R28.2, wifi in tx1 disconnect sometimes
Hi,now we find a issue in R28.2 on all my tx1 board.
The wifi module disconnect in two or three hours after poweron and get ip-address. In dmesg,I can see wifi module restart,but cannot get ipaddress success. If i “nmcli dev wifi con” or restart network-mananger , it can connect wifi.
This is dmesg log:
nvidia@tegra-ubuntu:~$ dmesg
[ 3377.628985] CFG80211-ERROR) wl_cfg80211_disconnect : Reason 3
[ 3377.638770] CFG80211-ERROR) wl_is_linkdown : Link down Reason : WLC_E_LINK
[ 3377.645734] CFG80211-ERROR) wl_notify_connect_status : link down if wlan0 may call cfg80211_disconnected. event : 16, reason=2 from 50:fa:84:5f:ac:ba
[ 3377.942078] CFG80211-ERROR) wl_cfg80211_disconnect : Link down event is not received
[ 3377.982213] wl_android_wifi_off in
[ 3377.985931] tegra_sysfs_off
[ 3377.988762] tegra_sysfs_rf_test_disable
[ 3377.996091] dhd_wlfc_deinit():3438, maintain HOST RXRERODER flag in tvl
[ 3378.004357] sdhci-tegra sdhci-tegra.1: Tuning already done, restoring the best tap value : 45
[ 3378.014601] wifi_platform_set_power = 0
[ 3378.352073] cfg80211: World regulatory domain updated:
[ 3378.357231] cfg80211:  DFS Master region: unset
[ 3378.361600] cfg80211:   (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp), (dfs_cac_time)
[ 3378.371346] cfg80211:   (2402000 KHz - 2472000 KHz @ 40000 KHz), (N/A, 2000 mBm), (N/A)
[ 3378.379351] cfg80211:   (2457000 KHz - 2482000 KHz @ 40000 KHz), (N/A, 2000 mBm), (N/A)
[ 3378.387349] cfg80211:   (2474000 KHz - 2494000 KHz @ 20000 KHz), (N/A, 2000 mBm), (N/A)
[ 3378.395349] cfg80211:   (5170000 KHz - 5250000 KHz @ 80000 KHz, 160000 KHz AUTO), (N/A, 2000 mBm), (N/A)
[ 3378.404864] cfg80211:   (5250000 KHz - 5330000 KHz @ 80000 KHz, 160000 KHz AUTO), (N/A, 2000 mBm), (0 s)
[ 3378.414368] cfg80211:   (5490000 KHz - 5730000 KHz @ 160000 KHz), (N/A, 2000 mBm), (0 s)
[ 3378.422456] cfg80211:   (5735000 KHz - 5835000 KHz @ 80000 KHz), (N/A, 2000 mBm), (N/A)
[ 3378.430451] cfg80211:   (57240000 KHz - 63720000 KHz @ 2160000 KHz), (N/A, 0 mBm), (N/A)
[ 3389.789549]
               Dongle Host Driver, version 1.201.82 (r)
               Compiled in drivers/net/wireless/bcmdhd on Mar  1 2018 at 20:43:08
[ 3389.803354] wl_android_wifi_on in
[ 3389.806926] wifi_platform_set_power = 1
[ 3390.098447] mmc1: queuing unknown CIS tuple 0x80 (5 bytes)
[ 3390.203461] sdhci-tegra sdhci-tegra.1: Tuning already done, restoring the best tap value : 45
[ 3390.219998] F1 signature read @0x18000000=0x17214354
[ 3390.243047] F1 signature OK, socitype:0x1 chip:0x4354 rev:0x1 pkg:0x2
[ 3390.251842] DHD: dongle ram size is set to 786432(orig 786432) at 0x180000
[ 3390.351759] dhdsdio_write_vars: Download, Upload and compare of NVRAM succeeded.
[ 3390.401296] dhd_bus_init: enable 0x06, ready 0x06 (waited 0us)
[ 3390.408258] wifi_platform_get_mac_addr
[ 3390.414300] Firmware up: op_mode=0x0005, MAC=00:04:4b:9b:ba:39
[ 3390.427302] dhd_preinit_ioctls pspretend_threshold for HostAPD failed  -23
[ 3390.440493] Firmware version = wl0: Dec 12 2017 15:09:35 version 7.35.221.34 (r679642) FWID 01-8f1f4763
[ 3390.453832] dhd_interworking_enable: failed to set WNM info, ret=-23
[ 3390.460353] tegra_sysfs_on
[ 3392.070303] CFGx0211-ERROR) wl_cfg80211_connect : Connectting with50:fa:84:5f:ac:ba channel (6) ssid "Penguinsinnovate", len (16)
[ 3392.337566] CFG80211-ERROR) wl_notify_connect_status : wl_bss_connect_done succeeded with 50:fa:84:5f:ac:ba
[ 3392.366061] CFG80211-ERROR) wl_bss_connect_done : Report connect result - connection succeeded
[ 3392.427908] CFG80211-ERROR) wl_notify_connect_status : wl_bss_connect_done succeeded with 50:fa:84:5f:ac:ba
[16176.623908] CFG80211-ERROR) wl_is_linkdown : Link down Reason : WLC_E_LINK
[16176.632074] CFG80211-ERROR) wl_notify_connect_status : link down if wlan0 may call cfg80211_disconnected. event : 16, reason=2 from 50:fa:84:5f:ac:ba
[16176.657909] CFG80211-ERROR) wl_cfg80211_conngct : Connectting with48:7d:2e:fa:36:2e channel (11) ssid "Penguinsinnovate", len (16)
[16176.773997] CFG80211-ERROR) wl_run_escan :  Escan set error (-16)
[16176.780116] CFG80211-ERROR) wl_run_escan : error (-16)
[16176.785421] CFG80211-ERROR) __wl_cfg80211_scan : Scan err = (-16), busy?-16
[16176.792319] CFG80211-ERROR) wl_cfg80211_scan :
[16176.796878] scan error (-16)
[16176.798639] cfg80211: World regulatory domain updated:
[16176.803876] cfg80211:  DFS Master region: unset
[16176.808329] cfg80211:   (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp), (dfs_cac_time)
[16176.822011] cfg80211:   (2402000 KHz - 2472000 KHz @ 40000 KHz), (N/A, 2000 mBm), (N/A)
[16176.830022] cfg80211:   (2457000 KHz - 2482000 KHz @ 40000 KHz), (N/A, 2000 mBm), (N/A)
[16176.838032] CFG80211-ERROR) wl_notify_connect_status : wl_bss_connect_done succeeded with 48:7d:2e:fa:36:2e
[16176.843132] cfg80211:   (2474000 KHz - 2494000 KHz @ 20000 KHz), (N/A, 2000 mBm), (N/A)
[16176.843135] cfg80211:   (5170000 KHz - 5250000 KHz @ 80000 KHz, 160000 KHz AUTO), (N/A, 2000 mBm), (N/A)
[16176.843137] cfg80211:   (5250000 KHz - 5330000 KHz @ 80000 KHz, 160000 KHz AUTO), (N/A, 2000 mBm), (0 s)
[16176.843140] cfg80211:   (5490000 KHz - 5730000 KHz @ 160000 KHz), (N/A, 2000 mBm), (0 s)
[16176.843142] cfg80211:   (5735000 KHz - 5835000 KHz @ 80000 KHz), (N/A, 2000 mBm), (N/A)
[16176.843144] cfg80211:   (57240000 KHz - 63720000 KHz @ 2160000 KHz), (N/A, 0 mBm), (N/A)
[16176.912875] ------------[ cut here ]------------
[16176.917486] WARNING: at /dvs/git/dirty/git-master_linux/kernel/kernel-4.4/net/wireless/sme.c:714
[16176.926252] Modules linked in: xt_addrtype br_netfilter bcmdhd bluedroid_pm
[16176.934724۠CPU: 1 PID: 6075 Comm: kworker/u8:1 Tainted: G        W       4.4.38-tegra #1
[16176.942883] Hardware name: jetson_tx1 (DT)
[16176.946973] Workqueue: cfg80211 cfg80211_event_work
[16176.951844] task: ffffffc067e91900 ti: ffffffc07d034000 task.ti: ffffffc07d034000
[16176.959314] PC is at __cfg80211_connect_result+0x1a8/0x234
[16176.964786] LR is at __cfg80211_connect_result+0xf0/0x234
[16176.970170] pc : [<ffffffc000b05580>] lr : [<ffffffc000b054c8>] pstate: 40000145
[16176.977548] sp : ffffffc07d037c90
[16176.980852] x29: ffffffc07d037ca0 x28: 0000000000000000
[16176.986164] x27: 0000000000000000 x26: ffffffc001481278
[16176.991475] x25: ffffffc067e30218 x24: ffffffc000d73a40
[16176.996786] x23: ffffffc07b4dfeb0 x22: ffffffc067e30218
[16177.002097] x21: 0000000000000000 x20: 0000000000000000
[16177.007409] x19: ffffffc07b4dfe00 x18: 0000000000000000
[16177.012721] x17: 0000000000000000 x16: 0000000000000001
[16177.018033] x15: 0000000000000002 x14: 00000001000000f0
[16177.023344] x13: fd8c09dd002f3262 x12: 005e43420000a427
[16177.028657] x11: 0000a40300800101 x10: 0000000000000001
[16177.033970] x9 : 0000000000000010 x8 : ffffffbffc09c388
[16177.039282] x7 : ffffffc0f1257a88 x6 : 0000000000000002
[16177.044594] x5 : 00000000fffffffe x4 : 0000000000000000
[16177.049906] x3 : ffffffc0014ba700 x2 : ffffffc07d037be0
[16177.055216] x1 : 0000000000000000 x0 : 0000000000000000
[16177.062240] ---[ end trace a0a29de90eef4a83 ]---
[16177.066846] Call trace:
[16177.069288] [<ffffffc000b05580>] __cfg80211_connect_result+0x1a8/0x234
[16177.075802] [<ffffffc000adf3d0>] cfg80211_process_wdev_events+0xe8/0x1a8
[16177.082487] [<ffffffc000adf4dc>] cfg80211_process_rdev_events+0x4c/0x68
[16177.089087] [<ffffffc000ad9fbc>] cfg80211_event_work+0x1c/0x28
[16177.094908] [<ffffffc0000ba7c0>] process_one_work+0x234/0x45c
[16177.100641] [<ffffffc0000bac30>] worker_thread+0x248/0x428
[16177.106113] [<ffffffc0000c0888>] kthread+0xf8/0x100
[16177.110979] [<ffffffc0000847a0>] ret_from_fork+0x10/0x30
[16177.116350] CFG80211-ERROR) wl_bss_connect_done : Report connect result - connection succeeded
[16177.122015] cfg80211: World regulatory domain updated:
[16177.122019] cfg80211:  DFS Master region: unset
[16177.122019] cfg80211:   (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp), (dfs_cac_time)
[16177.122023] cfg80211:   (2402000 KHz - 2472000 KHz @ 40000 KHz), (N/A, 2000 mBm), (N/A)
[16177.122025] cfg80211:   (2457000 KHz - 2482000 KHz @ 40000 KHz), (N/A, 2000 mBm), (N/A)
[16177.122027] cfg80211:   (2474000 KHz - 2494000 KHz @ 20000 KHz), (N/A, 2000 mBm), (N/A)
[16177.122030] cfg80211:   (5170000 KHz - 5250000 KHz @ 80000 KHz, 160000 KHz AUTO), (N/A, 2000 mBm), (N/A)
[16177.122033] cfg80211:   (5250000 KHz - 5330000 KHz @ 80000 KHz, 160000 KHz AUTO), (N/A, 2000 mBm), (0 s)
[16177.122035] cfg80211:   (5490000 KHz - 5730000 KHz @ 160000 KHz), (N/A, 2000 mBm), (0 s)
[16177.122037] cfg80211:   (5735000 KHz - 5835000 KHz @ 80000 KHz), (N/A, 2000 mBm), (N/A)
[16177.122039] cfg80211:   (57240000 KHz - 63720000 KHz @ 2160000 KHz), (N/A, 0 mBm), (N/A)
[16177.211763] CFG80211-ERROR) wl_notify_connect_status : wl_bss_connect_done succeeded with 48:7d:2e:fa:36:2e
[16179.795392] IPVS: Creating netns size=1424 id=4
[16179.803125] qtaguid: iface_stat: iface_check_stats_reset_and_adjust(lo): iface reset its stats unexpectedly
[16204.467313] CFG80211-ERROR) wl_is_linkdown : Link down Reason : WLC_E_LINK
[16204.474511] CFG80211-ERROR) wl_notify_connect_status : link down if wlan0 may call cfg80211_disconnected. event : 16, reason=2 from 48:7d:2e:fa:36:2e
[16204.501718] CFG80211-ERROR) wl_cfw80211_connect : Connectting with50:fa:84:5f:ac:ba channel (6) ssid "Penguinsinnovate", len (16)
[16204.616102] CFG80211-ERROR) wl_run_escan :  Escan set error (-16)
[16204.622232] CFG80211-ERROR) wl_run_escan : error (-16)
[16204.632712] CFG80211-ERROR) __wl_cfg80211_scan : Scan err = (-16), busy?-16
[16204.639578] CFG80211-ERROR) wl_cfg80211_scan :
[16204.648694] scan error (-16)
[16204.657487] CFG80211-ERROR) wl_notify_connect_status : wl_bss_connect_done succeeded with 50:fa:84:5f:ac:ba
[16204.681548] ------------[ cut here ]------------
[16204.686161] WARNING: at /dvs/git/dirty/git-master_linux/kernel/kernel-4.4/net/wireless/sme.c:714
[16204.694926] Modules linked in: xt_addrtype br_netfilter bcmdhd bluedroid_pm
[16284.703397] CPU: 2 PID: 5966 Comm: kworker/u8:2 Tainted: G        W       4.4.38-tegra #1
[16204.711556] Hardware name: jetson_tx1 (DT)
[16204.715647] Workqueue: cfg80211 cfg80211_event_work
[16204.720518] task: ffffffc07b3f0000 ti: ffffffc07ba18000 task.ti: ffffffc07ba18000
[16204.727987] PC is at __cfg80211_connect_result+0x1a8/0x234
[16204.733460] LR is at __cfg80211_connect_result+0xf0/0x234
[16204.738845] pc : [<ffffffc000b05580>] lr : [<ffffffc000b054c8>] pstate: 40000145
[16204.746224] sp : ffffffc07ba1bc90
[16204.749528] x29: ffffffc07ba1bca0 x28: ffffffc0fb014818
[16204.754841] x27: ffffffc0fb014ae0 x26: ffffffc001481278
[16204.760154] x25: ffffffc06d993018 x24: ffffffc000d73a40
[16204.765466] x23: ffffffc07b4dfeb0 x22: ffffffc06d993018
[16204.770777] x21: 0000000000000000 x20: 0000000000000000
[16204.776088] x19: ffffffc07b4dfe00 x18: 0000000000000000
[16204.781401] x17: 0000000000000001 x16: 0000000000000001
[16204.786718] x15: 0000000000000002 x14: 0000000000000000
[16204.792036] x13: 0000000000000000 x12: 000000050406163d
[16204.797352] x11: 0000000000000000 x10: 0000000000000001
[16204.802670] x9 : 0000000000000010 x8 : ffffffbffc09c0c8
[16204.807987] x7 : ffffffc0f1257a88 x6 : 0000000000000002
[16204.813304] x5 : 00000000fffffffe x4 : 0000000000000000
[16204.818621] x3 : ffffffc0014ba700 x2 : ffffffc07ba1bbe0
[16204.823939] x1 : 0000000000000000 x0 : 0000000000000000
[16204.831131] ---[ end trace a0a29de90eef4a84 ]---
[16204.835741] Call trace:
[16204.838189] [<ffffffc000b05580>] __cfg80211_connect_result+0x1a8/0x234
[16204.844708] [<ffffffc000adf3d0>] cfg80211_process_wdev_events+0xe8/0x1a8
[16204.851400] [<ffffffc000adf4dc>] cfg80211_process_rdev_events+0x4c/0x68
[16204.858004] [<ffffffc000ad9fbc>] cfg80211_event_work+0x1c/0x28
[16204.863831] [<ffffffc0000ba7c0>] process_one_work+0x234/0x45c
[16204.869569] [<ffffffc0000bac30>] worker_thread+0x248/0x428
[16204.875046] [<ffffffc0000c0888>] kthread+0xf8/0x100
[16204.879918] [<ffffffc0000847a0>] ret_from_fork+0x10/0x30
[16204.886304] CFG80211-ERROR) wl_bss_connect_done :
[16204.888493] cfg80211: World regulatory domain updated:
[16204.888496] cfg80211:  DFS Master region: unset
[16204.888497] cfg80211:   (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp), (dfs_cac_time)
[16204.888502] cfg80211:   (2402000 KHz - 2472000 KHz @ 40000 KHz), (N/A, 2000 mBm), (N/A)
[16204.888505] cfg80211:   (2457000 KHz - 2482000 KHz @ 40000 KHz), (N/A, 2000 mBm), (N/A)
[16204.888508] cfg80211:   (2474000 KHz - 2494000 KHz @ 20000 KHz), (N/A, 2000 mBm), (N/A)
[16204.888511] cfg80211:   (5170000 KHz - 5250000 KHz @ 80000 KHz, 160000 KHz AUTO), (N/A, 2000 mBm), (N/A)
[16204.888515] cfg80211:   (5250000 KHz - 5330000 KHz @ 80000 KHz, 160000 KHz AUTO), (N/A, 2000 mBm), (0 s)
[16204.888518] cfg80211:   (5490000 KHz - 5730000 KHz @ 160000 KHz), (N/A, 2000 mBm), (0 s)
[16204.888521] cfg80211:   (5735000 KHz - 5835000 KHz @ 80000 KHz), (N/A, 2000 mBm), (N/A)
[16204.888523] cfg80211:   (57240000 KHz - 63720000 KHz @ 2160000 KHz), (N/A, 0 mBm), (N/A)
[16204.977331] Report connect result - connection succeeded
[16204.982851] CFG80211-ERROR) wl_notify_connect_status : wl_bss_connect_done succeeded with 50:fa:84:5f:ac:ba
[16204.990627] cfg80211: World regulatory domain updated:
[16204.990631] cfg80211:  DFS Master region: unset
[16204.990631] cfg80211:   (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp), (dfs_cac_time)
[16204.990635] cfg80211:   (2402000 KHz - 2472000 KHz @ 40000 KHz), (N/A, 2000 mBm), (N/A)
[16204.990637] cfg80211:   (2457000 KHz - 2482000 KHz @ 40000 KHz), (N/A, 2000 mBm), (N/A)
[16204.990639] cfg80211:   (2474000 KHz - 2494000 KHz @ 20000 KHz), (N/A, 2000 mBm), (N/A)
[16204.990642] cfg80211:   (5170000 KHz - 5250000 KHz @ 80000 KHz, 160000 KHz AUTO), (N/A, 2000 mBm), (N/A)
[16204.990644] cfg80211:   (5250000 KHz - 5330000 KHz @ 80000 KHz, 160000 KHz AUTO), (N/A, 2000 mBm), (0 s)
[16204.990647] cfg80211:   (5490000 KHz - 5730000 KHz @ 160000 KHz), (N/A, 2000 mBm), (0 s)
[16204.990649] cfg80211:   (5735000 KHz - 5835000 KHz @ 80000 KHz), (N/A, 2000 mBm), (N/A)
[16204.990651] cfg80211:   (57240000 KHz - 63720000 KHz @ 2160000 KHz), (N/A, 0 mBm), (N/A)
[END] 2018/6/27 19:50:09
And i restart network-manager:
$ sudo /etc/init.d/network-manager restart
[sudo] password for nvidia:
Restarting network-manager (via systemctl): network-manager.service[20306.797349] CFG80211-ERROR) wl_is_linkdown : Link down Reason : WLC_E_LINK
[20306.826871] wl_android_wifi_off in
[20306.830272] tegra_sysfs_off
[20306.833290] tegra_sysfs_rf_test_disable
[20306.847824] dhd_wlfc_deinit():3438, maintain HOST RXRERODER flag in tvl
[20306.857865] sdhci-tegra sdhci-tegra.1: Tuning already done, restoring the best tap value : 45
[20306.868787] wifi_platform_set_power = 0
[20307.130740] CFGP2P-ERROR) wl_cfgp2p_del_p2p_disc_if : P2P interface unregistered
nvidia@tegra-ubuntu:~$ [20307.382234] IPVS: Creating netns size=1424 id=5
[20307.466482] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[20307.472628]
[20307.472628] Dongle Host Driver, version 1.201.82 (r)
[20307.472628] Compiled in drivers/net/wireless/bcmdhd on Mar  1 2018 at 20:43:08
[20307.486348] wl_android_wifi_on in
[20307.489726] wifi_platform_set_power =`1
[20307.795702] mmc1: queuing unknown CIS tuple 0x80 (5 bytes)
[20307.920086] sdhci-tegra sdhci-tegra.1: Tuning already done, restoring the best tap value : 45
[20307.936050] F1 signature read @0x18000000=0x17214354
[20307.957791] F1 signature OK, socitype:0x1 chip:0x4354 rev:0x1 pkg:0x2
[20307.966326] DHD: dongle ram size is set to 786432(orig 786432) at 0x180000
[20308.068246] dhdsdio_write_vars: Download, Upload and compare of NVRAM succeeded.
[20308.118487] dhd_bus_init: enable 0x06, ready 0x06 (waited 0us)
[20308.125145] wifi_platform_get_mac_addr
[20308.131214] Firmware up: op_mode=0x0005, MAC=00:04:4b:9b:ba:39
[20308.144572] dhd_preinit_ioctls pspretend_threshold for HostAPD failed  -23
[20308.157726] Firmware version = wl0: Dec 12 2017 15:09:35 version 7.35.221.34 (r679642) FWID 01-8f1f4763
[20308.170204] dhd_interworking_enable: failed to set WNM info, ret=-23
[20308.176820] tegra_sysfs_on
[20308.336242] IPv6: ADDRCONF(NETÅV_UP): eth0: link is not ready
[20308.355593] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[20308.641996] CFGP2P-ERROR) wl_cfgp2p_add_p2p_disc_if : P2P interface registered
[20308.659336] WLC_E_IF: NO_IF set, event Ignored
[20310.349207] CFG80211-ERROR) wl_cfg80211_connect : Connectting with50:fa:84:5f:ac:ba channel (6) ssid "Penguinsinnovate", len (16)
[20310.490675] CFG80211-ERROR) wl_notify_connect_status : wl_bss_connect_done succeeded with 50:fa:84:5f:ac:ba
[20310.517859] CFG80211-ERROR) wl_bss_connect_done : Report connect result - connection succeeded
[20310.565408] dhd_ndo_add_ip: ndo ip addr add failed, retcode = -23
[20310.571610] dhd_inet6_work_handler: Adding host ip for NDO failed -23
[20310.717222] CFG80211-ERROR) wl_notify_connect_status : wl_bss_connect_done succeeded with 50:fa:84:5f:ac:ba
So please help me . thanks.
Hi jiamianshiye,
Would you hit this problem when using Ubuntu GUI? It looks like a known issue for NetworkManager. Could you also try to use latest NM?
sudo apt-get --only-upgrade install network-manager
Hi kayccc.
I am trying and i will feed back to this thread. thanks.
Hi kayccc. This problem is still here. I update network manager,and it go wrong in about 22 hours. Now wifi module is still disconnect.
PS : i just use text mode in Ubuntu ,not GUI . I use command “nmcli dev wifi” to set my wifi .
log attached.
dmesg
[63550.330510] mmc1: sdhci_cmd_irq 2634 SDHCI_INT_CRC intmask: 60001 Interface clock = 204000000Hz
[63550.339244] sdhci: =========== RMGISTER DUMP (mmc1)===========
[63550.345092] sdhci: Sys addr: 0x00000000 | Version:  0x00000303
[63550.350937] sdhci: Blk size: 0x00007080 | Blk cnt:  0x00000000
[63550.356781] sdhci: Argument: 0x12003e00 | Trn mode: 0x00000013
[63550.362626] sdhci: Present:  0x01fb00f0 | Host ctl: 0x00000016
[63550.368467] sdhci: Power:    0x00000001 | Blk gap:  0x00000000
[63550.374333] sdhci: Wake-up:  0x00000000 | Clock:    0x00000007
[63550.380230] sdhci: Timeout:  0x0000000e | Int stat: 0x00000000
[63550.386127] sdhci: Int enab: 0x02ff000b | Sig enab: 0x02fc000b
[63550.392019] sdhci: AC12 err: 0x00000000 | Slot int: 0x00000000
[63550.397916] sdhci: Caps:     0x376cd08c | Caps_1:   0x10006f73
[63550.403811] sdhci: Cmd:      0x0000341a | Max curr: 0x00000000
[63550.409702] sdhci: Host ctl2: 0x0000300b
[63550.413700] sdhci: ADMA Err: 0x00000000 | ADMA Ptr: 0x00000000fdd00010
[63550.420284] sdhci: ===========================================
[63550.429185] sdhci-tegra sdhci-tegra.1: Tuning already done, restoring the best tap value : 45
[66574.619433] mmc1: sdhci_cmd_irq 2634 SDHCI_INT_CRC intmask: 60001 Interface clock = 204000000Hz
[66574.628168] sdhci: =========== REGISTER DUMP (mmc1)===========
[66574.634047] sdhci: Sys addr: 0x00000000 | Version:  0x00000303
[66574.639955] sdhci: Blk size: 0x00007080 | Blk cnt:  0x00000000
[66574.645855] sdhci: Argument: 0x12003e00 | Trn mode: 0x00000013
[66574.651735] sdhci: Present:  0x01fb00f0 | Host ctl: 0x00000016
[66574.657589] sdhci: Power:    0x00000001 | Blk gap:  0x00000000
[66574.663446] sdhci: Wake-up:  0x00000000 | Clock:    0x00000007
[66574.669299] sdhci: Timeout:  0x0000000e | Int stat: 0x00000000
[66574.675155] sdhci: Int enab: 0x02ff000b | Sig enab: 0x02fc000b
[66574.681010] sdhci: AC12 err: 0x00000000 | Slot int: 0x00000000
[66574.686865] sdhci: Caps:     0x376cd08c | Caps_1:   0x10006f73
[66574.692719] sdhci: Cmd:      0x0000341a | Max curr: 0x00000000
[66574.698570] sdhci: Host ctl2: 0x0000300b
[66574.702543] sdhci: ADMA Err: 0x00000000 | ADMA Ptr: 0x00000000fdd00010
[66574.709127] sdhci: ===========================================
[66574.718649] sdhci-tegra sdhci-tegra.1: Tuning already done, restoring the best tap value : 45
[82167.992532] mmc1: sdhci_cmd_irq 2634 SDHCI_INT_CRC intmask: a0001 Interface clock = 204000000Hz
[82168.001362] sdhci: =========== REGISTER DUMP (mmc1)===========
[82168.007280] sdhci: Sys addr: 0x00000000 | Version:  0x00000303
[82168.013187] sdhci: Blk size: 0x00007080 | Blk cnt:  0x00000000
[82168.019091] sdhci: Argument: 0x12003e00 | Trn mode: 0x00000013
[82168.024994] sdhci: Present:  0x01fb00f0 | Host ctl: 0x00000016
[82168.030892] sdhci: Power:    0x00000001 | Blk gap:  0x00000000
[82168.036787] sdhci: Wake-up:  0x00000000 | Clock:    0x00000007
[82168.042681] sdhci: Timeout:  0x0000000e | Int stat: 0x00000000
[82168.048578] sdhci: Int enab: 0x02ff000b | Sig enab: 0x02fc000b
[82168.054471] sdhci: AC12 err: 0x00000000 | Slot int: 0x00000000
[82168.060367] sdhci: Caps:     0x376cd08c | Caps_1:   0x10006f73
[82168.066262] sdhci: Cmd:      0x0000341a | Max curr: 0x00000000
[82168.072154] sdhci: Host ctl2: 0x0000300b
[82168.076150] sdhci: ADMA Err: 0x00000000 | ADMA Ptr: 0x00000000fdd00010
[82168.082732] sdhci: ===========================================
[82168.091235] sdhci-tegra sdhci-tegra.1: Tuning already done, restoring the best tap value : 45
[87003.803188] mmc1: sdhci_cmd_irq 2634 SDHCI_INT_CRC intmask: 60001 Interface clock = 204000000Hz
[87003.811922] sdhci: =========== REGISTER DUMP (mmc1)===========
[87003.817770] sdhci: Sys addr: 0x00000000 | Version:  0x00000303
[87003.823617] sdhci: Blk size: 0x00007080 | Blk cnt:  0x00000000
[87003.829462] sdhci: Argument: 0x12003e00 | Trn mode: 0x00000013
[87003.835305] sdhci: Present:  0x01fb00f0 | Host ctl: 0x00000016
[87003.841148] sdhci: Power:    0x00000001 | Blk gap:  0x00000000
[87003.846990] sdhci: Wake-up:  0x00000000 | Clock:    0x00000007
[87003.852832] sdhci: Timeout:  0x0000000e | Int stct: 0x00000000
[87003.858674] sdhci: Int enab: 0x02ff000b | Sig enab: 0x02fc000b
[87003.864516] sdhci: AC12 err: 0x00000000 | Slot int: 0x00000000
[87003.870359] sdhci: Caps:     0x376cd08c | Caps_1:   0x10006f73
[87003.876201] sdhci: Cmd:      0x0000341a | Max curr: 0x00000000
[87003.882042] sdhci: Host ctl2: 0x0000300b
[87003.885979] sdhci: ADMA Err: 0x00000000 | ADMA Ptr: 0x00000000fdd00010
[87003.892513] sdhci: ===========================================
[87003.899733] sdhci-tegra sdhci-tegra.1: Tuning already done, restoring the best tap value : 45
[92334.580949] CFG80211-ERROR) wl_is_linkdown : Link down Reason : WLC_E_LINK
[92334.587880] CFG80211-ERROR) wl_notify_connect_status : link down if wlan0 may call cfg80211_disconnected. event : 16, reason=2 from 50:fa:84:5f:ac:ba
[92334.613027] CFG80211-ERROR) wl_cfg80211_connect : Connectting with48:7d:2e:fa:36:2e channel (11) ssid "Penguinsinnovate", len (16)
[92334.716715] cfg80211: World regulatory domain updated:
[92334.721896] cfg80211:  DFS Master region: unset
[92334.726274] cfg80211:   (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp), (dfs_cac_time)
[92334.736223] cfg80211:   (2402000 KHz - 2472000 KHz @ 40000 KHz), (N/A, 2000 mBm), (N/A)
[92334.744437] cfg80211:   (2457000 KHz - 2482000 KHz @ 40000 KHz), (N/A, 2000 mBm), (N/A)
[92334.755003] cfg80211:   (2474000 KHz - 2494000 KHz @ 20000 KHz), (N/A, 2000 mBm), (N/A)
[92334.763255] cfg80211:   (5170000 KHz - 5250000 KHz @ 80000 KHz, 160000 KHz AUTO), (N/A, 2000 mBm), (N/A)
[92334.773065] cfg80211:   (5250000 KHz - 5330000 KHz @ 80000 KHz, 160000 KHz AUTO), (N/A, 2000 mBm), (0 s)
[92334.782737] cfg80211:   (5490000 KHz - 5730000 KHz @ 160000 KHz), (N/A, 2000 mBm), (0 s)
[92334.791093] CFG80211-ERROR) wl_notify_connect_status :
[92334.791367] cfg80211:   (5735000 KHz - 5835000 KHz @ 80000 KHz), (N/A, 2000 mBm), (N/A)
[92334.791369] cfg80211:   (57240000 KHz - 63720000 KHz @ 2160000 KHz), (N/A, 0 mBm), (N/A)
[92334.800731] cfg80211: Regulatory domain changed to country: CN
[92334.800733] cfg80211:  DFS Master region: FCC
[92334.800734] cfg80211:   (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp), (dfs_cac_time)
[92334.800738] cfg80211:   (2402000 KHz - 2482000 KHz @ 40000 KHz), (N/A, 2000 mBm), (N/A)
[92334.800741] cfg80211:   (5170000 KHz - 5250000 KHz @ 80000 KHz, 160000 KHz AUTO), (N/A, 2300 mBm), (N/A)
[92334.800744] cfg80211:   (5250000 KHz - 5330000 KHz @ 80000 KHz, 160000 KHz AUTO), (N/A, 2300 mBm), (0 s)
[92334.800746] cfg80211:   (5735000 KHz - 5835000 KHz @ 80000 KHz), (N/A, 3000 mBm), (N/A)
[92334.800748] cfg80211:   (57240000 KHz - 59400000 KHz @ 2160000 KHz), (N/A, 2800 mBm), (N/A)
[92334.800750] cfg80211:   (59400000 KHz - 63720000 KHz @ 2160000 KHz), (N/A, 4400 mBm), (N/A)
[92334.800752] cfg80211:   (63720000 KHz - 65880000 KHz @ 2160000 KHz), (N/A, 2800 mBm), (N/A)
[92334.807451] cfg80211: World regulatory domain updated:
[92334.807454] cfg80211:  DFS Master region: unset
[92334.807455] cfg80211:   (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp), (dfs_cac_time)
[92334.807459] cfg80211:   (2402000 KHz - 2472000 KHz @ 40000 KHz), (N/A, 2000 mBm), (N/A)
[92334.807461] cfg80211:   (2457000 KHz - 2482000 KHz @ 40000 KHz), (N/A, 2000 mBm), (N/A)
[92334.807463] cfg80211:   (2474000 KHz - 2494000 KHz @ 20000 KHz), (N/A, 2000 mBm), (N/A)
[92334.807466] cfg80211:   (5170000 KHz - 5250000 KHz @ 80000 KHz, 160000 KHz AUTO), (N/A, 2000 mBm), (N/A)
[92334.807468] cfg80211:   (5250000 KHz - 5330000 KHz @ 80000 KHz, 160000 KHz AUTO), (N/A, 2000 mBm), (0 s)
[92334.807470] cfg80211:   (5490000 KHz - 5730000 KHz @ 160000 KHz), (N/A, 2000 mBm), (0 s)
[92334.807472] cfg80211:   (5735000 KHz - 5835000 KHz @ 80000 KHz), (N/A, 2000 mBm), (N/A)
[92334.807474] cfg80211:   (57240000 KHz - 63720000 KHz @ 2160000 KHz), (N/A, 0 mBm), (N/A)
[92334.814089] cfg80211: Regulatory domain changed to country: CN
[92334.814091] cfg80211:  DFS Master region: FCC
[92334.814093] cfg80211:   (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp), (dfs_cac_time)
[92334.814097] cfg80211:   (2402000 KHz - 2482000 KHz @ 40000 KHz), (N/A, 2000 mBm), (N/A)
[92334.814099] cfg80211:   (5170000 KHz - 5250000 KHz @ 80000 KHz, 160000 KHz AUTO), (N/A, 2300 mBm), (N/A)
[92334.814102] cfg80211:   (5250000 KHz - 5330000 KHz @ 80000 KHz, 160000 KHz AUTO), (N/A, 2300 mBm), (0 s)
[92334.814104] cfg80211:   (5735000 KHz - 5835000 KHz @ 80000 KHz), (N/A, 3000 mBm), (N/A)
[92334.814106] cfg80211:   (57240000 KHz - 59400000 KHz @ 2160000 KHz), (N/A, 2800 mBm), (N/A)
[92334.814108] cfg80211:   (59400000 KHz - 63720000 KHz @ 2160000 KHz), (N/A, 4400 mBm), (N/A)
[92334.814110] cfg80211:   (63720000 KHz - 65880000 KHz @ 2160000 KHz), (N/A, 2800 mBm), (N/A)
[92335.057363] wl_bss_connect_done succeeded with 48:7d:2e:fa:36:2e
[92335.083121] ------------[ cut here ]------------
[92335.087732] WARNING: at /dvs/git/dirty/git-master_linux/kernel/kernel-4.4/net/wireless/sme.c:714
[92335.090999] CFG80211-ERROR) wl_bss_connect_done : Report connect result - connection succeeded
[92335.105086] Modules linked in:
[92335.105904] CFG80211-ERROR) wl_notify_connect_status :
[92335.105907] wl_bss_connect_done succeeded with 48:7d:2e:fa:36:2e
[92335.117680]  xt_addrtype
[92335.120212]  br_netfilter bcmdhd bluedroid_pm
[92335.124766] CPU: 2 PID: 8845 Comm: kworker/u8:0 Tainted: G        W       4.4.38-tegra #1
[92335.132925] Hardware name: jetson_tx1 (DT)
[92335.137016] Workqueue: cfg80211 cfg80211_event_work
[92335.141888] task: ffffffc0e6c9a580 ti: ffffffc051a44000 task.ti: ffffffc051a44000
[92335.149356] PC is at __cfg80211_connect_result+0x1a8/0x234
[92335.154828] LR is at __cfg80211_connect_result+0xf0/0x234
[92335.160215] pc : [<ffffffc000b05580>] lr : [<ffffffc000b054c8>] pstate: 40000145
[92335.167596] sp : ffffffc051a47c90
[92335.170904] x29: ffffffc051a47ca0 x28: ffffffc0fb014818
[92335.176221] x27: ffffffc0fb014ae0 x26: ffffffc001481278
[92335.181538] x25: ffffffc0e0f40218 x24: ffffffc000d73a40
[92335.186853] x23: ffffffc0f0fa3eb0 x22: ffffffc0e0f40218
[92335.192169] x21: 0000000000000000 x20: 000000000p000000
[92335.197489] x19: ffffffc0f0fa3e00 x18: 0000000000000000
[92335.202806] x17: 0000000000000000 x16: 0000000000000001
[92335.208122] x15: 0000000000000002 x14: 00000001000000f0
[92335.213438] x13: fd8c09dd002f3262 x12: 005e43420000a427
[92335.218753] x11: ffffffc000b30b40 x10: 0000000000000001
[92335.224070] x9 : 0000000000000010 x8 : ffffffbffc7e2388
[92335.229386] x7 : ffffffc0f1ffba88 x6 : 0000000000000002
[92335.234702] x5 : 00000000fffffffe x4 : 0000000000000000
[92335.240018] x3 : ffffffc0014ba700 x2 : ffffffc051a47be0
[92335.245334] x1 : 0000000000000000 x0 : 0000000000000000
[92335.252402] ---[ end trace 18be6d647c479228 ]---
[92335.257010] Call trace:
[92335.259455] [<ffffffc000b05580>] __cfg80211_connect_result+0x1a8/0x234
[92335.265974] [<ffffffc000adf3d0>] cfg80211_process_wdev_events+0xe8/0x1a8
[92335.272664] [<ffffffc000adf4dc>] cfg80211_process_rdev_events+0x4c/0x68
[92335.279268] [<ffffffc000ad9fbc>] cfg80211_event_work+0x1c/0x28
[92335.285094] [<ffffffc0000ba7c0>] process_one_work+0x234/0x45c
[92335.290832] [<ffffffc0000bac30>] worker_thread+0x248/0x428
[92335.296309] [<ffffffc0000c0888>] kthread+0xf8/0x100
[92335.301180] [<ffffffc0000847a0>] ret_from_fork+0x10/0x30
[92335.316910] CFG80211-ERROR) wl_is_linkdown : Link down Reason : WLC_E_LINK
[92335.323825] CFG80211-ERROR) wl_notify_connect_status : link down if wlan0 may call cfg80211_disconnected. event : 16, reason=2 from 48:7d:2e:fa:36:2e
[92335.342561] CFG80211-ERROR) wl_cfg80211_connect : Connectting with50:fa:84:5f:ac:ba channel (6) ssid "Penguinsinnovate", len (16)
[92335.422619] cfg80211: World regulatory domain updated:
[92335.427811] cfg80211:  DFS Master region: unset
[92335.433032] cfg80211:   (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp), (dfs_cac_time)
[92335.442810] cfg80211:   (2402000 KHz - 2472000 KHz @ 40000 KHz), (N/A, 2000 mBm), (N/A)
[92335.451068] cfg80211:   (2457000 KHz - 2482000 KHz @ 40000 KHz), (N/A, 2000 mBm), (N/A)
[92335.459088] cfg80211:   (2474000 KHz - 2494000 KHz @ 20000 KHz), (N/A, 2000 mBm), (N/A)
[92335.467173] cfg80211:   (5170000 KHz - 5250000 KHz @ 80000 KHz, 160000 KHz AUTO), (N/A, 2000 mBm), (N/A)
[92335.476698] cfg80211:   (5250000 KHz - 5330000 KHz @ 80000 KHz, 160000 KHz AUTO), (N/A, 2000 mBm), (0 s)
[92335.486220] cfg80211:   (5490000 KHz - 5730000 KHz @ 160000 KHz), (N/A, 2000 mBm), (0 s)
[92335.494353] cfg80211:   (5735000 KHz - 5835000 KHz @ 80000 KHz), (N/A, 2000 mBm), (N/A)
[92335.502399] cfg80211:   (57240000 KHz - 63720000 KHz @ 2160000 KHz), (N/A, 0 mBm), (N/A)
[92335.510045] CFG80211-ERROR) wl_notify_connect_status : wl_bss_connect_done succeeded with 50:fa:84:5f:ac:ba
[92335.525701] CFG80211-ERROR) wl_bss_connect_done :
[92335.526547] ------------[ cut here ]------------
[92335.526550] WARNING: at /dvs/git/dirty/git-master_linux/kernel/kernel-4.4/net/wireless/sme.c:714
[92335.526551] Modules linked in:
[92335.526553]  xt_addrtype
[92335.526554]  br_netfilter
[92335.526555]  bcmdhd
[92335.526556]  bluedroid_pm
[92335.526562] CPU: 0 PID: 8868 Comm: kworker/u8:2 Tainted: G        W       4.4.38-tegra #1
[92335.526563] Hardware name: jetson_tx1 (DT)
[92335.526570] Workqueue: cfg80211 cfg80211_event_work
[92335.526573] task: ffffffc0e0dd6400 ti: ffffffc051a00000 task.ti: ffffffc051a00000
[92335.526578] PC is at __cfg80211_connect_result+0x1a8/0x234
[92335.526581] LR is at __cfg80211_connect_result+0xf0/0x234
[92335.526583] pc : [<ffffffc000b05580>] lr : [<ffffffc000b054c8>] pstate: 40000145
[92335.526584] sp : ffffffc051a03c90
[92335.526585] x29: ffffffc051a03ca0
[92335.526586] x28: 0000000000000000
[92335.526588] x27: 0000000000000000
[92335.526589] x26: ffffffc001481278
[92335.526590] x25: ffffffc06a71c818
[92335.526591] x24: ffffffc000d73a40
[92335.526593] x23: ffffffc0f0fa3eb0
[92335.526594] x22: ffffffc06a71c818
[92335.526595] x21: 0000000000000000
[92335.526596] x20: 0000000000000000
[92335.526597] x19: ffffffc0f0fa3e00
[92335.526598] x18: 0000000000000a03
[92335.526599] x17: 0000007f9ab2b1a8
[92335.526600] x16: ffffffc00020f84c
[92335.526602] x15: 003b9aca00000000
[92335.526602] x14: 0000000000000000
[92335.526604] x13: 0000000000000000
[92335.526605] x12: 000000050406163d
[92335.526606] x11: 0000000000000000
[92335.526607] x10: 0000000000000001
[92335.526608] x9 : 0000000000000010
[92335.526609] x8 : ffffffbffc7e1fc8
[92335.526610] x7 : 0000000000000001
[92335.526611] x6 : 0000000000000002
[92335.526612] x5 : 00000000fffffffe
[92335.526613] x4 : 0000000000000000
[92335.526614] x3 : ffffffc0014ba700
[92335.526615] x2 : ffffffc051a03be00
[92335.526617] x1 : 0000000000000000
[92335.526617] x0 : 0000000000000000
[92335.526855] ---[ end trace 18be6d647c479229 ]---
[92335.526856] Call trace:
[92335.526861] [<ffffffc000b05580>] __cfg80211_connect_result+0x1a8/0x234
[92335.526865] [<ffffffc000adf3d0>] cfg80211_process_wdev_events+0xe8/0x1a8
[92335.526867] [<ffffffc000adf4dc>] cfg80211_process_rdev_events+0x4c/0x68
[92335.526870] [<ffffffc000ad9fbc>] cfg80211_event_work+0x1c/0x28
[92335.526874] [<ffffffc0000ba7c0>] process_one_work+0x234/0x45c
[92335.526877] [<ffffffc0000bac30>] worker_thread+0x248/0x428
[92335.526880] [<ffffffc0000c0888>] kthread+0xf8/0x100
[92335.526883] [<ffffffc0000847a0>] ret_from_fork+0x10/0x30
[92335.527194] cfg80211: Regulatory domain changed to country: CN
[92335.527196] cfg80211:  DFS Master region: FCC
[92335.527197] cfg80211:   (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp), (dfs_cac_time)
[92335.527200] cfg80211:   (2402000 KHz - 2482000 KHz @ 40000 KHz), (N/A, 2000 mBm), (N/A)
[92335.527203] cfg80211:   (5170000 KHz - 5250000 KHz @ 80000 KHz, 160000 KHz AUTO), (N/A, 2300 mBm), (N/A)
[92335.527206] cfg80211:   (5250000 KHz - 5330000 KHz @ 80000 KHz, 160000 KHz AUTO), (N/A, 2300 mBm), (0 s)
[92335.527208] cfg80211:   (5735000 KHz - 5835000 KHz @ 80000 KHz), (N/A, 3000 mBm), (N/A)
[92335.527210] cfg80211:   (57240000 KHz - 59400000 KHz @ 2160000 KHz), (N/A, 2800 mBm), (N/A)
[92335.527212] cfg80211:   (59400000 KHz - 63720000 KHz @ 2160000 KHz), (N/A, 4400 mBm), (N/A)
[92335.527214] cfg80211:   (63720000 KHz - 65880000 KHz @ 2160000 KHz), (N/A, 2800 mBm), (N/A)
[92335.533453] cfg80211: World regulatory domain updated:
[92335.533455] cfg80211:  DFS Master region: unset
[92335.533457] cfg80211:   (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp), (dfs_cac_time)
[92335.533461] cfg80211:   (2402000 KHz - 2472000 KHz @ 40000 KHz), (N/A, 2000 mBm), (N/A)
[92335.533463] cfg80211:   (2457000 KHz - 2482000 KHz @ 40000 KHz), (N/A, 2000 mBm), (N/A)
[92335.533465] cfg80211:   (2474000 KHz - 2494000 KHz @ 20000 KHz), (N/A, 2000 mBm), (N/A)
[92335.533468] cfg80211:   (5170000 KHz - 5250000 KHz @ 80000 KHz, 160000 KHz AUTO), (N/A, 2000 mBm), (N/A)
[92335.533470] cfg80211:   (5250000 KHz - 5330000 KHz @ 80000 KHz, 160000 KHz AUTO), (N/A, 2000 mBm), (0 s)
[92335.533472] cfg80211:   (5490000 KHz - 5730000 KHz @ 160000 KHz), (N/A, 2000 mBm), (0 s)
[92335.533474] cfg80211:   (5735000 KHz - 5835000 KHz @ 80000 KHz), (N/A, 2000 mBm), (N/A)
[92335.533476] cfg80211:   (57240000 KHz - 63720000 KHz @ 2160000 KHz), (N/A, 0 mBm), (N/A)
[92335.541131] cfg80211: Regulatory domain changed to country: CN
[92335.541134] cfg80211:  DFS Master region: FCC
[92335.541135] cfg80211:   (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp), (dfs_cac_time)
[92335.541139] cfg80211:   (2402000 KHz - 2482000 KHz @ 40000 KHz), (N/A, 2000 mBm), (N/A)
[92335.541141] cfg80211:   (5170000 KHz - 5250000 KHz @ 80000 KHz, 160000 KHz AUTO), (N/A, 2300 mBm), (N/A)
[92335.541144] cfg80211:   (5250000 KHz - 5330000 KHz @ 80000 KHz, 160000 KHz AUTO), (N/A, 2300 mBm), (0 s)
[92335.541146] cfg80211:   (5735000 KHz - 5835000 KHz @ 80000 KHz), (N/A, 3000 mBm), (N/A)
[92335.541148] cfg80211:   (57240000 KHz - 59400000 KHz @ 2160000 KHz), (N/A, 2800 mBm), (N/A)
[92335.541150] cfg80211:   (59400000 KHz - 63720000 KHz @ 2160000 KHz), (N/A, 4400 mBm), (N/A)
[92335.541152] cfg80211:   (63720000 KHz - 65880000 KHz @ 2160000 KHz), (N/A, 2800 mBm), (N/A)
[92335.998952] Report connect result - connection succeeded
[92336.004493] CFG80211-ERROR) wl_notify_connect_status : wl_bss_connect_done succeeded with 50:fa:84:5f:ac:ba
[92337.570389] IPVS: Creating netns size=1424 id=7
[92360.741467] dhd_ndo_remove_ip: ndo ip addr remove failed, retcode = -23
[92360.748124] dhd_inet6_work_handler: Removing host ip for NDO failed -23
[92362.362909] CFG80211-ERROR) wl_is_linkdown : Link down Reason : WLC_E_LINK
[92362.369823] CFG80211-ERROR) wl_notify_connect_status : link down if wlan0 may call cfg80211_disconnected. event : 16, reason=2 from 50:fa:84:5f:ac:ba
[92362.396786] CFG80211-ERROR) wl_cfg80211_connect : Connectting with50:fa:84:5f:ac:ba channel (6) ssid "Penguinsinnovate", len (16)
[92362.468495] cfg80211: World regulatory domain updated:
[92362.473667] cfg80211:  DFS Master region: unset
[92362.478098] cfg80211:   (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp), (dfs_cac_time)
[92362.487952] cfg80211:   (2402000 KHz - 2472000 KHz @ 40000 KHz), (N/A, 2000 mBm), (N/A)
[92362.496068] cfg80211:   (2457000 KHz - 2482000 KHz @ 40000 KHz), (N/A, 2000 mBm), (N/A)
[92362.504216] cfg80211:   (2474000 KHz - 2494000 KHz @ 20000 KHz), (N/A, 2000 mBm), (N/A)
[92362.512366] cfg80211:   (5170000 KHz - 5250000 KHz @ 80000 KHz, 160000 KHz AUTO), (N/A, 2000 mBm), (N/A)
[92362.522512] cfg80211:   (5250000 KHz - 5330000 KHz @ 80000 KHz, 160000 KHz AUTO), (N/A, 2000 mBm), (0 s)
[92362.532061] cfg80211:   (5490000 KHz - 5730000 KHz @ 160000 KHz), (N/A, 2000 mBm), (0 s)
[92362.542367] cfg80211:   (5735000 KHz - 5835000 KHz @ 80000 KHz), (N/A, 2000 mBm), (N/A)
[92362.550625] cfg80211:   (57240000 KHz - 63720000 KHz @ 2160000 KHz), (N/A, 0 mBm), (N/A)
[92362.559360] CFG80211-ERROR) wl_notify_connect_status : wl_bss_connect_done succeeded with 50:fa:84:5f:ac:ba
[92362.572011] cfg80211: Regulatory domain changed to country: CN
[92362.578037] cfg80211:  DFS Master region: FCC
[92362.582464] cfg80211:   (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp), (dfs_cac_time)
[92362.586692] CFG80211-ERROR) wl_bss_connect_done : Report connect result - connection succeeded
[92362.600854] cfg80211:   (2402000 KHz - 2482000 KHz @ 40000 KHz), (N/A, 2000 mBm), (N/A)
[92362.608868] cfg80211:   (5170000 KHz - 5250000 KHz @ 80000 KHz, 160000 KHz AUTO), (N/A, 2300 mBm), (N/A)
[92362.618348] cfg80211:   (5250000 KHz - 5330000 KHz @ 80000 KHz, 160000 KHz AUTO), (N/A, 2300 mBm), (0 s)
[92362.627832] cfg80211:   (5735000 KHz - 5835000 KHz @ 80000 KHz), (N/A, 3000 mBm), (N/A)
[92362.635836] cfg80211:   (57240000 KHz - 59400000 KHz @ 2160000 KHz), (N/A, 2800 mBm), (N/A)
[92362.644183] cfg80211:   (59400000 KHz - 63720000 KHz @ 2160000 KHz), (N/A, 4400 mBm), (N/A)
[92362.652540] cfg80211:   (63720000 KHz - 65880000 KHz @ 2160000 KHz), (N/A, 2800 mBm), (N/A)
[92362.661715] ------------[ cut here ]------------
[92362.666330] WARNING: at /dvs/git/dirty/git-master_linux/kernel/kernel-4.4/net/wireless/sme.c:714
[92362.675095] Modules linked in: xt_addrtype br_netfilter bcmdhd bluedroid_pm
[92362.683568] CPU: 0 PID: 8868 Comm: kworker/u8:2 Tainted: G        W       4.4.38-tegra #1
[92362.691726] Hardware name: jetson_tx1 (DT)
[92362.695817] Workqueue: cfg80211 cfg80211_event_work
[92362.700689] task: ffffffc0e0dd6400 ti: ffffffc051a00000 task.ti: ffffffc051a00000
[92362.708157] PC is at __cfg80211_connect_result+0x1a8/0x234
[92362.713629] LR is at __cfg80211_connect_result+0xf0/0x234
[92362.719013] pc : [<ffffffc000b05580>] lr : [<ffffffc000b054c8>] pstate: 40000145
[92362.726391] sp : ffffffc051a03c90
[92362.729696] x29: ffffffc051a03ca0 x28: 0000000000000000
[92362.735008] x27: 0000000000000000 x26: ffffffc001481278
[92362.740320] x25: ffffffc05f1fd218 x24: ffffffc000d73a40
[92362.745632] x23: ffffffc0f0fa3eb0 x22: ffffffc05f1fd218
[92362.750944] x21: 0000000000000000 x20: 0000000000000000
[92362.756255] x19: ffffffc0f0fa3e00 x18: 000000000cf8d629
[92362.761567] x17: 0000007f9e7bff18 x16: ffffffc0001df364
[92362.766877] x15: 0000000000000028 x14: 0000000000000000
[92362.772189] x13: 0000000000000000 x12: 000000050406163d
[92362.777499] x11: ffffffc000b30b?0 x10: 0000000000000001
[92362.782810] x9 : 0000000000000010 x8 : ffffffbffc7e1fc8
[92362.788122] x7 : ffffffc0f1ffba88 x6 : 0000000000000002
[92362.793434] x5 : 00000000fffffffe x4 : 0000000000000000
[92362.798746] x3 : ffffffc0014ba700 x2 : ffffffc051a03be0
[92362.804057] x1 : 0000000000000000 x0 : 0000000000000000
[92362.811082] ---[ end trace 18be6d647c47922a ]---
[92362.815687] Call trace:
[92362.818128] [<ffffffc000b05580>] __cfg80211_connect_result+0x1a8/0x234
[92362.824642] [<ffffffc000adf3d0>] cfg80211_process_wdev_events+0xe8/0x1a8
[92362.831327] [<ffffffc000adf4dc>] cfg80211_process_rdev_events+0x4c/0x68
[92362.837927] [<ffffffc000ad9fbc>] cfg80211_event_work+0x1c/0x28
[92362.843748] [<ffffffc0000ba7c0>] process_one_work+0x234/0x45c
[92362.849481] [<ffffffc0000bac30>] worker_thread+0x248/0x428
[92362.854953] [<ffffffc0000c0888>] kthread+0xf8/0x100
[92362.859820] [<ffffffc0000847a0>] ret_from_fork+0x10/0x30
[92362.866946] cfg80211: World regulatory domain updated:
[92362.873435] cfg80211:  DFS Master region: unset
[92362.877584] CFG80211-ERROR) wl_notify_connect_status :
[92362.877588] wl_bss_connect_done succeeded with 50:fa:84:5f:ac:ba
[92362.887623] cfg80211:   (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp), (dfs_cac_time)
[92362.897477] cfg80211:   (2402000 KHz - 2472000 KHz @ 40000 KHz), (N/A, 2000 mBm), (N/A)
[92362.905527] cfg80211:   (2457000 KHz - 2482000 KHz @ 40000 KHz), (N/A, 2000 mBm), (N/A)
[92362.913558] cfg80211:   (2474000 KHz - 2494000 KHz @ 20000 KHz), (N/A, 2000 mBm), (N/A)
[92362.921612] cfg80211:   (5170000 KHz - 5250000 KHz @ 80000 KHz, 160000 KHz AUTO), (N/A, 2000 mBm), (N/A)
[92362.931115] cfg80211:   (5250000 KHz - 5330000 KHz @ 80000 KHz, 160000 KHz AUTO), (N/A, 2000 mBm), (0 s)
[92362.940621] cfg80211:   (5490000 KHz - 5730000 KHz @ 160000 KHz), (N/A, 2000 mBm), (0 s)
[92362.948735] cfg80211:   (5735000 KHz - 5835000 KHz @ 80000 KHz), (N/A, 2000 mBm), (N/A)
[92362.956931] cfg80211:   (57240000 KHz - 63720000 KHz @ 2160000 KHz), (N/A, 0 mBm), (N/A)
[92362.971980] cfg80211: Regulatory domain changed to country: CN
[92362.977826] cfg80211:  DFS Master region: FCC
[92362.982078] cfg80211:   (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp), (dfs_cac_time)
[92362.991866] cfg80211:   (2402000 KHz - 2482000 KHz @ 40000 KHz), (N/A, 2000 mBm), (N/A)
[92362.999906] cfg80211:   (5170000 KHz - 5250000 KHz @ 80000 KHz, 160000 KHz AUTO), (N/A, 2300 mBm), (N/A)
[92363.009418] cfg80211:   (5250000 KHz - 5330000 KHz @ 80000 KHz, 160000 KHz AUTO), (N/A, 2300 mBm), (0 s)
[92363.018894] cfg80211:   (5735000 KHz - 5835000 KHz @ 80000 KHz), (N/A, 3000 mBm), (N/A)
[92363.026893] cfg80211:   (57240000 KHz - 59400000 KHz @ 2160000 KHz), (N/A, 2800 mBm), (N/A)
[92363.035237] cfg80211:   (59400000 KHz - 63720000 KHz @ 2160000 KHz), (N/A, 4400 mBm), (N/A)
[92363.043582] cfg80211:   (63720000 KHz - 65880000 KHz @ 2160000 KHz), (N/A, 2800 mBm), (N/A)
[94716.802602] CFG80211-ERROR) wl_is_linkdown : Link down Reason : WLC_E_DEAUTH_IND
[94716.810486] CFG80211-ERROR) wl_notify_connect_status : link down if wlan0 may call cfg80211_disconnected. event : 6, reason=6 from 50:fa:84:5f:ac:ba
[94716.861068] cfg80211: World regulatory domain updated:
[94716.866280] cfg80211:  DFS Master region: unset
[94716.871324] cfg80211:   (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp), (dfs_cac_time)
[94716.881106] cfg80211:   (2402000 KHz - 2472000 KHz @ 40000 KHz), (N/A, 2000 mBm), (N/A)
[94716.889369] cfg80211:   (2457000 KHz - 2482000 KHz @ 40000 KHz), (N/A, 2000 mBm), (N/A)
[94716.898198] cfg80211:   (2474000 KHz - 2494000 KHz @ 20000 KHz), (N/A, 2000 mBm), (N/A)
[94716.906215] cfg80211:   (5170000 KHz - 5250000 KHz @ 80000 KHz, 160002 KHz AUTO), (N/A, 2000 mBm), (N/A)
[94716.915975] cfg80211:   (5250000 KHz - 5330000 KHz @ 80000 KHz, 160000 KHz AUTO), (N/A, 2000 mBm), (0 s)
[94716.925612] cfg80211:   (5490000 KHz - 5730000 KHz @ 160000 KHz), (N/A, 2000 mBm), (0 s)
[94716.933816] cfg80211:   (5735000 KHz - 5835000 KHz @ 80000 KHz), (N/A, 2000 mBm), (N/A)
[94716.941944] cfg80211:   (57240000 KHz - 63720000 KHz @ 2160000 KHz), (N/A, 0 mBm), (N/A)
[94716.956737] cfg80211: Regulatory domain changed to country: CN
[94716.962583] cfg80211:  FFS Master region: FCC
[94716.966839] cfg80211:   (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp), (dfs_cac_time)
[94716.976604] cfg80211:   (2402000 KHz - 2482000 KHz @ 40000 KHz), (N/A, 2000 mBm), (N/A)
[94716.984656] cfg80211:   (5170000 KHz - 5250000 KHz @ 80000 KHz, 160000 KHz AUTO), (N/A, 2300 mBm), (N/A)
[94716.994197] cfg80211:   (5250000 KHz - 5330000 KHz @ 80000 KHz, 160000 KHz AUTO), (N/A, 2300 mBm), (0 s)
[94717.003704] cfg80211:   (5735000 KHz - 5835000 KHz @ 80000 KHz), (N/A, 3000 mBm), (N/A)
[94717.011733] cfg80211:   (57240000 KHz - 59400000 KHz @ 2160000 KHz), (N/A, 2800 mBm), (N/A)
[94717.020109] cfg80211:   (59400000 KHz - 63720000 KHz @ 2160000 KHz), (N/A, 4400 mBm), (N/A)
[94717.028493] cfg80211:   (63720000 KHz - 65880000 KHz @ 2160000 KHz), (N/A, 2800 mBm), (N/A)
[94717.042371] cfg80211: World regulatory domain updated:
[94717.047522] cfg80211:  DFS Master region: unset
[94717.051878] cfg80211:   (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp), (dfs_cac_time)
[94717.061617] cfg80211:   (2402000 KHz - 2472000 KHz @ 40000 KHz), (N/A, 2000 mBm), (N/A)
[94717.069725] cfg80211:   (2457000 KHz - 2482000 KHz @ 40000 KHz), (N/A, 2000 mBm), (N/A)
[94717.077760] cfg80211:   (2474000 KHz - 2494000 KHz @ 20000 KHz), (N/A, 2000 mBm), (N/A)
[94717.085792] cfg80211:   (5170000 KHz - 5250000 KHz @ 80000 KHz, 160000 KHz AUTO), (N/A, 2000 mBm), (N/A)
[94717.095299] cfg80211:   (5250000 KHz - 5330000 KHz @ 80000 KHz, 160000 KHz AUTO), (N/A, 2000 mBm), (0 s)
[94717.104802] cfg80211:   (5490000 KHz - 5730000 KHz @ 160000 KHz), (N/A, 2000 mBm), (0 s)
[94717.112917] cfg80211:   (5735000 KHz - 5835000 KHz @ 80000 KHz), (N/A, 2000 mBm), (N/A)
[94717.120946] cfg80211:   (57240000 KHz - 63720000 KHz @ 2160000 KHz), (N/A, 0 mBm), (N/A)
[94717.134260] cfg80211: Regulatory domain changed to country: CN
[94717.140109] cfg80211:  DFS Master region: FCC
[94717.144357] cfg80211:   (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp), (dfs_cac_time)
[94717.154118] cfg80211:   (2402000 KHz - 2482000 KHz @ 40000 KHz), (N/A, 2000 mBm), (N/A)
[94717.162196] cfg80211:   (5170000 KHz - 5250000 KHz @ 80000 KHz, 160000 KHz AUTO), (N/A, 2300 mBm), (N/A)
[94717.175611] cfg80211:   (5250000 KHz - 5330000 KHz @ 80000 KHz, 160000 KHz AUTO), (N/A, 2300 mBm), (0 s)
[94717.185119] cfg80211:   (5735000 KHz - 5835000 KHz @ 80000 KHz), (N/A, 3000 mBm), (N/A)
[94717.193148] cfg80211:   (57240000 KHz - 59400000 KHz @ 2160000 KHz), (N/A, 2800 mBm), (N/A)
[94717.201503] cfg80211:   (59400000 KHz - 63720000 KHz @ 2160000 KHz), (N/A, 4400 mBm), (N/A)
[94717.209846] cfg80211:   (63720000 KHz - 65880000 KHz @ 2160000 KHz), (N/A, 2800 mBm), (N/A)
nvidia@tegra-ubuntu:~$ ifconfig
docker0   Link encap:Ethernet  HWaddr 02:42:a0:28:41:5d
          inet addr:172.17.0.1  Bcast:0.0.0.0  Mask:255.255.0.0
          UP BROADCAST MULTICAST  MTU:1500  Metric:1
          RX packets:0 errors:0 dropped:0 overruns:0 frame:0
          TX packets:0 errors:0 dropped:0 overruns:0 carrier:0
          collisions:0 txqueuelen:0
          RX bytes:0 (0.0 B)  TX bytes:0 (0.0 B)
eth0      Link encap:Ethernet  HWaddr 00:04:4b:9b:ba:3b
          collisions:0 txqueuelen:1000
l4tbr0    Link encap:Ethernet  HWaddr 8a:44:f4:21:2c:a5
          inet addr:192.168.55.1  Bcast:192.168.55.255  Mask:255.255.255.0
          inet6 addr: fe80::fcf8:80ff:fe96:f219/64 Scope:Link
          TX packets:8 errors:0 dropped:0 overruns:0 carrier:0
          RX bytes:0 (0.0 B)  TX bytes:704 (704.0 B)
lo        Link encap:Local Loopback
          inet addr:127.0.0.1  Mask:255.0.0.0
          inet6 addr: ::1/128 Scope:Host
          UP LOOPBACK RUNNING  MTU:65536  Metric:1
          RX packets:866 errors:0 dropped:0 overruns:0 frame:0
          TX packets:866 errors:0 dropped:0 overruns:0 carrier:0
          RX bytes:68424 (68.4 KB)  TX bytes:68424 (68.4 KB)
usb0      Link encap:Ethernet  HWaddr 8a:44:f4:21:2c:a5
usb1      Link encap:Ethernet  HWaddr ca:9a:03:25:ba:44
wlan0     Link encap:Ethernet  HWaddr 00:04:4b:9b:ba:39
          RX packets:334773 errors:0 dropped:0 overruns:0 frame:0
          TX packets:112847 errors:0 dropped:0 overruns:0 carrier:0
          RX bytes:333018471 (333.0 MB)  TX bytes:8259031 (8.2 MB)
jiamianshiye,
Please help do some debug test and reply questions for us if possible. Thanks
  1. Are you using wifi ap or sta mode?
  2. When you hit error, could you also share the syslog from /var/log/syslog?
  3. If you fallback to jetpack3.1 (rel-28.1), would you hit the error?
WayneWWW.Hi.
Im doing test and if something new i will let you know.Thanks.
This issue happened again. I test in 28.2.1 with using station mode. I will fallback to jetpack3.1 later and feed back result.
log attached.
serial-191_dmesg.log (91 KB)
serial-191_syslog.log (719 KB)
I test this Tx1 for two weeks in version 28.2 and i found that if wifi disconnect, tx1 will try to re-connect. Or i can just use ping tx1 from host , it will show network unreachable for about 2-5 minites. And after that , wifi can be connected ok . Is this a bug ?
jiamianshiye,
Does the error from latest comment have the same error log as previous one?
How was the result of jetpack3.1?
Hi.
Error log is same as previous one. I think it maybe itwas related to my route device.
Now i have no extra Tx1 to test jetpack3.1 . I will do jetpack3.1 test some days and reply results.
Did you have any luck with this? I’ve been running my TX1 fine for like a year but since flashing with JetPack3.3 the other day I’m also getting the ‘link down reason : WLC_E_DEAUTH_IND’ error, which then re-prompts the desktop to submit the WPA2 key again. Even when doing that it is hit or miss. Restarting the net-manager seems to work most times. I’ve noticed on dmesg that it is also switching region: [ 2006.179217] cfg80211: Regulatory domain changed to country: GB
Found this https://askubuntu.com/questions/465848/frequent-deauthentication-from-wifi-reason-6-in-a-centrino-advanced-n-6230-r#comment1091348_471492 Seemed to be suspicious of the 5Ghz band and channel swapping so disabled both of them at the router. Not at all ideal but seems stable at the moment.
Also added these lines to /etc/sysctl.conf
net.ipv6.conf.all.disable_ipv6 = 1
net.ipv6.conf.default.disable_ipv6 = 1
net.ipv6.conf.lo.disable_ipv6 = 1
And modified /etc/default/crda with the value found from executing ‘iw reg get’ when connected
Will monitor but I’m guessing it’s just a bug around how its handling the WPA supplicant on changes like user403237 said.
OK I think I’m homing in on the problem. Tried removing one fix at a time after the tx1 ran stable for over 12 hours. I re-enabled 5ghz with a fixed channel first and the tx1 switched OK to it almost instantly. I let it run for a few more minutes and it went into WLC_E_DEAUTH_IND. I removed 5ghz again and the tx1 switched back to 2.4 without any problems and restored the connection. This looks like the tx1 is switching between the two bands. My hub is set up to span the two bands on the same IP range and has the same ID and key. Wonder if there is any way to get the tx1 to stick with the original band it connects to and if it swaps for it to avoid the WLC_E_DEAUTH_IND issue failing to submit its stored credentials.
finlay.macrae,
It sounds weird. How did you setup your wifi AP? We don’t see wifi AP switch different bands on our side.
