I am currently working on a project using the following setup:
- Jetson AGX Orin 64GB Developer Kit
- Jetpack 6.1
- Isaac ROS 3.1
- Isaac_ros_example 3.2
- Isaac_ros_visual_slam 3.1
- Realsense-ros 4.55.1
- Librealsense 2.55.1
- cuVSLAM 12.6
My goal is to use the Realsense D430i camera for visual SLAM. To enable compatibility, I updated the Realsense-ros version to 4.55.1 and used the isaac_ros_visual_slam_multirealsense.launch.py file to run the camera.
However, I frequently encounter the following error:
[component_container_mt-3] 21/01 15:47:30,944 WARNING [281469439961312] (messenger-libusb.cpp:42) control_transfer returned error, index: 768, error: Resource temporarily unavailable, number: 11
While the setup occasionally works fine, this error occurs most of the time.
Could you please provide any suggestions or guidance to resolve this issue? Additionally, is there a plan to officially support the Realsense D430i in a future update?
Thank you in advance for your assistance!
Below is the detailed log output:
[INFO] [launch]: All log files can be found below /home/admin/.ros/log/2025-01-21-15-47-11-864406-ubuntu-152571
[INFO] [launch]: Default logging verbosity is set to INFO
camera_name: camera1
camera_name: camera2
[INFO] [foxglove_bridge-1]: process started with pid [152582]
[INFO] [robot_state_publisher-2]: process started with pid [152584]
[INFO] [component_container_mt-3]: process started with pid [152586]
[robot_state_publisher-2] [INFO] [1737442032.235130524] [robot_state_publisher]: got segment base_link
[robot_state_publisher-2] [INFO] [1737442032.235321180] [robot_state_publisher]: got segment camera1_link
[robot_state_publisher-2] [INFO] [1737442032.235338972] [robot_state_publisher]: got segment camera2_link
[foxglove_bridge-1] [INFO] [1737442032.244188175] [foxglove_bridge_component_manager]: Load Library: /opt/ros/humble/lib/libfoxglove_bridge_component.so
[foxglove_bridge-1] [INFO] [1737442032.254960064] [foxglove_bridge_component_manager]: Found class: rclcpp_components::NodeFactoryTemplate<foxglove_bridge::FoxgloveBridge>
[foxglove_bridge-1] [INFO] [1737442032.255029504] [foxglove_bridge_component_manager]: Instantiate class: rclcpp_components::NodeFactoryTemplate<foxglove_bridge::FoxgloveBridge>
[foxglove_bridge-1] [INFO] [1737442032.260589592] [foxglove_bridge]: Starting foxglove_bridge (humble, 0.8.2@) with WebSocket++/0.8.2
[foxglove_bridge-1] [INFO] [1737442032.261885559] [foxglove_bridge]: [WS] Server running without TLS
[foxglove_bridge-1] [INFO] [1737442032.262319414] [foxglove_bridge]: [WS] WebSocket server listening at ws://0.0.0.0:8765
[foxglove_bridge-1] [INFO] [1737442032.262333814] [foxglove_bridge]: [WS] WebSocket server run loop started
[component_container_mt-3] [INFO] [1737442032.445830740] [visual_slam_launch_container]: Load Library: /workspaces/isaac_ros-dev/install/realsense2_camera/lib/librealsense2_camera.so
[component_container_mt-3] [INFO] [1737442032.558639637] [visual_slam_launch_container]: Found class: rclcpp_components::NodeFactoryTemplate<realsense2_camera::RealSenseNodeFactory>
[component_container_mt-3] [INFO] [1737442032.559602900] [visual_slam_launch_container]: Instantiate class: rclcpp_components::NodeFactoryTemplate<realsense2_camera::RealSenseNodeFactory>
[component_container_mt-3] [INFO] [1737442032.589077835] [camera1]: RealSense ROS v4.55.1
[component_container_mt-3] [INFO] [1737442032.589147466] [camera1]: Built with LibRealSense v2.55.1
[INFO] [launch_ros.actions.load_composable_nodes]: Loaded node '/camera1' in container 'visual_slam_launch_container'
[component_container_mt-3] [INFO] [1737442032.589163562] [camera1]: Running with LibRealSense v2.55.1
[component_container_mt-3] [INFO] [1737442032.590363401] [visual_slam_launch_container]: Load Library: /workspaces/isaac_ros-dev/install/isaac_ros_visual_slam/lib/libvisual_slam_node.so
[component_container_mt-3] [INFO] [1737442032.651632915] [visual_slam_launch_container]: Found class: rclcpp_components::NodeFactoryTemplate<nvidia::isaac_ros::visual_slam::VisualSlamNode>
[component_container_mt-3] [INFO] [1737442032.651728658] [visual_slam_launch_container]: Instantiate class: rclcpp_components::NodeFactoryTemplate<nvidia::isaac_ros::visual_slam::VisualSlamNode>
[component_container_mt-3] [INFO] [1737442032.664277313] [NitrosContext]: [NitrosContext] Loading extension: gxf/lib/std/libgxf_std.so
[component_container_mt-3] [INFO] [1737442032.668684187] [NitrosContext]: [NitrosContext] Loading extension: gxf/lib/libgxf_isaac_gxf_helpers.so
[component_container_mt-3] [INFO] [1737442032.673793427] [NitrosContext]: [NitrosContext] Loading extension: gxf/lib/libgxf_isaac_sight.so
[component_container_mt-3] [INFO] [1737442032.679498827] [NitrosContext]: [NitrosContext] Loading extension: gxf/lib/libgxf_isaac_atlas.so
[component_container_mt-3] 2025-01-21 15:47:12.693 WARN external/com_nvidia_gxf/gxf/std/program.cpp@532: No GXF scheduler specified.
[component_container_mt-3] [INFO] [1737442032.693847543] [NitrosContext]: [NitrosContext] Loading extension: gxf/lib/multimedia/libgxf_multimedia.so
[component_container_mt-3] [INFO] [1737442032.702264619] [visual_slam_node.ManagedNitrosSubscriber]: Starting Managed Nitros Subscriber
[component_container_mt-3] [INFO] [1737442032.703997705] [visual_slam_node.ManagedNitrosSubscriber]: Starting Managed Nitros Subscriber
[component_container_mt-3] [INFO] [1737442032.705623335] [visual_slam_node.ManagedNitrosSubscriber]: Starting Managed Nitros Subscriber
[component_container_mt-3] [INFO] [1737442032.707135525] [visual_slam_node.ManagedNitrosSubscriber]: Starting Managed Nitros Subscriber
[component_container_mt-3] [INFO] [1737442032.730420644] [visual_slam_node]: cuVSLAM version: 12.2
[component_container_mt-3] [INFO] [1737442032.806619417] [visual_slam_node]: Time taken by CUVSLAM_WarmUpGPU(): 0.076131
[INFO] [launch_ros.actions.load_composable_nodes]: Loaded node '/visual_slam_node' in container '/visual_slam_launch_container'
[component_container_mt-3] [INFO] [1737442032.816230667] [visual_slam_launch_container]: Found class: rclcpp_components::NodeFactoryTemplate<realsense2_camera::RealSenseNodeFactory>
[component_container_mt-3] [INFO] [1737442032.816299115] [visual_slam_launch_container]: Instantiate class: rclcpp_components::NodeFactoryTemplate<realsense2_camera::RealSenseNodeFactory>
[component_container_mt-3] [INFO] [1737442032.829142809] [camera2]: RealSense ROS v4.55.1
[component_container_mt-3] [INFO] [1737442032.829375545] [camera2]: Built with LibRealSense v2.55.1
[component_container_mt-3] [INFO] [1737442032.829403097] [camera2]: Running with LibRealSense v2.55.1
[INFO] [launch_ros.actions.load_composable_nodes]: Loaded node '/camera2' in container 'visual_slam_launch_container'
[component_container_mt-3] 21/01 15:47:12,953 WARNING [281470020217056] (handle-libusb.h:110) failed to claim usb interface, interface 0, is busy - retrying...
[component_container_mt-3] 21/01 15:47:12,963 WARNING [281470020217056] (handle-libusb.h:110) failed to claim usb interface, interface 0, is busy - retrying...
[component_container_mt-3] 21/01 15:47:13,076 WARNING [281471632337120] (handle-libusb.h:110) failed to claim usb interface, interface 0, is busy - retrying...
[component_container_mt-3] 21/01 15:47:13,175 WARNING [281470020217056] (handle-libusb.h:110) failed to claim usb interface, interface 0, is busy - retrying...
[component_container_mt-3] 21/01 15:47:13,185 WARNING [281470020217056] (handle-libusb.h:110) failed to claim usb interface, interface 0, is busy - retrying...
[component_container_mt-3] 21/01 15:47:13,261 WARNING [281471632337120] (handle-libusb.h:110) failed to claim usb interface, interface 0, is busy - retrying...
[component_container_mt-3] 21/01 15:47:13,272 WARNING [281471632337120] (handle-libusb.h:110) failed to claim usb interface, interface 0, is busy - retrying...
[component_container_mt-3] [INFO] [1737442033.394348171] [camera1]: Device with serial number 239722073302 was found.
[component_container_mt-3] [INFO] [1737442033.394477867] [camera1]: Device with physical ID 2-2-24 was found.
[component_container_mt-3] [INFO] [1737442033.394495051] [camera1]: Device with name Intel RealSense D435I was found.
[component_container_mt-3] [INFO] [1737442033.394774282] [camera1]: Device with port number 2-2 was found.
[component_container_mt-3] [INFO] [1737442033.689685621] [camera2]: Device with serial number 239722073302 was found.
[component_container_mt-3] [INFO] [1737442033.689804565] [camera2]: Device with physical ID 2-2-24 was found.
[component_container_mt-3] [INFO] [1737442033.689817973] [camera2]: Device with name Intel RealSense D435I was found.
[component_container_mt-3] [INFO] [1737442033.690097397] [camera2]: Device with port number 2-2 was found.
[component_container_mt-3] [INFO] [1737442033.690118101] [camera2]: Device USB type: 3.2
[component_container_mt-3] [INFO] [1737442033.690128597] [camera2]: Resetting device...
[component_container_mt-3] [INFO] [1737442034.087807061] [camera1]: Device with serial number 239722072275 was found.
[component_container_mt-3] [INFO] [1737442034.087923221] [camera1]: Device with physical ID 2-3.2-22 was found.
[component_container_mt-3] [INFO] [1737442034.087937653] [camera1]: Device with name Intel RealSense D435I was found.
[component_container_mt-3] [INFO] [1737442034.088248084] [camera1]: Device with port number 2-3.2 was found.
[component_container_mt-3] [INFO] [1737442034.088271892] [camera1]: Device USB type: 3.2
[component_container_mt-3] [INFO] [1737442034.088352852] [camera1]: Resetting device...
[component_container_mt-3] 21/01 15:47:20,219 WARNING [281469599541472] (handle-libusb.h:110) failed to claim usb interface, interface 0, is busy - retrying...
[component_container_mt-3] 21/01 15:47:20,229 WARNING [281469599541472] (handle-libusb.h:110) failed to claim usb interface, interface 0, is busy - retrying...
[component_container_mt-3] 21/01 15:47:20,325 WARNING [281469456869600] (handle-libusb.h:110) failed to claim usb interface, interface 0, is busy - retrying...
[component_container_mt-3] 21/01 15:47:20,335 WARNING [281469456869600] (handle-libusb.h:110) failed to claim usb interface, interface 0, is busy - retrying...
[component_container_mt-3] 21/01 15:47:20,346 ERROR [281469456869600] (handle-libusb.h:125) failed to claim usb interface: 0, error: RS2_USB_STATUS_BUSY
[component_container_mt-3] 21/01 15:47:20,347 ERROR [281470037125344] (uvc-sensor.cpp:412) acquire_power failed: failed to set power state
[component_container_mt-3] 21/01 15:47:20,347 WARNING [281470037125344] (d400-factory.cpp:717) Cannot read RGB calibration table
[component_container_mt-3] 21/01 15:47:20,347 WARNING [281470037125344] (d400-factory.cpp:833) invalid RGB extrinsic was identified, recovery routine was invoked
[component_container_mt-3] 21/01 15:47:20,443 WARNING [281469599541472] (handle-libusb.h:110) failed to claim usb interface, interface 0, is busy - retrying...
[component_container_mt-3] 21/01 15:47:20,453 WARNING [281469599541472] (handle-libusb.h:110) failed to claim usb interface, interface 0, is busy - retrying...
[component_container_mt-3] 21/01 15:47:20,581 WARNING [281469456869600] (handle-libusb.h:110) failed to claim usb interface, interface 0, is busy - retrying...
[component_container_mt-3] 21/01 15:47:20,591 WARNING [281469456869600] (handle-libusb.h:110) failed to claim usb interface, interface 0, is busy - retrying...
[component_container_mt-3] 21/01 15:47:20,700 WARNING [281469456869600] (messenger-libusb.cpp:42) control_transfer returned error, index: 768, error: Device or resource busy, number: 16
[component_container_mt-3] 21/01 15:47:20,711 WARNING [281469456869600] (messenger-libusb.cpp:42) control_transfer returned error, index: 768, error: Device or resource busy, number: 16
[component_container_mt-3] 21/01 15:47:20,717 WARNING [281469599541472] (handle-libusb.h:110) failed to claim usb interface, interface 0, is busy - retrying...
[component_container_mt-3] 21/01 15:47:20,722 WARNING [281469456869600] (messenger-libusb.cpp:42) control_transfer returned error, index: 768, error: Device or resource busy, number: 16
[component_container_mt-3] 21/01 15:47:20,728 WARNING [281469599541472] (handle-libusb.h:110) failed to claim usb interface, interface 0, is busy - retrying...
[component_container_mt-3] 21/01 15:47:20,733 WARNING [281469456869600] (messenger-libusb.cpp:42) control_transfer returned error, index: 768, error: Device or resource busy, number: 16
[component_container_mt-3] 21/01 15:47:20,738 ERROR [281469599541472] (handle-libusb.h:125) failed to claim usb interface: 0, error: RS2_USB_STATUS_BUSY
[component_container_mt-3] 21/01 15:47:20,738 ERROR [281471693613280] (uvc-sensor.cpp:412) acquire_power failed: failed to set power state
[component_container_mt-3] 21/01 15:47:20,739 ERROR [281471693613280] (rs.cpp:237) [rs2_create_device( info_list:0xffff34042290, index:0 ) UNKNOWN] failed to set power state
[component_container_mt-3] 21/01 15:47:20,739 ERROR [281471693613280] (rs.cpp:237) [rs2_delete_device( device:nullptr ) UNKNOWN] null pointer passed for argument "device"
[component_container_mt-3] 21/01 15:47:20,739 WARNING [281471693613280] (rs.cpp:373) null pointer passed for argument "device"
[component_container_mt-3] [WARN] [1737442040.739708862] [camera1]: Device 1/2 failed with exception: failed to set power state
[component_container_mt-3] 21/01 15:47:20,743 WARNING [281469456869600] (messenger-libusb.cpp:42) control_transfer returned error, index: 768, error: Device or resource busy, number: 16
[component_container_mt-3] 21/01 15:47:20,754 WARNING [281469456869600] (messenger-libusb.cpp:42) control_transfer returned error, index: 768, error: Device or resource busy, number: 16
[component_container_mt-3] 21/01 15:47:20,789 WARNING [281470037125344] (d400-factory.cpp:859) RGB stream extrinsic successfully recovered
[component_container_mt-3] [INFO] [1737442040.927449702] [camera2]: Device with serial number 239722073302 was found.
[component_container_mt-3] [INFO] [1737442040.927556486] [camera2]: Device with physical ID 2-2-25 was found.
[component_container_mt-3] [INFO] [1737442040.927570886] [camera2]: Device with name Intel RealSense D435I was found.
[component_container_mt-3] [INFO] [1737442040.927844613] [camera2]: Device with port number 2-2 was found.
[component_container_mt-3] [INFO] [1737442040.927865445] [camera2]: Device USB type: 3.2
[component_container_mt-3] [INFO] [1737442040.927986437] [camera2]: getParameters...
[component_container_mt-3] [INFO] [1737442040.930169443] [camera2]: JSON file is not provided
[component_container_mt-3] [INFO] [1737442040.930236323] [camera2]: Device Name: Intel RealSense D435I
[component_container_mt-3] [INFO] [1737442040.930251618] [camera2]: Device Serial No: 239722073302
[component_container_mt-3] [INFO] [1737442040.930261954] [camera2]: Device physical port: 2-2-25
[component_container_mt-3] [INFO] [1737442040.930269410] [camera2]: Device FW version: 5.13.0.50
[component_container_mt-3] [INFO] [1737442040.930276930] [camera2]: Device Product ID: 0x0B3A
[component_container_mt-3] [INFO] [1737442040.930283810] [camera2]: Sync Mode: On
[component_container_mt-3] [INFO] [1737442041.622518647] [camera1]: Device with serial number 239722072275 was found.
[component_container_mt-3] [INFO] [1737442041.622641655] [camera1]: Device with physical ID 2-3.2-26 was found.
[component_container_mt-3] [INFO] [1737442041.622657271] [camera1]: Device with name Intel RealSense D435I was found.
[component_container_mt-3] [INFO] [1737442041.622931798] [camera1]: Device with port number 2-3.2 was found.
[component_container_mt-3] [INFO] [1737442041.622955254] [camera1]: Device USB type: 3.2
[component_container_mt-3] [INFO] [1737442041.623015702] [camera1]: getParameters...
[component_container_mt-3] [INFO] [1737442041.624734196] [camera1]: JSON file is not provided
[component_container_mt-3] [INFO] [1737442041.624803156] [camera1]: Device Name: Intel RealSense D435I
[component_container_mt-3] [INFO] [1737442041.624817492] [camera1]: Device Serial No: 239722072275
[component_container_mt-3] [INFO] [1737442041.624826996] [camera1]: Device physical port: 2-3.2-26
[component_container_mt-3] [INFO] [1737442041.624834900] [camera1]: Device FW version: 5.13.0.50
[component_container_mt-3] [INFO] [1737442041.624841940] [camera1]: Device Product ID: 0x0B3A
[component_container_mt-3] [INFO] [1737442041.624848756] [camera1]: Sync Mode: On
[component_container_mt-3] [WARN] [1737442048.274766163] [camera2]: re-enable the stream for the change to take effect.
[component_container_mt-3] [WARN] [1737442048.781493283] [camera1]: re-enable the stream for the change to take effect.
[component_container_mt-3] [WARN] [1737442048.985843848] [camera2]: re-enable the stream for the change to take effect.
[component_container_mt-3] [INFO] [1737442048.996680638] [camera2]: Stopping Sensor: Depth Module
[component_container_mt-3] [INFO] [1737442049.244579234] [camera2]: Starting Sensor: Depth Module
[component_container_mt-3] [INFO] [1737442049.326102585] [camera2]: Open profile: stream_type: Infra(1), Format: Y8, Width: 424, Height: 240, FPS: 30
[component_container_mt-3] [INFO] [1737442049.326210937] [camera2]: Open profile: stream_type: Infra(2), Format: Y8, Width: 424, Height: 240, FPS: 30
[component_container_mt-3] 21/01 15:47:29,327 WARNING [281469456869600] (messenger-libusb.cpp:42) control_transfer returned error, index: 768, error: Resource temporarily unavailable, number: 11
[component_container_mt-3] [INFO] [1737442049.329744182] [camera2]: RealSense Node Is Up!
[component_container_mt-3] 21/01 15:47:29,338 WARNING [281469456869600] (messenger-libusb.cpp:42) control_transfer returned error, index: 768, error: Resource temporarily unavailable, number: 11
[component_container_mt-3] [WARN] [1737442049.524614409] [camera1]: re-enable the stream for the change to take effect.
[component_container_mt-3] [INFO] [1737442049.537477726] [camera1]: Stopping Sensor: Depth Module
[component_container_mt-3] [INFO] [1737442049.742094408] [camera1]: Starting Sensor: Depth Module
[component_container_mt-3] [INFO] [1737442049.834790710] [camera1]: Open profile: stream_type: Infra(1), Format: Y8, Width: 424, Height: 240, FPS: 30
[component_container_mt-3] [INFO] [1737442049.834902198] [camera1]: Open profile: stream_type: Infra(2), Format: Y8, Width: 424, Height: 240, FPS: 30
[component_container_mt-3] 21/01 15:47:29,836 WARNING [281469439961312] (messenger-libusb.cpp:42) control_transfer returned error, index: 768, error: Resource temporarily unavailable, number: 11
[component_container_mt-3] [INFO] [1737442049.837194324] [camera1]: RealSense Node Is Up!
[component_container_mt-3] 21/01 15:47:29,847 WARNING [281469439961312] (messenger-libusb.cpp:42) control_transfer returned error, index: 768, error: Resource temporarily unavailable, number: 11
[component_container_mt-3] [INFO] [1737442049.956494250] [visual_slam_node]: Initializing cuVSLAM.
[component_container_mt-3] [INFO] [1737442049.956749770] [visual_slam_node]: Use use_gpu: true
[component_container_mt-3] [INFO] [1737442049.956774250] [visual_slam_node]: Enable IMU Fusion: false
[component_container_mt-3] [INFO] [1737442049.979195702] [visual_slam_node]: Time taken by CUVSLAM_CreateTracker(): 0.022407
[component_container_mt-3] [INFO] [1737442049.979811125] [visual_slam_node]: cuVSLAM tracker was successfully initialized.
[component_container_mt-3] [WARN] [1737442050.288073932] [visual_slam_node]: Delta between current and previous frame [34.128662 ms] is above threshold [34.000000 ms]
[component_container_mt-3] [WARN] [1737442050.322470478] [visual_slam_node]: Delta between current and previous frame [34.153321 ms] is above threshold [34.000000 ms]
[component_container_mt-3] [WARN] [1737442050.357557232] [visual_slam_node]: Delta between current and previous frame [34.177978 ms] is above threshold [34.000000 ms]
[component_container_mt-3] [WARN] [1737442050.389068309] [visual_slam_node]: Delta between current and previous frame [34.051270 ms] is above threshold [34.000000 ms]
[component_container_mt-3] [WARN] [1737442050.421977656] [visual_slam_node]: Delta between current and previous frame [34.048584 ms] is above threshold [34.000000 ms]
[component_container_mt-3] [WARN] [1737442050.455221916] [visual_slam_node]: Delta between current and previous frame [34.046386 ms] is above threshold [34.000000 ms]
[component_container_mt-3] 21/01 15:47:30,879 WARNING [281469439961312] (messenger-libusb.cpp:42) control_transfer returned error, index: 768, error: Resource temporarily unavailable, number: 11
[component_container_mt-3] 21/01 15:47:30,890 WARNING [281469439961312] (messenger-libusb.cpp:42) control_transfer returned error, index: 768, error: Resource temporarily unavailable, number: 11
[component_container_mt-3] 21/01 15:47:30,900 WARNING [281469439961312] (messenger-libusb.cpp:42) control_transfer returned error, index: 768, error: Resource temporarily unavailable, number: 11
[component_container_mt-3] 21/01 15:47:30,911 WARNING [281469439961312] (messenger-libusb.cpp:42) control_transfer returned error, index: 768, error: Resource temporarily unavailable, number: 11
[component_container_mt-3] 21/01 15:47:30,922 WARNING [281469439961312] (messenger-libusb.cpp:42) control_transfer returned error, index: 768, error: Resource temporarily unavailable, number: 11
[component_container_mt-3] 21/01 15:47:30,933 WARNING [281469439961312] (messenger-libusb.cpp:42) control_transfer returned error, index: 768, error: Resource temporarily unavailable, number: 11
