hello:
When my multi-media api program starts, there is a chance that the following print will appear and it will not work properly.It will have a kernel syncpoint error
falcon 544c0000.nvenc: firmware, attempted to load /lib/firmware/tegra21x/nvhost_nvenc050.fw, but failed with error -4
falcon 544c0000.nvenc: Direct firmware load for tegra21x/nvhost_nvenc050.fw failed with error -4
falcon 544c0000.nvenc: Falling back to user helper
falcon 544c0000.nvenc: failed to get firmware
falcon 544c0000.nvenc: nvhost_flcn_init_sw: failed
bilities: Inappropriate ioctl for device
smmu_dump_pagetable(): fault_address=0x0000000000000000 pa=0xffffffffffffffff bytes=ffffffffffffffff #pte=0 in L2
mc-err: (11) csr_nvencsrd: EMEM decode error on PDE or PTE entry
mc-err: status = 0x6000001c; addr = 0x00000000
mc-err: secure: no, access-type: read, SMMU fault: nr-nw-s
I started a multi-channel encoder\decoder thread in my process, but added a thread lock when initializing the encoder/decoder device.
What is the cause of the problem and how to avoid it ?
Thanks a lot !
