can u provide me with the link of the jetson orin nano obeject detection examples because in the nvidia website i got some examples which are not compatible on jetson devices as it of drive sdk examples.
You can find Jetson’s tutorial in the below link:
For example, the YOLO detection sample ca be found in the below page:
https://www.jetson-ai-lab.com/tutorial_ultralytics.html
I am using csi camera with jetson orin nano but the live feed of the camera is not been shown
I am sharing the logs here
jetson@jetson-desktop:~$ gst-launch-1.0 nvarguscamerasrc sensor-id=0 ! ‘video/x-raw(memory:NVMM), width=1280, height=720, framerate=30/1, format=NV12’ ! queue ! nvvidconv ! queue ! videoconvert ! queue ! xvimagesink
Setting pipeline to PAUSED …
Pipeline is live and does not need PREROLL …
Pipeline is PREROLLED …
Setting pipeline to PLAYING …
New clock: GstSystemClock
GST_ARGUS: Creating output stream
CONSUMER: Waiting until producer is connected…
GST_ARGUS: Available Sensor modes :
GST_ARGUS: 3280 x 2464 FR = 21.000000 fps Duration = 47619048 ; Analog Gain range min 1.000000, max 10.625000; Exposure Range min 13000, max 683709000;
GST_ARGUS: 3280 x 1848 FR = 28.000001 fps Duration = 35714284 ; Analog Gain range min 1.000000, max 10.625000; Exposure Range min 13000, max 683709000;
GST_ARGUS: 1920 x 1080 FR = 29.999999 fps Duration = 33333334 ; Analog Gain range min 1.000000, max 10.625000; Exposure Range min 13000, max 683709000;
GST_ARGUS: 1640 x 1232 FR = 29.999999 fps Duration = 33333334 ; Analog Gain range min 1.000000, max 10.625000; Exposure Range min 13000, max 683709000;
GST_ARGUS: 1280 x 720 FR = 59.999999 fps Duration = 16666667 ; Analog Gain range min 1.000000, max 10.625000; Exposure Range min 13000, max 683709000;
GST_ARGUS: Running with following settings:
Camera index = 0
Camera mode = 4
Output Stream W = 1280 H = 720
seconds to Run = 0
Frame Rate = 59.999999
GST_ARGUS: Setup Complete, Starting captures for 0 seconds
GST_ARGUS: Starting repeat capture requests.
CONSUMER: Producer has connected; continuing.
nvbuf_utils: dmabuf_fd -1 mapped entry NOT found
Error generated. /dvs/git/dirty/git-master_linux/multimedia/nvgstreamer/gst-nvarguscamera/gstnvarguscamerasrc.cpp, threadExecute:734 NvBufSurfaceFromFd Failed.
Error generated. /dvs/git/dirty/git-master_linux/multimedia/nvgstreamer/gst-nvarguscamera/gstnvarguscamerasrc.cpp, threadFunction:245 (propagating)
Redistribute latency…
Got EOS from element “pipeline0”.
Execution ended after 0:00:04.020021061
Setting pipeline to NULL …
GST_ARGUS: Cleaning up
GST_ARGUS: Done Success
Freeing pipeline …
I have attached the live feed’s screenshot
So what’s the issue and I am using IMX-219 in dual mode and i have configured and I have also tried IMX219-A mode also and its still the same
Could you file a new topic for the camera question?
Since the following problem seems not related to YOLO and detection anymore.
