Hello there,
I recently run this script: https://github.com/AastaNV/JEP/blob/master/script/install_opencv4.0.0_Nano.sh to install opencv-4.0.0 when I realised it is already preinstalled on the Nano (another version but is still ok) and so I stopped the installation in the middle of the process. The script removed libopencv by following command:
sudo sudo apt-get purge *libopencv*
Now if I want to rum some scripts in jetson-inference (which use opencv), which worked perfect so far, this message comes:
./imagenet-camera: error while loading shared libraries: libopencv_calib3d.so.3.3: cannot open shared object file: No such file or directory
Is there any way to replace it? I tried
sudo apt-get install *libopencv*
to fix but didn’t work. So does somebody know how to efficiently install opencv, preferably the version that was preinstalled, on the Jetson Nano to get things to work?
Thanks for the help in advance!
