RCE fails to respond to a CAMRTC_HSP_FW_HASH Request through the IVC/HSP
Hello, we have a custom board based on a Xavier NX SoM.
During the boot process the rtcpu-rce driver sets up an IVC/HSP channel used for IPC to the Realtime Camera Engine. During the rtcpu-rce driver probe the driver pushes a message into the channel instructing the RCE to load its firmware, however the HSP never gets a response from the RCE, which results in several hsp-vm1 timeouts. The rtcpu-rce driver attempts to reset the RCE several times but never gets a response from the RCE, which results in a boot sync failure.
Xavier NX TRM doesn’t provide any RCE documentation.
Flash logs are attached.
Here’s a snippet from the boot logs:
[    4.674209] tegra186-cam-rtcpu bc00000.rtcpu: Adding to iommu group 4
[    4.675435] tegra186-cam-rtcpu bc00000.rtcpu: Trace buffer configured at IOVA=0xbff00000
[    6.693859]  bc00000.rtcpu:hsp-vm1: request 0x40b85d43: response timeout
[    8.709858]  bc00000.rtcpu:hsp-vm1: request 0x4077fb32: response timeout
[    8.710069] tegra186-cam-rtcpu bc00000.rtcpu: rce full reset, retry 2/3
[   10.725876]  bc00000.rtcpu:hsp-vm1: request 0x4039815a: response timeout
[   10.726076] tegra186-cam-rtcpu bc00000.rtcpu: rce full reset, retry 3/3
[   12.741856]  bc00000.rtcpu:hsp-vm1: request 0x40fad020: response timeout
[   12.747682] tegra-ivc-bus bc00000.rtcpu:ivc-bus: region 0: iova=0xbfec0000-0xbfee01ff size=131584
[   12.748250] tegra-ivc-bus bc00000.rtcpu:ivc-bus:echo@0: echo: ver=0 grp=1 RX[16x64]=0x1000-0x1480 TX[16x64]=0x1480-0x1900
[   12.749357] tegra-ivc-bus bc00000.rtcpu:ivc-bus:dbg@1: dbg: ver=0 grp=1 RX[1x448]=0x1900-0x1b40 TX[1x448]=0x1b40-0x1d80
[   12.750211] tegra-ivc-bus bc00000.rtcpu:ivc-bus:dbg@2: dbg: ver=0 grp=1 RX[1x8192]=0x1d80-0x3e00 TX[1x8192]=0x3e00-0x5e80
[   12.751867] tegra-ivc-bus bc00000.rtcpu:ivc-bus:ivccontrol@3: ivccontrol: ver=0 grp=1 RX[64x320]=0x5e80-0xaf00 TX[64x320]=0xaf00-0xff80
[   12.752526] tegra-ivc-bus bc00000.rtcpu:ivc-bus:ivccapture@4: ivccapture: ver=0 grp=1 RX[512x64]=0xff80-0x18000 TX[512x64]=0x18000-0x20080
[   12.752941] tegra-ivc-bus bc00000.rtcpu:ivc-bus:diag@5: diag: ver=0 grp=1 RX[1x64]=0x20080-0x20140 TX[1x64]=0x20140-0x20200
[   12.754254] tegra186-cam-rtcpu bc00000.rtcpu: using cam RTCPU IRQ (48)
[   12.754557] tegra186-cam-rtcpu bc00000.rtcpu: tegra_camrtc_mon_create is successful
sting_mbu_flash_logs.txt (629.9 KB)
My appologies, the snippet was missing a few critical logs:
[   14.757913]  bc00000.rtcpu:hsp-vm1: request 0x46000000: response timeout
[   14.758166]  bc00000.rtcpu:hsp-vm1: FW_HASH failed: 0xffffff92
[   16.773921]  bc00000.rtcpu:hsp-vm1: request 0x44bff000: response timeout
[   16.774191] tegra186-cam-rtcpu bc00000.rtcpu: RTCPU trace: IOVM setup error: -110
[   16.774358] tegra186-cam-rtcpu bc00000.rtcpu: trace boot sync failed: -5
[   18.789919]  bc00000.rtcpu:hsp-vm1: request 0x44bfef80: response timeout
[   20.805930]  bc00000.rtcpu:hsp-vm1: request 0x44bfec00: response timeout
[   20.806196] tegra-ivc-bus bc00000.rtcpu:ivc-bus: IOVM setup error: -110
[   20.806346] tegra186-cam-rtcpu bc00000.rtcpu: ivc-bus boot sync failed: -5
[   20.806634] tegra186-cam-rtcpu bc00000.rtcpu: firmware version cpu=rce cmd=0 sha1=0000000000000000000000000000000000000000
Please provide the version and reproduce step.
We are using a Xavier NX SoM with eMMC (p3668-0001). A decompiled version of our DTB is attached as well as the config files and XML flash files. I’ve also attached a file called install.log which contains the output diagnostics from the flash tools.
After flashing the rtcpu-rce fails to load and start it’s firmware. The rtcpu-rce fails to respond to the hsp-vm1 FW_HASH command resulting in the following errors in the logs:
The bootloader seems to be writing the RCE firmware properly. Is there a way to check the RCE firmware?
sting_mbu.dts (380.8 KB)
jetson-xavier-nx-sting-chassis-carrier.conf (2.5 KB)
sting-chassis-carrier-p3668.conf.common (6.3 KB)
nv_boot_control.conf (118 Bytes)
extlinux.conf (948 Bytes)
flash.xml (40.6 KB)
flash_mb1_fix.xml (40.3 KB)
flash_l4t_t194_spi_emmc_p3668.xml (40.2 KB)
Did you try flash the jetson-xavier-nx-devkit-emmc.conf?
We are using L4T version r35.1. We use the jetson-xavier-nx-sting-chassis-carrier.conf and sting-chassis-carrier-p3668.conf.common which are based on the DevKit’s jetson-xavier-nx-devkit-emmc.conf and p3668.conf.common files.
Our .conf files use a smaller ROOTFS and add a few more partitions. The diffs between the sting-chassis-carrier-p3668.conf.common and jetson-xavier-nx-devkit-emmc.conf are:
bchaco@R9-10EDXJ:sting_dev$ diff jetson-xavier-nx-sting-chassis-carrier.conf jetson-xavier-nx-devkit-emmc.conf
34c34
< source "${LDK_DIR}/sting-chassis-carrier-p3668.conf.common";
> source "${LDK_DIR}/p3668.conf.common";
36,37c36
< DTB_FILE=tegra194-p3668-0001-p3509-0000-sting-chassis-carrier.dtb;
< TBCDTB_FILE=tegra194-p3668-0001-p3509-0000-sting-chassis-carrier.dtb;
> DTB_FILE=tegra194-p3668-0001-p3509-0000.dtb;
The diffs between the sting-chassis-carrier-p3668.conf.common file and original p3668.conf.common file are:
 diff sting-chassis-carrier-p3668.conf.common p3668.conf.common
101a102,103
> DTB_FILE=tegra194-p3668-all-p3509-0000.dtb;
> TBCDTB_FILE=tegra194-p3668-all-p3509-0000.dtb;
104,109c106
< ROOTFSSIZE=8GiB;
< HOMEFSSIZE=1GiB;
< VARFSSIZE=250MiB;
< VARLFSSIZE=250MiB;
< VARLAFSSIZE=500MiB;
< RECOVERYFSSIZE=4GiB;
> ROOTFSSIZE=14GiB;
150c147
< PINMUX_CONFIG="tegra19x-sting-chassis-carrier-pinmux.cfg";
> PINMUX_CONFIG="tegra19x-mb1-pinmux-p3668-a01.cfg";
152c149
< PMC_CONFIG="tegra19x-sting-chassis-carrier-padvoltage.cfg";
> PMC_CONFIG="tegra19x-mb1-padvoltage-p3668-a01.cfg";
The attached flash_l4t_t194_spi_emmc_p3668.xml has been modified from the Xavier NX devkit version to include additional partitions, with the ‘APP’ partition renamed to ‘ROOT’. The diffs are
--- a/bootloader/t186ref/cfg/flash_l4t_t194_spi_emmc_p3668.xml
+++ b/bootloader/t186ref/cfg/flash_l4t_t194_spi_emmc_p3668.xml
@@ -496,16 +496,14 @@
               partitions defined after this entry are configured in the kernel, and are
               accessible by standard partition tools such as gdisk and parted. </description>
         </partition>
-        <partition name="APP" type="data">
+        <partition name="ROOT" type="data">
             <allocation_policy> sequential </allocation_policy>
             <filesystem_type> basic </filesystem_type>
-            <size> APPSIZE </size>
+            <size> ROOTSIZE </size>
             <file_system_attribute> 0 </file_system_attribute>
             <allocation_attribute> 0x8 </allocation_attribute>
             <align_boundary> 4096 </align_boundary>
             <percent_reserved> 0 </percent_reserved>
-            <filename> APPFILE </filename>
-            <unique_guid> APPUUID </unique_guid>
             <description> **Required.** Contains the rootfs. This partition must be defined
               after `primary_GPT` so that it can be accessed as the fixed known special device
               `/dev/mmcblk0p1`. </description>
@@ -532,6 +530,48 @@
             <filename> DTB_FILE </filename>
             <description> **Required.** Chain A; contains kernel device tree blob. </description>
         </partition>
+        <partition name="HOME" type="data">
+            <allocation_policy> sequential </allocation_policy>
+            <filesystem_type> basic </filesystem_type>
+            <size> HOMESIZE </size>
+            <file_system_attribute> 0 </file_system_attribute>
+            <allocation_attribute> 0x8 </allocation_attribute>
+            <percent_reserved> 0 </percent_reserved>
+        </partition>
+        <partition name="VAR" type="data">
+            <size> VARSIZE </size>
+        </partition>
+        <partition name="VARL" type="data">
+            <size> VARLSIZE </size>
+        </partition>
+        <partition name="VARLA" type="data">
+            <size> VARLASIZE </size>
+        </partition>
+        <partition name="RECOVERY" type="data">
+            <size> RECOVERYSIZE </size>
+            <unique_guid> APPUUID </unique_guid>
+            <filename> RECOVERYFILE </filename>
+        </partition>
         <partition name="reserved_for_chain_A_user" type="data">
Thank you!
Could you try flash with default XNX emmc config without any modification.
