R36.4.4 The GBE network card light of the Orin NX is not displaying normally
The GBE network card light of the r36.4.4 orin nx is not displaying normally, while the same SDK orin nano module is functioning properly. Please help analyze this issue, thank you!
Not sure what is your environment.
Are you talking about LED is not light up on your custom board but working on devkit?
On the custom baseboard, the two LED lights on the orin nano are functioning normally. However, when replaced with the orin nx module, the LED lights display abnormally.
Is the behavior of Orin NX fine when it is on NV devkit?
Without using a development kit, the Orin NX module + custom carrier board works normally with both LED lights on the Ethernet port displaying correctly in the bootloader node. However, it becomes abnormal in the system node.
我直接用中文問好了. 所以是因為你沒有devkit還是你有但沒有測過?
我这里没有devkit,也没有测试过orin nx模组,直接用的自定义载板
同样的自定义载板和同样的sdk,orin nx烧录,原生网口的led显示不正常
orin nx 在启动过程,前面bootloader阶段,原生网卡led是正常的,到系统阶段,就不正常了。
我剛才確認了一下Orin NX在NV devkit上的行為是正常的
請問網卡本身是能使用的嗎? 我是說不管LED的狀態. 是能做基本的操作嗎
是R36.4.4版本吗
网卡功能正常,能联网
是的 這版本的LED能正常使用
orin nano led也是正常的,有诊断办法吗
jetson-orin-nano-devkit-super 我用这个配置烧录orin nx的,是否正确
基本上是建議你先找個NV devkit測試一下是否在NV devkit上也有同樣問題
如果有的話可以RMA module. 或是多個Orin NX module交叉測試一下
没有开发套件,只有一块orin nx,验证不了
在烧录阶段和bootloader启动阶段,led灯都是正常的,应该硬件是没问题的
bootloader阶段是正常的
