i have a quick question.
when i use “read” statement in pgf90 and execute, the result shows IOSTAT number 251.
what means IOSTAT=251 ?
thanx
%uname -a
Linux node3 2.6.9-67.ELsmp #1 SMP Fri Nov 16 12:49:06 EST 2007 x86_64 x86_64 x86_64 GNU/Linux
%pgf90 -V
pgf90 6.2-5 64-bit target on x86-64 Linux
Copyright 1989-2000, The Portland Group, Inc. All Rights Reserved.
Copyright 2000-2006, STMicroelectronics, Inc. All Rights Reserved.
Hi BJ.JUNG,
Sorry for the late reply. Message 251 means that you have an illegal character in your format string. In general, you can find out the meaning of these codes by either referring to the PGI User’s guide section called “Fortran Run-time Error Messages” or by adding a call to the function “get_iostat_msg(integer iostat, character* msg)” in your program. As of the 8.0 compilers we also added the F2003 IOMSG Specifier.
Hope this helps,
Mat
