We have purchased the Jetson Orin Nano Developer Kit and are planning to design a custom carrier board based on it.
However, we have not been able to find the schematic for the Developer Kit’s baseboard (carrier board).
Is the schematic for the Jetson Orin Nano Developer Kit carrier board available?
If so, where can we access it?
You can check the DLC webpage under the section “Jetson Orin NX Series and Orin Nano Series Design Guide”
Jose Morera
Embedded Software Engineer at RidgeRun
Contact us: support@ridgerun.com
Developers wiki: https://developer.ridgerun.com
Website: www.ridgerun.com
The Jetson Orin Nano Developer Kit consists of a P3767 System on Module (SOM) connected to a P3768 carrier board. The complete kit is designated by part number P3766.
Regarding the schematic for the P3768 carrier board, the provided context does not explicitly mention its availability or provide a direct link to access it. However, it does mention that NVIDIA provides the binary and source for the EFM8SB10F2G-A-QFN20 MPU for Power Button control on the Jetson Download Center.
It is likely that the schematic for the P3768 carrier board is not publicly available, as the context suggests that customers should replicate the circuitry on the latest P3768 carrier board exactly, and provides instructions for obtaining the flashing instructions from Silicon Labs.
If you are looking for the schematic, I recommend checking the following resources:
- Jetson Download Center: You can try searching for the P3768 carrier board schematic or related documentation on the Jetson Download Center.
- NVIDIA Developer Website: You can also check the NVIDIA developer website for any documentation or resources related to the Jetson Orin Nano Developer Kit and the P3768 carrier board.
- Contact NVIDIA Support: If you are unable to find the schematic or related documentation, you can try contacting NVIDIA support directly to inquire about the availability of the schematic and any other resources you may need.
In summary, while the context does not provide a direct link to the schematic, it suggests that NVIDIA may provide some documentation or resources related to the P3768 carrier board on their website or through their support channels.
