I’m quite new of this world.
I’m working on a Jetson and i’m trying to use the jetson_multimedia_api to record a video encode it and save it on a disk.
I already looked at tutorial 2 and 10.
Is it possible to came from a raw image (ARGB) and save it on the disk?
Raw2NvBuffer it look like the function that i’m looking for. But this function ask for a fd (fileDescriptor) in. Can you explain please how to push it into the encoding buffer please?
Thank you
For video encoding, you can start with
/usr/src/jetson_multimedia_api/samples/01_video_encode/
Please try the default sample. See if you can run it successfully. Input buffers to encoder have to be in YUV420. For BGRA, you can allocate NvBuffers in NvBufferColorFormat_ARGB32 and call NvBufferTransform() to convert to YUV420(NvBufferColorFormat_YUV420)
Document:
