Hi, I tried the configuration for windows access but I got this message
PuTTY X11 proxy: unable to connect to forwarded X server: Network error: Connection refused
Make sure your x server is running on windows (eg. Xvcsrc) and set putty setting like this:
Then connect as usual.
Chances are very high that’s the address vcxsrv will use so that should work. Lmk if it doesn’t.
I tried xrdp and xfce4 and no joy. I then found and followed this tutorial and it seems to work fine for me. The encryption is switched off though so keep that in mind.
https://medium.com/@bharathsudharsan023/jetson-nano-remote-vnc-access-d1e71c82492b
https://www.nomachine.com/download/download&id=116&s=ARM
worked for me almost effortlessly, download, install and boom it works!
