodebin child added: multiqueue0
Decodebin child added: multiqueue2
Decodebin child added: multiqueue3
Decodebin child added: multiqueue4
Decodebin child added: h264parse0
Decodebin child added: h264parse2
Decodebin child added: h264parse1
Decodebin child added: h264parse3
Decodebin child added: h264parse4
Decodebin child added: capsfilter0
Decodebin child added: capsfilter1
Decodebin child added: capsfilter2
Decodebin child added: capsfilter3
Decodebin child added: capsfilter4
Decodebin child added: aacparse2
Decodebin child added: aacparse1
Decodebin child added: aacparse3
Decodebin child added: aacparse0
Decodebin child added: nvv4l2decoder0
Decodebin child added: avdec_aac0
Decodebin child added: avdec_aac2
Decodebin child added: avdec_aac1
Decodebin child added: avdec_aac3
Opening in BLOCKING MODE
Decodebin child added: nvv4l2decoder1
0:00:05.339321909 185926 0xfffef0015400 WARN v4l2 gstv4l2object.c:4671:gst_v4l2_object_probe_caps:nvv4l2decoder0:src Failed to probe pixel aspect ratio with VIDIOC_CROPCAP: Unknown error -1
Decodebin child added: nvv4l2decoder2
Decodebin child added: nvv4l2decoder3
Decodebin child added: nvv4l2decoder4
NvMMLiteOpen : Block : BlockType = 261
NvMMLiteBlockCreate : Block : BlockType = 261
0:00:05.366148580 185926 0xfffef400a400 WARN v4l2 gstv4l2object.c:4671:gst_v4l2_object_probe_caps:nvv4l2decoder3:src Failed to probe pixel aspect ratio with VIDIOC_CROPCAP: Unknown error -1
0:00:05.366148548 185926 0xfffee8014980 WARN v4l2 gstv4l2object.c:4671:gst_v4l2_object_probe_caps:nvv4l2decoder2:src Failed to probe pixel aspect ratio with VIDIOC_CROPCAP: Unknown error -1
0:00:05.367544913 185926 0xfffef802b920 WARN v4l2 gstv4l2object.c:4671:gst_v4l2_object_probe_caps:nvv4l2decoder1:src Failed to probe pixel aspect ratio with VIDIOC_CROPCAP: Unknown error -1
0:00:05.373365057 185926 0xfffef0015ea0 WARN v4l2 gstv4l2object.c:4671:gst_v4l2_object_probe_caps:nvv4l2decoder4:src Failed to probe pixel aspect ratio with VIDIOC_CROPCAP: Unknown error -1
0:00:05.467227127 185926 0xfffef0015400 WARN v4l2 gstv4l2object.c:4671:gst_v4l2_object_probe_caps:nvv4l2decoder0:src Failed to probe pixel aspect ratio with VIDIOC_CROPCAP: Unknown error -1
In cb_newpad
0:00:05.470355436 185926 0xfffef0015400 WARN v4l2videodec gstv4l2videodec.c:2311:gst_v4l2_video_dec_decide_allocation: Duration invalid, not setting latency
0:00:05.470508906 185926 0xfffee8014980 WARN v4l2 gstv4l2object.c:4671:gst_v4l2_object_probe_caps:nvv4l2decoder2:src Failed to probe pixel aspect ratio with VIDIOC_CROPCAP: Unknown error -1
0:00:05.470522441 185926 0xfffef400a400 WARN v4l2 gstv4l2object.c:4671:gst_v4l2_object_probe_caps:nvv4l2decoder3:src Failed to probe pixel aspect ratio with VIDIOC_CROPCAP: Unknown error -1
In cb_newpad
In cb_newpad
0:00:05.471603291 185926 0xfffef0015400 WARN v4l2bufferpool gstv4l2bufferpool.c:1116:gst_v4l2_buffer_pool_start:nvv4l2decoder0:pool:src Uncertain or not enough buffers, enabling copy threshold
In cb_newpad
In cb_newpad
0:00:05.473282916 185926 0xfffef400a400 WARN v4l2videodec gstv4l2videodec.c:2311:gst_v4l2_video_dec_decide_allocation: Duration invalid, not setting latency
0:00:05.473351491 185926 0xfffee8014980 WARN v4l2videodec gstv4l2videodec.c:2311:gst_v4l2_video_dec_decide_allocation: Duration invalid, not setting latency
0:00:05.474269462 185926 0xfffef400a400 WARN v4l2bufferpool gstv4l2bufferpool.c:1116:gst_v4l2_buffer_pool_start:nvv4l2decoder3:pool:src Uncertain or not enough buffers, enabling copy threshold
0:00:05.474676784 185926 0xfffee8014980 WARN v4l2bufferpool gstv4l2bufferpool.c:1116:gst_v4l2_buffer_pool_start:nvv4l2decoder2:pool:src Uncertain or not enough buffers, enabling copy threshold
0:00:05.475071915 185926 0xfffef802b920 WARN v4l2 gstv4l2object.c:4671:gst_v4l2_object_probe_caps:nvv4l2decoder1:src Failed to probe pixel aspect ratio with VIDIOC_CROPCAP: Unknown error -1
In cb_newpad
In cb_newpad
0:00:05.476430648 185926 0xfffef0015ea0 WARN v4l2 gstv4l2object.c:4671:gst_v4l2_object_probe_caps:nvv4l2decoder4:src Failed to probe pixel aspect ratio with VIDIOC_CROPCAP: Unknown error -1
In cb_newpad
0:00:05.477813093 185926 0xfffef802b920 WARN v4l2videodec gstv4l2videodec.c:2311:gst_v4l2_video_dec_decide_allocation: Duration invalid, not setting latency
In cb_newpad
0:00:05.478748984 185926 0xfffef802b920 WARN v4l2bufferpool gstv4l2bufferpool.c:1116:gst_v4l2_buffer_pool_start:nvv4l2decoder1:pool:src Uncertain or not enough buffers, enabling copy threshold
0:00:05.481526642 185926 0xfffef0015ea0 WARN v4l2videodec gstv4l2videodec.c:2311:gst_v4l2_video_dec_decide_allocation: Duration invalid, not setting latency
0:00:05.489547268 185926 0xfffef0015ea0 WARN v4l2bufferpool gstv4l2bufferpool.c:1116:gst_v4l2_buffer_pool_start:nvv4l2decoder4:pool:src Uncertain or not enough buffers, enabling copy threshold
0:00:05.507880104 185926 0xfffecc0b8400 WARN v4l2bufferpool gstv4l2bufferpool.c:1567:gst_v4l2_buffer_pool_dqbuf:nvv4l2decoder4:pool:src Driver should never set v4l2_buffer.field to ANY
0:00:05.511426935 185926 0xfffed808b520 WARN v4l2bufferpool gstv4l2bufferpool.c:1567:gst_v4l2_buffer_pool_dqbuf:nvv4l2decoder1:pool:src Driver should never set v4l2_buffer.field to ANY
0:00:05.516286004 185926 0xfffed008de40 WARN v4l2bufferpool gstv4l2bufferpool.c:1567:gst_v4l2_buffer_pool_dqbuf:nvv4l2decoder3:pool:src Driver should never set v4l2_buffer.field to ANY
0:00:05.522177667 185926 0xfffed4049760 WARN v4l2bufferpool gstv4l2bufferpool.c:1567:gst_v4l2_buffer_pool_dqbuf:nvv4l2decoder2:pool:src Driver should never set v4l2_buffer.field to ANY
0:00:05.543425631 185926 0xfffeec019520 WARN v4l2bufferpool gstv4l2bufferpool.c:1567:gst_v4l2_buffer_pool_dqbuf:nvv4l2decoder0:pool:src Driver should never set v4l2_buffer.field to ANY
I think this issue is caused by Jetpack not being installed properly.
Can you try the following command line for test ? Or try the deepstream-test1-app ?
gst-launch-1.0 -e nvstreammux name=mux batch-size=1 width=1280 height=720 ! nvinfer config-file-path=/opt/nvidia/deepstream/deepstream/sources/apps/sample_apps/deepstream-test2/dstest2_pgie_config.yml ! nvinfer config-file-path=/opt/nvidia/deepstream/deepstream/sources/apps/sample_apps/deepstream-test2/dstest2_sgie1_config.yml ! nvvideoconvert ! "video/x-raw(memory:NVMM), format=RGBA" ! nvdsosd ! nvvideoconvert ! nv3dsink filesrc location=/opt/nvidia/deepstream/deepstream/samples/streams/sample_720p.h264 ! h264parse ! nvv4l2decoder ! queue ! mux.sink_0
I have tested it on AGX Orin,deepstream-3d-action-recognition works properly.
The deepstream-test1 is same as previous
How to find the source of this problem?
This problem is caused by the driver, which may be an incompatible version. You need to re-burn the system to update JetPack
Can you explain in detail?
How to find the compatible driver
I met this situation today
root@jetson:/home/debug/deepstream/deepstream-6.3/sources/apps/sample_apps/deepstream-test1# GST_DEBUG=3 ./deepstream-test1-app dstest1_config.yml
Added elements to bin
Using file: dstest1_config.yml
0:00:00.132039106 314700 0xaaaaf1d14b20 WARN v4l2 gstv4l2object.c:4512:gst_v4l2_object_probe_caps:nvv4l2-decoder:src Failed to probe pixel aspect ratio with VIDIOC_CROPCAP: Unknown error -1
0:00:00.132113091 314700 0xaaaaf1d14b20 WARN v4l2 gstv4l2object.c:2398:gst_v4l2_object_add_interlace_mode:0xaaaaf1492760 Failed to determine interlace mode
0:00:00.132138340 314700 0xaaaaf1d14b20 WARN v4l2 gstv4l2object.c:2398:gst_v4l2_object_add_interlace_mode:0xaaaaf1492760 Failed to determine interlace mode
0:00:00.132155684 314700 0xaaaaf1d14b20 WARN v4l2 gstv4l2object.c:2398:gst_v4l2_object_add_interlace_mode:0xaaaaf1492760 Failed to determine interlace mode
0:00:00.132171493 314700 0xaaaaf1d14b20 WARN v4l2 gstv4l2object.c:2398:gst_v4l2_object_add_interlace_mode:0xaaaaf1492760 Failed to determine interlace mode
0:00:00.132475275 314700 0xaaaaf1d14b20 WARN basesrc gstbasesrc.c:3600:gst_base_src_start_complete: pad not activated yet
Running…
NVMEDIA: Reading vendor.tegra.display-size : status: 6
0:00:00.236740495 314700 0xaaaaf149a580 WARN v4l2 gstv4l2object.c:4512:gst_v4l2_object_probe_caps:nvv4l2-decoder:src Failed to probe pixel aspect ratio with VIDIOC_CROPCAP: Unknown error -1
0:00:00.236790096 314700 0xaaaaf149a580 WARN v4l2 gstv4l2object.c:2398:gst_v4l2_object_add_interlace_mode:0xaaaaf1492760 Failed to determine interlace mode
0:00:00.236818481 314700 0xaaaaf149a580 WARN v4l2 gstv4l2object.c:2398:gst_v4l2_object_add_interlace_mode:0xaaaaf1492760 Failed to determine interlace mode
0:00:00.236832849 314700 0xaaaaf149a580 WARN v4l2 gstv4l2object.c:2398:gst_v4l2_object_add_interlace_mode:0xaaaaf1492760 Failed to determine interlace mode
0:00:00.236845969 314700 0xaaaaf149a580 WARN v4l2 gstv4l2object.c:2398:gst_v4l2_object_add_interlace_mode:0xaaaaf1492760 Failed to determine interlace mode
0:00:00.237171961 314700 0xaaaaf149a580 WARN v4l2videodec gstv4l2videodec.c:1880:gst_v4l2_video_dec_decide_allocation: Duration invalid, not setting latency
0:00:00.237434558 314700 0xaaaaf149a580 WARN v4l2bufferpool gstv4l2bufferpool.c:1114:gst_v4l2_buffer_pool_start:nvv4l2-decoder:pool:src Uncertain or not enough buffers, enabling copy threshold
0:00:00.249199007 314700 0xaaaaf149a980 WARN v4l2bufferpool gstv4l2bufferpool.c:1565:gst_v4l2_buffer_pool_dqbuf:nvv4l2-decoder:pool:src Driver should never set v4l2_buffer.field to ANY
End of stream
Returned, stopping playback
Deleting pipeline
JetPack includes kernel, driver, cuda and Tensort.
Select the corresponding JetPack version and re-burn it using SDKManager
Why you think this problem is caused by the driver?
dulicate with 302292. This can be discussed at 302292.
