Recent NVidia Cards Flickering Causing Health Issues
Hello all! Im find solutions for my RX 6800 XT, i trying a lot of monitors, and finally il bought monitor " iiyama prolite xb2483hsu-b1 ", i was have some discomfort, but after 3 days its gone, and im again can keep play and work while using my new video card!
NVIDIA,
get someone from the developement team on this thread now!!
You have thousands of people you are physically hurting and you’re completely ignoring it.
You’re going to end up with a class action lawsuite if you continue to ignore that your products are hurting people.
Be the solution and not the problem.
I want to join the club. I am also sensitive and flickering causes me migraine. As many of you descibed it can be pain/pressure in back of the head or behind right eye. After longer periods I feel nervous, unconformable and if migraine begins, it can last for days.
I use GTX 970 connected via DP to 144Hz LCD monitor with G-Sync module. I tried everything. Every setting. every version of driver. Windows or Linux, problem is still there.
I start to feel desperate how to fix this issue other way that leave G-Sync behind and invest in AMD or Intel card instead
 Its sad because I always liked NVIDIA colours and rendering quality (its almost the same now, except DLSS) but company went downhill from my perspective. Newer cards are ridiculously expensive and with this amount of support (almost none) its only funny. Clowns without any real care.
I can also confirm this might be hardware issue and I wonder if any driver/software can fix this. My second PC is laptop with muxxed graphics integrated Intel HD3000 + dedicate GT 525M and guess what. I can stare at that computer screen for days without any issue. This setup has serious overheeting issues because muxxed graphic cards are basickly in like one after another and display part of the job is on Intel side.
Please NVIDIA, do something! I know i have been harsh here. Its only I love your products and I wish this problem has a fix.
EDIT: one question on you guys - do any computer glasses or any other solution works outside gpu/monitor perspective to reduce symptomps from this flickering?
