I’m using OpenCV 4.4.1 and a Jetson Nano (JP 4.4) with 3 raspberry pi cameras.
My goal is to process the latest frame grabbed from the ‘next’ camera source in a round robin fashion every 3 seconds. For now, ‘processing’ just means saving the frame to disk. My program continuously grabs frames from all 3 cameras in separate threads to ensure the latest frame is retrieved and the buffer doesn’t grow large while the main thread handles processing.
The problem I’m seeing is that typically at least 1/3 cameras will be frozen on a frame while the other cameras remain real time. So the frame read from the VideoCapture
will be an old frame. This doesn’t happen immediately after starting the program. Sometimes this will happen 10 min later, other times a few hours later. I have seen all 3 cameras “frozen” on a past frame as well.
My gstreamer fstring:
nvarguscamerasrc sensor_id={id} !
video/x-raw(memory:NVMM), width={self.frame_width}, height={self.frame_height},
format=(string)NV12, framerate=30/1 ! nvvidconv flip-method={flip_method} !
video/x-raw, width={self.frame_width}, height={self.frame_height},
format=(string)BGRx ! videoconvert ! video/x-raw, format=(string)BGR
! appsink
I have a class CameraStream
which manages a single camera, so 3 CameraStream
’s are initialized with the gstreamer string above. To ensure that the cameras aren’t being throttled, I call cap.read
in a thread for each camera.
# CameraStream methods..
def start(self):
t = Thread(target=self.get, args=())
t.setDaemon(True)
t.start()
def get(self):
while not self.stopped:
(self.grabbed, self.frame) = self.cap.read()
cv2.waitKey(1)
Then in the main thread I process a frame on an interval:
while True:
image = self.cameras[frame_idx].frame
now_s = time.time()
if (now_s - start_s) < self.args['interval'] or image is None:
continue
''' Code to process frame here - for now, we save to disk .. '''
start_s = time.time()
frame_idx = (frame_idx + 1) % len(self.cameras)
Edit - For my sanity I checked that saving to disk wasn’t the issue by checking the latest frame against a previously saved frame in the main thread when processing:
# Temp check to see if frame is repeating.
if self.old_frames[frame_idx] is not None:
if np.array_equal(self.old_frames[frame_idx], image):
print(f"Same frame idx {frame_idx}")
Edit2 - I’ve done some more testing. I believe cap.read
is hanging or blocking indefinitely and not retrieving anything now, because I cannot get the thread to stop by changing the stopped
variable above after a repeated frame is detected. This would explain the ‘repeated’ frames because the thread would never update the frame.
