Is it possible to deploy a real-time OS on the Jetson AGX Orin?
The RTOS is required for a time-critical application.
I believe the AGX Orin is not optimized for an RTOS out of the box.
Can I install an RT kernel on the AGX Orin?
If Yes, how do I do this, and any relevant resources would be really helpful.
If No, Can I have the PREEMPT-RT patch installed and applied on the AGX Orin? If not, what are alternatives to this?
RT kernel is supported. Please refer to Kernel section in developer guide.
Thank you.
You may find this interesting: https://concurrent-rt.com/
Thank You for sharing.
