Hi all
I’m trying to map a grayscale image to get a pointer to use with CUDA.
- I get a FD for the HW buffer using
ExtractFdFromNvBuffer - If I run
NvBufferGetParamsI can see that the format of this buffer isNvBufferColorFormat_GRAY8(which is what I need). - Then I run
NvEGLImageFromFd. - Finally I run
cuGraphicsEGLRegisterImage.
This last step however returns CUDA_ERROR_NOT_SUPPORTED. Every other. Other formats such as RGBA or I420 work just fine. Is GRAY8 not supported?
Platform: Any Jetson board
Jetpack: 4.4
Multimedia API: 32.2.3
