Raspberry Pi Camera Module V2 Not Detected
Hello Everyone, I have Raspberry Pi Camera Module V2 and plug it in, whe i try this command, it seems cannot detected :
gst-launch-1.0 nvarguscamerasrc ! nvoverlaysink
Setting pipeline to PAUSED ...
Pipeline is live and does not need PREROLL ...
Setting pipeline to PLAYING ...
New clock: GstSystemClock
Error generated. /dvs/git/dirty/git-master_linux/multimedia/nvgstreamer/gst-nvarguscamera/gstnvarguscamerasrc.cpp, execute:740 No cameras available
Got EOS from element "pipeline0".
Execution ended after 0:00:00.001374400
Setting pipeline to READY ...
Setting pipeline to NULL ...
Freeing pipeline ...
Thank You
Do you use latest Jetpack 4.6.1 or 4.6.2? If not, we suggest upgrade the system and try. Besides, please plug in the camera in power off and boot up the system
yes. i use Jetpack 4.6.1
When i tried this command :
v4l2-ctl --list-devices
it shown :
Failed to open /dev/video0: No such file or directory
We suggest re-flash the system image through SDKManager and try again. Raspberry Pi camera v2 should work well on default system image. If it still fails after re-flashing, it is very likely the camera is broken.
okk thank you.
